Friday, February 20th 2009, 11:25am
Problems to put one or two images
Hi, klaus
I have problems to put any images in a textfield
example:
1 image of a product and a second image as a logo
If possible or not ? *cry*
This post has been edited 1 times, last edit by "Job.1" (Feb 20th 2009, 12:35pm)
Friday, February 20th 2009, 2:07pm
yes, that is possible,
the textfield plugin just uses the flash intern html renderer,
it has a very limited html support but simple images are possible
e.g.
<img src="image1.jpg" width="100" height="80" /><br/>
<img src="image2.jpg" width="100" height="80" /><br/>
but one important note - the paths of the images are relative to the html file!
when you use the flashplayer debug plugin you will get a error from
the flashplayer when the image can't be loaded,
I'm not sure but I think the normal flashplayer will just display nothing
when a image can't be found,
Friday, February 20th 2009, 2:59pm
Thanks Klaus
we can put them in the center of the textfied ?
many pb with that here *cry*
Graydon
Professional
Occupation: Industrial gas turbine services.
Friday, February 20th 2009, 7:02pm
I don't think the flash html renderer supports putting an image in the center... only left / right.
this link was helpful to me...
http://livedocs.adobe.com/flex/201/langr…d.html#htmlText
as well as this one for css stuff...
http://livedocs.adobe.com/flex/201/langr…StyleSheet.html
Of course, I'm still trying to figure out if I can get images to be side by side.... they keep showing up on different lines. *sad*
Friday, February 20th 2009, 8:39pm
Thanks for the links Graydon ;-)
Saturday, February 21st 2009, 10:32pm
Hi every body
I try to put a background image in the textfield and I can't *confused* *cry*
have you any code for me ?
This post has been edited 1 times, last edit by "Job.1" (Feb 21st 2009, 11:16pm)
Monday, February 23rd 2009, 11:51pm
a background image is not possible,
but you could disable the background of the textfield and add a normal image (<plugin>)
behind the textfield (verfiy zorder)
Tuesday, February 24th 2009, 10:07am
Okay Klaus I try it
Tuesday, February 24th 2009, 12:42pm
can you show me the example or the xml code?
Tuesday, February 24th 2009, 1:05pm
syntax error "enable" and "visible" is not the same
okay I get the image now in background, and others images in the textfield all are ok, but I lost all the text
edit 13h25
sorry for all troubles Inot awake this day all it's working very well *thumbsup*
This post has been edited 1 times, last edit by "Job.1" (Feb 24th 2009, 1:27pm)
Saturday, August 22nd 2009, 4:36pm
Error #2044: IOErrorEvent non pris en charge : text=Error #2036: Le chargement n'a pas été achevé.
Hi ,
I try the textfield, when i'm in local, all is ok,
then when it's on the server :
If i remove the <img> balise, it work properly....
Someone know something about this problem ?
thanx
Tuesday, August 25th 2009, 2:17pm
this means that the image couldn't be loaded,
the path to the image in the textfield must be relative to the "real" HTML file (the file where the krpano.swf is embedded),
