globule22
Trainee
  • "globule22" started this thread
Wednesday, June 2nd 2010, 12:08pm
Kmakemultires 1.0.8.10 error
I have a 55Gb Giga panorama which i want to be tiled.
I start in terminal calling Kmakemultires with parameters. After telling it the configuration of my panorama, it starts creating the tiles for level 7: l7_%0v_%0h.jpg
But i get an error
ERROR: unable to create file /xxx/xxx/xxx/pano.tiles/l7_01_253.jpg
Any idea?
Regards
Wednesday, June 2nd 2010, 12:41pm
on what system you are? (Mac?)
what tilesize do you use and what are the image dimensions?
(enough disk space?)
globule22
Trainee
Wednesday, June 2nd 2010, 2:44pm
I am on a Mac 10.6.3 Snow Leopard
The panorama is on a separated hard drive, kmakemultires too.
The hard drive is 1.31 To available.
The size of the picture is 233059*59652 px ; and the tilesize is automaticlly by 780px
Maybe it is a swap file problem? like i had on this thread: kmakemultires 1.0.8 bug with High gigapixel panorama
Regards
Wednesday, June 2nd 2010, 2:55pm
on Mac the number of files that are opened at the same time by one program is limited by default (I think to 256), and a program can't change that limit by itself,
the kmaketiles tool is writing all tiles for one row at the same time,
that means for a 233.059 pixel wide image a minimum of 299 (=233059/780) files will be needed,
and this is more than the limited 256 files,
you can increase this 256 files limit in the terminal by the ulimit command,
e.g. to increase the limit to 1000 files:
ulimit -n 1000
than it should work,
globule22
Trainee
Wednesday, June 2nd 2010, 3:01pm
Nice Klaus,
Genration start well ! just need to wait a little ;)
Regards
Friday, October 1st 2010, 11:57am
hi, i have the same problem on both windows and linux. kmakemultires makes a preview.jpg alright and crashes.
Quoted
kmakemultires 1.0.8.11 (build 2010-05-31)
processing - project (SPHERE)
inputfile:
image: project.jpg (25000x12500)
outputfiles:
xml: project.xml
preview: project.tiles/preview.jpg
tiles: project.tiles
parameters:
-xmltemplate=panoonly.xml
-tilesize=625 (automatic)
-levels=4 - 25000x12500, 12500x6250, 6250x3125, 3125x1563
generate:
making preview...
making tiles: project.tiles - 40x20 (800) tiles
ERROR: unable to create file /storage/virttours/gigapan/jpeg/project.tiles
on linux i tried
Quoted
ulimit -n 2000
but that wouldn't help. i also moved the krpano tools and the panoramic image to another hard drive where there is a lot of free space - no change.
Friday, October 1st 2010, 12:59pm
that must be a different problem,
in your case there's just 40 files / row, that shouldn't be that problem,
does the tool has the rights/permissions to write to that folder?
Friday, October 1st 2010, 5:12pm
i guess it has, because it successfully creates the folder project.tiles and the file preview.jpg inside
