bulp
  • "bulp" started this thread
Saturday, October 24th 2009, 11:26am
cant embed plugin..
Hye Klaus.. i cant directly embed all the plugin into 1 swf or exe... but the rest of the file are alreday embed..
i do manually select the file to embed.. in kprotect it seem all can be embed..
the whole file size is about 26Mb... with 7 pano + 3 swf plugin + 1 jpeg .....
This post has been edited 1 times, last edit by "bulp" (Oct 25th 2009, 9:23am)
milotimbol
Occupation: Software Developer
Sunday, November 1st 2009, 11:20am
I am having the same problem. I am trying to create an exe file with scrolling thumbnails and simple viewer
I get this error
download of "as3Thumbsforkrpano.swf?TheXML=gallery.xml" failed
and
download of "simpleviewer.swf?xmlDataPathl=photos.xml" failed
In kprotect under the embed/encrypt I manually added the .swf and xml files. When running the exe file on the krpotect folder it works but when I put the exe file on a different folder the errors above appears.
milotimbol
Sunday, November 1st 2009, 11:06pm
klaus,
Some observation
When running the .exe file inside the folder where kprotect.exe is the "scrolling thumbnail" and "simple viewer" plugins work. When I rename the xml files in that folder, gallery.xml to gallery2.xml and photos.xml to photos2.xml and run the .exe file again I see the errors again
It means that gallery.xml and photos.xml were not pacakaged in the .exe file. I also tried renaming the 2 plugins, and I get the errors. For some reason kprotect is not including these files even If I had manually added them.
Help!!! I need to give an offline wedding 360 presentation in a few days.
thanks,
Milo
bulp
Monday, November 2nd 2009, 5:59am
hello milotimbol...
the swf plugin that im trying to embed is without xml .... not like milo...
maybe should have the upgraded version of kprotect?....
anyway thank you Klaus for the GREAT WORKS!!!!! *thumbsup*
milotimbol
Monday, November 2nd 2009, 8:39am
bulp,
I'm using the latest bet version. Just downloaded it a while ago.
Monday, November 2nd 2009, 4:15pm
embedding such plugins is not possible,
because the parameter passing via HTTP GET (the '?parameter=value&...) is not possible for files that where loaded from memory (like the embedded files),
and further - the plugins are loading the files with the standard flash IO routines,
so they can't load the embedded files,
in beta 9 I will provide an interface for plugins to make them able to load embedded files,
but then the plugins must be re-coded and use this interface (but this will not be possible for the simpleviewer),
milotimbol
Monday, November 2nd 2009, 10:52pm
ok. now I really have to learn actionscript. *smile* .
thanks,
Milo
bulp
Tuesday, November 3rd 2009, 7:52am
Klaus...
"in beta 9 I will provide an interface for plugins to make them able to load embedded files,
but then the plugins must be re-coded and use this interface (but this will not be possible for the simpleviewer),"
hurm.. cant wait to get this interface... :) ...
Milo.. good luck...
Tuesday, November 3rd 2009, 10:26am
okay, you want it now
here a short how-to:
download the 1.0.8 beta 9 pre-release from here:
1.0.8 beta 9 - fovtype setting
download and use this this krpano_as3_interface.as:
krpano_as3_interface.zip
there are these new functions in the as3 interface:
loadfile(url:String,donefunction:Function,errorfunction:Function=null,cacheit:Boolean=true)
- loads the given file and returns a ByteArray with the bytes of the file
loadobject(url:String,donefunction:Function,errorfunction:Function=null,cacheit:Boolean=true)
- loads the given file and returns a Loader object (only for swf,jpg,png,gif files)
both functions can also load embedded files,
if a file can't be loaded, it automatically shows an error message,
by passing an own errorfunction the error can also be handled manually,
the 'donefunction' will be called when the file was downloaded (and decoded),
is passes an Object with the following attributes: "url", "data" and "loader",
it will look like this:
function donefunction(ld:Object):void
  var url:String = ld.url;        // the file url
  var bytes:ByteArray = ld.data;  // the data bytes (loadfile())
  var loader:Loader = ld.loader;  // the Loader object (only loadobject())
example usage:
14
15
16
17
krpano_as3_interface.loadfile("pano.xml", xmldone);
krpano_as3_interface.loadobject("image.jpg", imagedone);
function xmldone(ld:Object):void
  var xmlstring:String = String(ld.data);
function imagedone(ld:Object):void
  this.addChild(loader); // e.g. add the loader to show it
more details and examples later on release
Rahim
Trainee
Occupation: diving instructor/photographer
Tuesday, June 29th 2010, 2:53pm
well i have a relative problem i am trying to create a standalone file ,even though i put the plugin and the gallery files apart when working offline the thumbs are not visible however when i put the tour online it is working fine it is only with the krpano standalone that it will not work
any help i need to deliver an offline version soon!!! *unsure*
Similar threads
