Wednesday, July 17th 2013, 9:19pm
Is there a way to autosize the width of hotspot textfield?
I need to put tooltip hotspots with background. It seems that I need to write down
width and height for every single tooltip hotspot. Since the width of every tooltip hotspot
is different from one another, it is really a time consuming task for finding out
right size..
I wonder if there is a way to autosize the width of hotspot textfield.
Or is there a way for workaround?
This would be a really convenient feature!
Best Regards,
Hyung
Alexey Tkachenko
Professional
Occupation: Interpreting, Building virtual tours
Wednesday, July 17th 2013, 10:22pm
Well, I thought on that issue before and just now I've created something like that, I suppose *smile*
Try adding this action
<action name="show_tooltip">
	txtadd(tooltip_width_search, 'get(tooltip)','_countstart');
	indexoftxt(number_of_characters,get(tooltip_width_search),_countstart,0);
	mul(text_width, number_of_characters, 8);
	copy(layer[tooltip].width, text_width);
	copy(layer[tooltip].html, tooltip);
	set(layer[tooltip].visible, true);
	tween(layer[tooltip].alpha, 1.0, 0.5);
	asyncloop(hovering, copy(layer[tooltip].x,mouse.stagex); copy(layer[tooltip].y,mouse.stagey); );
to the onover attribute in the style of your hotspots. I've just tested it quickly and it seems to work.
The value "8" in this line
Comes from my thought and my quick practical test that the font Arial 12 has optimal "width" of 8 px. If I set more than 8, the textfield becomes a bit long on the edges, if I state less than 8, textfield sometimes becomes "cut'. So if you are using other fonts, then state some other character width value.
Or maybe is there some connection between font height and font width in lower and upper cases? I don't know that, unfortunately...
P.S. note that there must be tooltip="your_tooltip" attributes in your hotspots for the above action to retrieve these tooltips.
Regards,
Alexey
Thursday, July 18th 2013, 11:03am
Brilliant Alexey!
I haven't tried it myself yet but I believe this would work! I was thinking something
similar (getting the size of the tooltip on the fly) but I thought there is no krpano action
that would do this but "indexoftxt" would do the trick.
I will try the code later and share the result :)
Thanks!
Hyung
Thursday, July 18th 2013, 9:48pm
This is how I applied based on the code Alexey has provided
14
15
16
17
18
19
20
21
22
23
	<style name="building_tooltip"
		url="%SWFPATH%/plugins/textfield.swf"
		children="false"
		css="text-align:center; color:#FFFFFF; font-family:Arial; font-weight:bold; font-size:12px;"
		vcenter="true"
		backgroundcolor="0x000000" backgroundalpha="0.6" roundedge="5" border="false"
		handcursor="false" capture="false"
		height="25"
	<action name="calc_tooltip_width">
		if(hotspot[%1].width == 0,
			txtadd(tooltip_width_search, get(hotspot[%1].html),'_countstart');
			indexoftxt(number_of_characters,get(tooltip_width_search), '_countstart',0);
			mul(text_width, number_of_characters, 17);
			if(number_of_characters GT 5, sub(text_width, 10));
			copy(hotspot[%1].width, text_width);
			delete(tooltip_width_search, number_of_characters, text_width);
	<hotspot name="building_tooltip1" ath="20" atv="0" style="building_tooltip" html="Main Entrance" onloaded="calc_tooltip_width(building_tooltip1);" width="0" />
	<hotspot name="building_tooltip2" ath="-30" atv="-15" style="building_tooltip" html="Second Entrance" onloaded="calc_tooltip_width(building_tooltip2);" width="0" />
I found out that the length of one character is not always the same.. This could be worse
when using non alphabetic language characters. So I set the basic width for one character
and when there are many characters I subtract certain pixels. (In the code above I subtract
10 pixels of width when there are more than 5 characters)
Of course the value would differ depending on the language, font size, font style etc..
And I tried to apply this action to all the tooltips hotspots at one time but I don't know this
could be done with pure krpano actions. So I have added "onloaded" event to each tooltip
hotspot.
Lastly, automatic width calculation action is performed only when there the value of "width"
is 0. First I have removed the width and tried to give condition "when there is no width
specified" in the "calc_tooltip_width" action but I didn't succeed.
I tried something like
if(hotspot[%1].width != null
if(hotspot[%1].width !== null
ifnot(hotspot[%1].width == null
ifnot(hotspot[%1].width === null
if(get(hotspot[%1].width) != null
if(get(hotspot[%1].width) !== null
ifnot(get(hotspot[%1].width) == null
ifnot(get(hotspot[%1].width) === null
but none of them worked. It's probably because the width is NOT null but I don't know
what condition I should do the job.
So if you specify the width value more than 0, then that value will be applied and otherwise
the width will be calculated automatically.
Thanks again to Alexey for giving guides.
Hope this helps others too :)
Best Regards,
Hyung
Alexey Tkachenko
Professional
Thursday, July 18th 2013, 10:38pm
Hi!
I'm glad that my thoughts were useful *tongue*
Really can't understand why your code doesn't work unless width="0"... *confused*
Regards,
Alexey
Alexey Tkachenko
Professional
Thursday, July 18th 2013, 11:25pm
Just tried your code.
Really, if don't specify "width" of the hotspot, I get both hotspots at 400 px in width.
If I specify some other value other than "0", I got this value as textfield width. *confused*
Regards,
Alexey
Alexey Tkachenko
Professional
Thursday, July 18th 2013, 11:44pm
I've had another try just now with this code:
14
			txtadd(tooltip_width_search, 'get(hotspot[%1].html)','_countstart');
			indexoftxt(number_of_characters,'get(tooltip_width_search)', '_countstart',0);
	<hotspot name="building_tooltip1" ath="20" atv="0" style="building_tooltip" html="Main Entrance" onloaded="calc_tooltip_width(building_tooltip1);"  />
	<hotspot name="building_tooltip2" ath="-30" atv="-15" style="building_tooltip" html="Second Entrance to the church" onloaded="calc_tooltip_width(building_tooltip2);" />
And it seems to calculate the width of the tooltip, if I increase the tooltip phrase, the tolltip textfield grows in length.
Has anybody else tried this yet?
Regards,
Alexey
Friday, July 19th 2013, 10:34am
Yes I also get 400px if I don't specify the width. Seems that 400px is the default width used
inside krpano. Do you still get 400px even give value other than "0"? Strange, because the codes
works for me, which means if I give 100 as width for example, the action is ignored and the
width becomes 100. Maybe it could be different krpano version, or you might want to delete
browser cache and check again.
I have modified the code a bit as below so that in order to differentiate mobile from desktop
			mul(text_width, number_of_characters, 18);
			ifnot(device.mobile,
				if(number_of_characters GT 10, sub(text_width, 40));
Again, the right size if the width would depends on the language, font size, style etc..
I believe the code in your last post should work :)
Best Regards,
Hyung
Alexey Tkachenko
Professional
Friday, July 19th 2013, 10:58am
It's just struck me. Is this okay to define hotspot url as "textfield.swf"? Maybe textfield has some default width value which interferes with the action?
*confused*
Just a guess...
Regards,
Alexey
