Saturday, August 3rd 2013, 12:57am
Encrypt xml not protect code!!!
Hi Klaus.
*attention* Any encrypted XML file can be downloaded and easily view!
Just connect it to your panorama and enable the plugin editor.swf (http://krpano.com/plugins/editor/ # top). This plugin shows all the code!
It turns out that the files are not protected!
Really there is not any protection of XML files? *cry* *question*
I want to write XML code so that it would not be seen ...
Look, this code has been encrypted:
Thank you in advance.
Thursday, August 8th 2013, 1:44pm
what you see here in the editor is a dynamically rebuild xml, not the source xml itself.
That rebuilding works via the normal 'get' interface.
But I understand that some people didn't want that too. In newer versions there will be an additional setting in the krpano Protect to allow ONLY privately encrypted xml and plugins files. Together with the disabled external parameters and disabled Javascript-interface, there will be no way to the runtime data.
Thursday, August 8th 2013, 4:49pm
Great to hear, Klaus! Even the dynamically created xml shows too much ;-)
Friday, August 9th 2013, 8:41am
This is good news!
Thank you.
jordi
Monday, August 19th 2013, 10:44am
Great Klauss !!
everpano.com step beyond 360
Similar threads
