Hi Graydon,
Thanks for answering
You are right in saying that there is already the possibility to customize the
cursor as it is show in the "examples /
cursors"...
But note that this do not apply to the arrow
cursor or
hand cursor that appears onover a plugin .... it only apply to the
cursor onover the pano itself...
As an exemple to demonstrate this, edit the
cursors example erasing the b1 plugin, with the following one :
<plugin name="b1" style="buttonstyle"
visible="true" enabled="true" handcursor="false" capture="true" children="true"
html="[p]move[/p]"
align="bottom" x="-240" y="25"
onclick="action(movecursor);"
onhover="action(arrowcursor); "
You can also change the settings for the
handcursor and capture attributes... no changes...
Surely this can be done in using AS3... It would be great to have this feature able directly from xml
... KLAUS please
SAlut.
