Thursday, September 9th 2010, 4:15pm UTC+2
  • Login
  • Register
Wednesday, March 3rd 2010, 3:56pm
command line on linux
hello,
how do you send an image file to kmakemultires on the command line ?
[edit] I tried > and |
ideally I want to tag something on the end of the windows pscp line to send the file directly to kmakemultires on the linux box.
cheers
Mick
This post has been edited 1 times, last edit by "michael crane" (Mar 3rd 2010, 11:41pm)
Friday, March 5th 2010, 1:42pm
as normal parameters,
e.g.
./kmakemultires pano.jpg
if you want to that a specifc .config file will be used just pass that too,
e.g.
./kmakemultires pano.jpg settings.config
or set the settings from the .config file direct on the command line (the setting must be prefixed with a '-')
e.g.
./kmakemultires pano.jpg -tilesize=512 -panotype=flat -hfov=1.0
Friday, March 5th 2010, 9:40pm
cheers *smile*
Similar threads
