21
Monday, August 30th 2010, 9:48pm
It seems that the plugin Autolevels.swf sets default values when no parameters are preset in the xml ... isn't it?...
This has been confusing me a long time *wacko* ... Unless if the preload is set to true for plugin Autolevels.swf, some times they apply, some no *whistling* ...
I am not sure I am using the registerattribute() call in registerPlugin(event:DataEvent) correctly. That takes a default setting, but that defaultsetting does not seem to "take" so I set it again. Look at the registerPlugin() function for default values.
pow(val,0.33333333333333333333333333333333)
I'm not dead-set on pow(val,3)... pow(val,4) and pow(val,.25) may be more convenient.
Either way, the ui works more than well enough. Thanks for your work.
22
Wednesday, September 1st 2010, 7:00pm
This plugin is f*****g amazing !!!!!!!!!!!
Love it !
Just something that annoys me, when I look to the sky, the plugin effect is ugly ... Is there a way to avoid this effect??
Thanks a lot !!
Flow
michel
Professional
Occupation: TV
23
Wednesday, September 1st 2010, 8:14pm
Hi Aldo,
I have little knowledge of AS3 so I can not be of much help here *sad* ... Perhaps Zephyr could *rolleyes* , or KLAUS himself ;-) ...
About the UI you are using on your web page, it has an issue.... After that the pano has finished to load, try clicking over the threshold slider... The pano turns black because the value for the threshold attribute becomes "NaN"... So the code works wrong... The last UI above should work properly...
Hi Tiflo,
Quoted from "Tiflo"
The The This plugin is f*****g amazing !!!!!!!!!!!
Love it !
Yes, this plugin is f*****g amazing !!!!!!!!!!! *g* ... But it can be difficult to obtain the proper configuration for a given pano:
The effect can be tuned to affect just the luminosity of the view, or the luminosity as well as the color of the view. Please note that the effect is applied to the (jpeg compressed) 8 bit panorama, so if the effect is too pronounced you will start to see artifacts such as banding and color mismatches. There is a number of parameters that will let you tone down the effect to suite your images.
You can include the autolevel_ui.xml to help finding the correct values for each attributes... You can download it here ....
SAlut.
24
Friday, September 3rd 2010, 11:24am
Quoted
normally the registerattribute() should work...
do you have an example where not?
was any attribute really 'null' in any case?
it checks if there is already an attribute and if not it creates it with the given default value,
but note - there is no automatic type conversion for numbers, a given number can be also a string,
but with casting (what you already doing) that should be not a problem...
but there are some attributes that are already used by krpano - "enabled" and "effect",
maybe this can cause problems, I'm not sure yet...
michel
Professional
Occupation: TV
25
Saturday, September 4th 2010, 9:49pm
First, I have no idea about AS3, that could explain if I say something with no sense ;-) ...
About the default values in AS3 (that could return NaN as value)... I have read somewhere that the default value for a variable typed as Number is NaN ... The default value for a variable typed as int is 0 ... So, perhaps it could be good to retype the variables from Number to int ...???
I would like to try the above editing the file autolevels.as with flash CS4 but, as I am very new on this, I just do not know how to save the resulting code as an SWF file *sad* *thumbdown* *g* .... Please, someone could explain or point to a tutorial *smile* ?
SAlut.
Graydon
Professional
Occupation: Industrial gas turbine services.
26
Tuesday, September 7th 2010, 5:03am
Aldo - great work and the new site is looking good.
27
Wednesday, September 8th 2010, 12:01pm
this file must be compiled with mxmlc (not Flash CS*),
to compile it: (under Windows)
  1. get the free "Flex SDK", e.g. here
  2. extract the Flex SDK zip anywhere
  3. the mxmlc compiler is s located in the "bin" folder,
    add that folder to PATH environment variable,
    or make a shortcut of it for drag and drop usage,
  4. finally you need to call "mxmlc -use-network=false autolevels.as" to build the .swf
    (the -use-network=false settings is necessary to let the swf also work offline)
here is also a great tutorial for the mxmlc compiler:
http://www.senocular.com/flash/tutorials/as3withmxmlc/
Tuesday, October 5th 2010, 9:22am
Great plugin - thanx for sharing this!
minor bug found - on exit of the plugin it does not reset the applied layer color- and brightness adjustments:
Using it in a tour (not in a single pano) i put no "keep = true" to the defining plugin. Because i want it to be alive only in those panos of the tour i decide it to be useful. Now when you leave one pano with activated autolevels into another one without this feature the last autoleveladjusment stays and controls this new pano. It means that the new pano with no autolevels activated is much to dark or light, depending on the exit-situation of the pano before.
best regards!
best regards from www.PanAustria.com
29
Tuesday, October 5th 2010, 5:45pm
I have uploaded a new version of the plugin that should fix this issue (though I have not tested the fix)
http://fieldofview.com/sites/default/fil…/autolevels.swf
'do
30
Tuesday, October 5th 2010, 8:14pm
Thank you very much - i tested the update and the bug is fixed with this new version!
Hellkeeper
31
Wednesday, October 13th 2010, 7:05pm
Great plugin - already using it on http://www.gpix.at --> one thing I noticed - if you click on any of our hotspots - the color won't adjust until the final destination is reached - sometimes there are massive misscorrections if you zoom from a dark spot to a lighter one - or vice versa.
following procedure to move to hotspots:
- zoom out half
- pause 0.33
- zoom in to hotspot
is there at least a possibility to get autolevels to readjust the color while we do the pause?
Thank you, bye
Andreas
Andreas Schnederle-Wagner
Rundblick GmbH / Gigapixel aus Österreich
https://www.rundblick.at/
https://www.gpix.at
32
Saturday, October 16th 2010, 1:48pm
Interesting... The autolevels plugin relies on krpano sending events.onviewchange events. Apparently these are not being fired during a moveto call. Unless Klaus agrees this is a bug in krpano and fixes it it a next release, I may have to find a workaround.
edit: I just thought of a workaround; setting any of the autlevels plugin attributes should result in recalculating the histogram. You can set a variable to its current value again, or even set a "dummy" variable (set(plugin[autolevels].dummyvar,0)). If you do this before going into the pause, you should at least get some adjustments going on during the sweep.
Hellkeeper
33
Monday, October 18th 2010, 12:25pm
thank you for this workaround - not perfect - but better than before! ;-)
Maybe Klaus can send the onviewchange events while moveto - or maybe new Events like "moveToStart" and "moveToStop" or something like that? (I'm no AS pro ;-))
bye
Andreas
https://www.gpix.at
VN2009
Professional
34
Wednesday, December 22nd 2010, 4:26pm
does this plugin still work with the newer version? i tried to add it but it does nothing. the effect is not applied.
35
Monday, December 27th 2010, 6:15pm
Yeah, it works for me, the same way it did for 1.0.8.11. Are you using the UI to tune the effect? Do you have a link we can check out?
VN2009
Professional
36
Thursday, December 30th 2010, 3:58pm
I did get this to work. I had to play with the threshold some but it is working. Great Plugin! Thank you!
fotojehle
Beginner
Occupation: Fotograf
37
Thursday, April 7th 2011, 10:33pm
Great plugin
Aldo many thanks for sharing!!!!
Felix
Hellkeeper
38
Thursday, August 30th 2012, 11:48am
I got some Problems with the Autolevels Plugin - I described them here: Mouse Problem
Any chance to fix them? As I really don't want to loose this great plugin! :-/
thx
Andreas
https://www.gpix.at
39
Sunday, May 19th 2013, 7:55pm
Html5
There will be a version for html5?
40
Monday, May 27th 2013, 10:37am
The short answer is "probably not any time soon"
