jl-krp
  • "jl-krp" started this thread
Occupation: Panographer - hobby and commercial
Thursday, October 17th 2013, 11:55pm
on hover? on click?
Hi
I have an overlay on a pano where I'd like the user to be able to hear some audio when hovering, then go to another scene when s/he clicks
This is what I've used:
onhover="stopallsounds();playsound(auto,sounds/2dante.mp3|2dante.ogg);"
onclick="loadscene('scene_1',null,MERGE,BLEND(1));"
but it only plays the audio when clicked and does not go the next scene - what am I doing wrong? (Mac desktop, initially)
thanks
JL
Friday, October 18th 2013, 2:24am
attribute name full variable name type default value
onover
layer[name].onover
Action Event
Actions / functions that will be called when the mouse moves over the layer/plugin element.
onhover
layer[name].onhover
Action Event
Actions / functions that will be called in intervals (15 times per second) when the mouse stays over / hovers the layer/plugin element.
Try onover
jl-krp
Friday, October 18th 2013, 9:39am
Many Thanks - over not hover
Hello Jarredja
When in doubt remove the 'h', and it works!
I should have said that I was using a hotspot with a text layer. I've changed it to a layer but I'm not at all clear as to the difference between hotspots, layers and plugins as yet, they seem to be interchangeable. This L curve is a steep climb but worthwhile.
Now I'd like to limit the audio to a single 'play' - will work on it...
best wishes
JL
Alexey Tkachenko
Professional
Occupation: Interpreting, Building virtual tours
Friday, October 18th 2013, 9:47am
Concerning differences between hotspots, layers and plugins: hotspots are located inside the panorama and aligned in panoramic coordinates, whereas layers/plugins are located on the screen area and aligned to its width/height and x/y.
What about playing the sound just once, try this code:
playsound(auto,sounds/2dante.mp3|2dante.ogg,1);
value "1" in the end means that the sound must be played just once. If you need it to be played in loops, place "0".
See here for more details:
http://www.krpano.com/plugins/soundinterface/#actions
Regards,
Alexey
jl-krp
Friday, October 18th 2013, 10:03am
Got it, already
Thanks Alex
I actually managed to work that out myself - I must be learning something...
Thanks also for the clear definitions of hotspots etc. very helpful.
JL
Similar threads
