Sie sind nicht angemeldet.
Freitag, 24. August 2012, 13:53
PNG frames horizontally
Just as you can make an animation from a vertical strip frames (eg hotspot), is it possible to do it from a horizontal strip?
My program generates only horizontal strips.
Freitag, 24. August 2012, 20:45
Simply replace the pair of parameters offset animation. That's one of the standard examples:
Quellcode
14
15
16
17
18
19
20
21
22
23
24
25
<hotspot name="hs1" style="hs-animate"
ath="324.93" atv="3.20" keep="true" devices="all"
onhover=""
onclick=""
<style name=hs-animate"
url="hs_anima.png"
crop="0|0|128|128"
keep="true"
zorder="99"
scale="0.7"
align="center"
framewidth="128"
 frameheight="128"
 frame="0"
lastframe="5"
onloaded="hs_animate(); />
<action name="hs_animate">
inc(frame,1,get(lastframe),0);
mul(ypos,frame,frameheight);
txtadd(crop,'0|',get(ypos),'|',get(framewidth),'|',get(frameheight));
delayedcall(0.1, if(loaded, hs_animate() ) );
Change the parameters in Action:
mul(xpos,frame,framewidth );
txtadd(crop,'0|',get(xpos), …
That's all! *tongue*
Panoreal — to make and see this wonderful world! *whistling*
Montag, 27. August 2012, 18:40
No me funciona
Thank you very much your help.
I have ridden an example with horizontal strip (left) and vertical (right): http://www.imaginartejuegos.com/ijLAB/ej…spotanimado.htm
As you can see on the right is working properly, but not the left.
The code used is this:
Quellcode
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
ath="-30" atv="0" keep="true" devices="all"
onhover=""
onclick=""
<style name="hs-animate"
url="posibilidades/imag/ojos-tira300.png"
crop="0|0|300|300"
keep="true"
zorder="99"
scale="1"
align="center"
framewidth="300"
frameheight="300"
frame="0"
lastframe="23"
onloaded="hs_animate();" />
mul(xpos,frame,framewidht);
txtadd(crop,'0|',get(xpos),'|',get(framewidth),'|',get(frameheight));
<hotspot name="vs1" style="vs-animate"
ath="30" atv="0" keep="true" devices="all"
onhover=""
onclick=""
<style name="vs-animate"
url="posibilidades/imag/tiradados1.png"
crop="0|0|130|1230"
keep="true"
zorder="99"
scale="1"
align="center"
framewidth="130"
frameheight="130"
frame="0"
lastframe="15"
onloaded="vs_animate();" />
<action name="vs_animate">
delayedcall(0.1, if(loaded, vs_animate() ) );
What is my mistake?
Mittwoch, 29. August 2012, 08:49
Zitat
What is my mistake?
here:
you need to swap x and y - correct would be:
txtadd(crop,get(xpos),'|0','|',get(framewidth),'|',get(frameheight));
Donnerstag, 30. August 2012, 19:38
¡¡ PERFECT !!
Thank you very much Klaus.
In addition to the error that you show me a little more I found another in the line above with "framewitdht".
You can see the end running on http://www.imaginartejuegos.com/ijLAB/ejemplo_base/hotspotanimado.htm
Take this opportunity to congratulate you on the latest version of krpano and VTOUR interface.
Greetings
Agustín
jschrader
Fortgeschrittener
Beruf: Photographer, Producer
  • Nachricht senden
Montag, 21. Januar 2013, 14:20
Exactly what I needed.
Thank you very much to everyone *thumbsup*
esys
Fortgeschrittener
Beruf: photographer
  • Nachricht senden
Freitag, 10. Mai 2013, 16:29
IS it possible to don't have a drop (the hotspot would stay constantly visible) in this animation?
I'd like to put like an animated glow effect around the hotspot, so the hotspot needs to remain visible all time.
Thanks.
Steph.:-)
Steph
Montag, 15. Juli 2013, 11:01
Animation with cross-fade effect
UPDATE!
Now I myself want to use animation without flash file(swf) on any device!
But the question is: how to make simple animation with cross-fade effect to make the transition frame by frame?
Frame#1 -->fade 0.5 sec --> Frame#2 --> fade 0.5 sec --> Frame#3… action to stop or replay and etc.
I understand that can be done using the individual layers with pictures and action "tween alpha", but I want this to be a separate action without a write action in each layer/plugin image! This is is possible?
Any suggestions or idea!? I'm deep in thought!
*confused*
Beruf: Interpreting, Building virtual tours
  • Nachricht senden
Montag, 15. Juli 2013, 14:50
Regards,
Alexey
Montag, 15. Juli 2013, 18:57
Yes, like this!
Basic fade: A->B->C
Earlier I used a flash file with any animation and alternative flat image for html5 versions.
Ось такі справи, друже)
Dienstag, 16. Juli 2013, 17:02
