Sie sind nicht angemeldet.
Montag, 15. Oktober 2012, 09:35
Help with HTML5 Object Movies / Custom programming
We are trying to accomplish the following:
  1. HTML5 viewer for object movies -- single res, no zoom
  2. Ability to have hotspots over the object movies
  3. Ability to have two object movies on screen and synced
Krpano does not "automatically support object movies for HTML5" at the moment. Klaus has said "Non-multires, non-zoomable object movies should be already possible by loading the object images manually via layer/plugin elements and toggling their visibility by a modified objectskin.xml code. The current object movies are also just normal flat images that will be 'rotated' by xml codes - see the objectskin.xml for details."
It seems like what we want is possible, with some minor coding modifications, but I have been unable to figure out how to make this work. Can someone please help with this? We will gladly pay you for your time.
-Chris
Montag, 9. Dezember 2013, 12:00
The same
Hello,
I'm representing company in Latvia, that offers object movie solutions for our clients.
We are looking forward to find solution for the same issue.
Ähnliche Themen
