Saturday, February 28th 2009, 5:30pm
Replacing jpg buttons with swfs
As the title says: How can I replace the little jpeg on-screen nav buttons with nice animated swfs ? I have tried all the obvious things with Z order, size, names, %SWFPATH% etc but nothing appears. Is there a simple answer ?
(Sorry to ask so many questions!)
Graydon
Professional
Occupation: Industrial gas turbine services.
Saturday, February 28th 2009, 5:50pm
should be able to just replace the url --> jpg with the url pointing to the swf that you want to use.
http://www.krpano.com/docu/xml/#plugin
can you post a sample of your code?
Sunday, March 1st 2009, 1:02am
I thought I could just do a straight swap too, but no luck. I have tried many permutations and different swfs.
In the code below if I swap the left.swf for left.jpg it works perfectly !
<plugin name="flash"
    	url="left.swf"
    	width="100" height="100"
 	visible="true" enabled="true" handcursor="true" capture="true" children="true"
 	zorder="0"
 	alpha="1.00" blendmode="normal"
    	align="rightbottom" x="10" y="10"
    	onhover="showtext(Flash element);"
    	onclick="openurl(http://krpano.com,_blank);"
Graydon
Professional
Sunday, March 1st 2009, 2:08am
In the 1.0.7 stable release, under examples / tour... there is a hotspot_ani.swf... so it's guaranteed to be compatible with krpano... try it also.
The only other thing that you might want to add first... is...
keep="true"...
but if the jpg file is showing... then the swf should show as well without it.
I've tested the code you posted and made only two changes...
1. using the hotspot_ani.swf
2. added keep="true"
The second one is more specifically for how I have my test template setup... I do not load a pano initially... only after clicking on a button will the first pano load.... thus I NEED to have keep true in place otherwise it dumps the plugin.
Sunday, March 1st 2009, 8:39am
You've rescued me again Graydon, thanks :-)
