February 24, 2011 at 1:31 PM #1 Hello,I'd like to know if there is a way to show a textstyle with the showtext command outside the pano area when using absolute coordinateSomething like plugin[].parent = stageThanks !Regards
February 24, 2011 at 2:59 PM #2 check here https://krpano.com/examples/textstyles/ you can place text staticlly use textstyles anywhere you want. use the textstyle to place the text outside the stage. then use showtext(text goes here,textstylehere);
February 24, 2011 at 3:09 PM #3 Thanks for your replyBut in this example, the area node is not used ... so the textstyle 9 position is fixed, but inside the pano area
February 24, 2011 at 4:39 PM #4 i guess i dont understand then. if you are not using area tags how would you place the text outside the stage if the stage is 100% x 100%?
