Hallo,
ich habe im Netz ein Beispiel gefunden wo ein Button zum vtourskin die Autorotation hinzugefügt wurde. Aus diesem Beispiel habe ich den Code entnommen und das hat auch gut geklappt. Nur beim iPhone zeigt der Skin dort wo eigentlich der Button für die Rotation sein soll etwas anderes. Das PNG hab ich mal angehängt und hier der Code aus der vtourskin.xml:
<!-- krpano 1.17.pr - Default Virtual Tour Skin -->
<!-- Global Skin settings (can be overridden in the 'outer' xml) -->
<skin_settings bingmaps="false"
bingmaps_key=""
bingmaps_zoombuttons="false"
gyro="true"
thumbs_width="120" thumbs_height="80" thumbs_padding="10" thumbs_crop="0|40|240|160"
thumbs_opened="false"
thumbs_text="false"
thumbs_dragging="true"
thumbs_onhoverscrolling="false"
thumbs_scrollbuttons="false"
thumbs_scrollindicator="false"
thumbs_loop="false"
tooltips_thumbs="false"
tooltips_hotspots="false"
tooltips_mapspots="false"
controlbar_offset="20"
<autorotate enabled="true" waittime="3.0" speed="3" />
<!-- Skin Styles -->
<!-- skin_base - the base skin image -->
<style name="skin_base" url="vtourskin.png" />
<!-- skin_glow - button glowing, if ondown/onup events were needed, then ondown2/onup2 need to be used instead when using this style -->
<style name="skin_glow"
ondown="copy(skin_lockglow,name); skin_buttonglow(get(name)); if(ondown2, ondown2() );"
onover="if(skin_lockglow === null, copy(skin_lockglow,name); skin_buttonglow(get(name),0.3) ); "
onout="if(skin_lockglow === name, ifnot(pressed, skin_buttonglow(null);delete(skin_lockglow); ));"
onup="if(hovering, skin_buttonglow(get(name),0.3), skin_buttonglow(null);delete(skin_lockglow); ); if(onup2, onup2() );"
<!-- skin_thumbtext_style - style/textfield for the (optional, skin_settings.thumbs_text) thumbnails texts -->
<style name="skin_thumbtext_style" url="%SWFPATH%/plugins/textfield.swf" align="bottom" width="100%" autoheight="true" y="5" enabled="false" background="false" border="false" css="text-align:center; color:#fff000; font-family:Arial; font-weight:bold; font-size:10px;" textshadow="1" />
<!-- skin_hotspotstyle - style for the hotspots (note - the onclick event will be overwritten here and can't be set directly at the hotspot! the hotspots need to have a 'linkedscene' attribute to be clickable) -->
<style name="skin_hotspotstyle" url="vtourskin_hotspot.png" scale="0.5" edge="top" oy="0" distorted="false"
tooltip=""
onclick="if(linkedscene, skin_hidetooltips(); tween(scale,0.25,0.5); tween(oy,-20,0.5); tween(alpha,0,0.5); looktohotspot(); loadscene(get(linkedscene),null,MERGE,BLEND(1)); skin_updatescroll(); );"
onloaded="if(skin_settings.tooltips_hotspots, if(linkedscene, copy(tooltip,scene[get(linkedscene)].title); loadstyle(skin_tooltips); ));"
<!-- skin_tooltip - style for the thumb, hotspot and mapspot tooltips -->
<style name="skin_tooltips"
onover="copy(layer[skin_tooltip].html, tooltip);
set(layer[skin_tooltip].visible, true);
tween(layer[skin_tooltip].alpha, 1.0, 0.1);
asyncloop(hovering, copy(layer[skin_tooltip].x,mouse.stagex); copy(layer[skin_tooltip].y,mouse.stagey); );"
onout="tween(layer[skin_tooltip].alpha, 0.0, 0.1, default, set(layer[skin_tooltip].visible,false), copy(layer[skin_tooltip].x,mouse.stagex); copy(layer[skin_tooltip].y,mouse.stagey); );"
<textstyle name="rotation"
font="Arial"
fontsize="12.0"
bold="true"
italic="false"
background="false"
backgroundcolor="0x000000"
border="false"
bordercolor="0x000000"
textcolor="0xFFF000"
alpha="1.0"
blendmode="normal"
effect=""
origin="cursor"
edge="bottom"
textalign="none"
xoffset="0"
yoffset="-10"
showtime="0.1"
fadetime="0.0"
fadeintime="0.0"
noclip="true"
<!-- the tooltip textfield -->
<layer name="skin_tooltip" keep="true"
parent="STAGE"
visible="false" alpha="0" enabled="false"
align="lefttop" edge="bottom" oy="-2" width="200" autoheight="true"
background="false" backgroundcolor="0xFFFFFF" backgroundalpha="1.0"
border="false" bordercolor="0x000000" borderalpha="1.0" borderwidth="1.0" roundedge="0"
shadow="0.0" shadowrange="4.0" shadowangle="45" shadowcolor="0x000000" shadowalpha="1.0"
textshadow="1" textshadowrange="6.0" textshadowangle="90" textshadowcolor="0x000000" textshadowalpha="1.0"
css="text-align:center; color:#FFFFFF; font-family:Arial; font-weight:bold; font-size:16px;"
html=""
<!-- context menu -->
<contextmenu>
<item name="krp" caption="KRPANO" />
<item name="fsc" caption="FULLSCREEN" />
<item name="scm" caption="Change Controlmode" onclick="switch(control.mousetype, 'moveto', 'drag2d');" separator="true" />
<item name="nrm" caption="Normal View" onclick="skin_view_normal();" showif="view.vlookatrange == 180" separator="true" />
<item name="fis" caption="Fisheye View" onclick="skin_view_fisheye();" showif="view.vlookatrange == 180" devices="flash|webgl" />
<item name="ste" caption="Stereographic View" onclick="skin_view_stereographic();" showif="view.vlookatrange == 180" devices="flash|webgl" />
<item name="arc" caption="Architectural View" onclick="skin_view_architectural();" showif="view.vlookatrange == 180" />
<item name="pan" caption="Pannini View" onclick="skin_view_pannini();" showif="view.vlookatrange == 180" devices="flash|webgl" />
<item name="lpv" caption="Little Planet View" onclick="skin_view_littleplanet();" showif="view.vlookatrange == 180" devices="flash|webgl" />
</contextmenu>
<!-- Skin Layout -->
<layer name="skin_scroll_window" type="container" keep="true" align="leftbottom" width="100%" height="100%" x="0" y="60" y_opened="60" y_closed="-2" maskchildren="true">
<layer name="skin_scroll_layer" type="container" align="leftbottom" width="100%" height="100%" x="0" y="-100%">
<layer name="skin_topborder" style="skin_base" crop="2|0|60|12" align="topleft" edge="bottomleft" width="100%" height="12" x="0" y="0" enabled="false" />
<layer name="skin_title" url="%SWFPATH%/plugins/textfield.swf" align="lefttop" edge="leftbottom" width="95%" height="32" autoheight="true" x="5" y="-3" zorder="4" enabled="false" background="false" border="false" css="text-align:left; color:#FFFFFF; font-family:Arial; font-weight:bold; font-size:16px;" textshadow="1" visible="false" />
<layer name="skin_scroll_container" type="container" bgcolor="0x000000" bgalpha="0.5" align="lefttop" width="100%" height="100%" x="0" y="0" maskchildren="true">
<layer name="skin_thumbs_container" type="container" align="lefttop" width="100%" height="100%" visible="false">
<layer name="skin_thumbs_scrollleft" style="skin_base|skin_glow" crop="0|64|64|64" align="lefttop" edge="left" x="5" y="50" scale="0.5" zorder="2" alpha="1.0" ondown2="asyncloop(pressed, layer[skin_thumbs].scrollby(+2,0));" visible="false" />
<layer name="skin_thumbs_scrollright" style="skin_base|skin_glow" crop="64|64|64|64" align="righttop" edge="right" x="5" y="50" scale="0.5" zorder="2" alpha="1.0" ondown2="asyncloop(pressed, layer[skin_thumbs].scrollby(-2,0));" visible="false" />
<layer name="skin_thumbs_scrollindicator" type="container" bgcolor="0xFFFFFF" bgalpha="0.25" align="lefttop" width="0" y="100" height="4" visible="false" enabled="false" />
<layer name="skin_thumbs" state="closed" url="%SWFPATH%/plugins/scrollarea.swf" alturl="%SWFPATH%/plugins/scrollarea.js" direction="h" align="top" width="100%" height="100" zorder="1" onloaded="skin_updatescroll();" onscroll="skin_updatethumbscroll();" />
</layer>
<layer name="skin_map" state="closed" url="" flash_url="%SWFPATH%/plugins/bingmaps.swf" html5_url="%SWFPATH%/plugins/bingmaps.js" visible="false" align="lefttop" width="100%" height="50%" x="0" y="0" zorder="1" lat="" lng="" zoom="10" bgalpha="0" maptype="hybrid" onmapready="skin_addmapspots();">
<maptypecontrol visible="true" align="righttop" x="5" y="5" buttonalign="v" />
<radar visible="false" headingoffset="0" />
<spotstyle name="DEFAULT" url="vtourskin_mapspot.png" activeurl="vtourskin_mapspotactive.png" edge="bottom" x="-5" y="-8" scale="0.5" />
<layer name="skin_map_zoom_in" style="skin_base" visible="false" crop="9|512|46|64" align="right" x="0" y="-40" zorder="2" ondown="layer[skin_map].zoomin(); skin_buttonglow(get(name));" onup="skin_buttonglow(null);" />
<layer name="skin_map_zoom_out" style="skin_base" visible="false" crop="73|512|46|64" align="right" x="0" y="+40" zorder="2" ondown="layer[skin_map].zoomout(); skin_buttonglow(get(name));" onup="skin_buttonglow(null);" />
</layer>
</layer>
</layer>
</layer>
<layer name="skin_control_bar" keep="true" type="container" bgcolor="0x000000" bgalpha="0.5" align="leftbottom" width="100%" height="40" x="0" y="20" y_opened="20" y_closed="-42" zorder="3">
<layer name="skin_btmborder" style="skin_base" crop="2|52|60|12" align="bottomleft" edge="topleft" width="100%" height="12" x="0" y="0" enabled="false" />
<layer name="skin_btn_prev" style="skin_base|skin_glow" crop="0|64|64|64" align="left" x="5" y="0" scale="0.5" alpha="0.5" onclick="if(skin_settings.thumbs_loop, skin_nextscene_loop(-1), skin_nextscene(-1) );" />
<layer name="skin_btn_next" style="skin_base|skin_glow" crop="64|64|64|64" align="right" x="5" y="0" scale="0.5" alpha="0.5" onclick="if(skin_settings.thumbs_loop, skin_nextscene_loop(+1), skin_nextscene(+1) );" />
<layer name="skin_btn_thumbs" style="skin_base|skin_glow" crop="0|128|64|64" align="leftbottom" x="50" y="4" scale="0.5" ondown2="skin_showmap(false); skin_showthumbs();" />
<layer name="skin_btn_map" style="skin_base|skin_glow" crop="64|128|64|64" align="leftbottom" x="90" y="4" scale="0.5" ondown2="skin_showthumbs(false); skin_showmap();" visible="false" />
<layer name="skin_btn_lt" style="skin_base|skin_glow" crop="0|192|64|64" align="bottom" x="-100" y="4" scale="0.5" ondown2="set(hlookat_moveforce,-1);" onup2="set(hlookat_moveforce,0);" />
<layer name="skin_btn_rt" style="skin_base|skin_glow" crop="64|192|64|64" align="bottom" x="-60" y="4" scale="0.5" ondown2="set(hlookat_moveforce,+1);" onup2="set(hlookat_moveforce,0);" />
<layer name="skin_btn_up" style="skin_base|skin_glow" crop="0|256|64|64" align="bottom" x="-20" y="4" scale="0.5" ondown2="set(vlookat_moveforce,-1);" onup2="set(vlookat_moveforce,0);" />
<layer name="skin_btn_dn" style="skin_base|skin_glow" crop="64|256|64|64" align="bottom" x="+20" y="4" scale="0.5" ondown2="set(vlookat_moveforce,+1);" onup2="set(vlookat_moveforce,0);" />
<layer name="skin_btn_in" style="skin_base|skin_glow" crop="0|320|64|64" align="bottom" x="+60" y="4" scale="0.5" ondown2="set(fov_moveforce,-1);" onup2="set(fov_moveforce,0);" />
<layer name="skin_btn_ou" style="skin_base|skin_glow" crop="64|320|64|64" align="bottom" x="+100" y="4" scale="0.5" ondown2="set(fov_moveforce,+1);" onup2="set(fov_moveforce,0);" />
<layer name="skin_btn_gyro" style="skin_base|skin_glow" crop="0|384|64|64" align="bottom" x="140" y="4" scale="0.5" ondown2="skin_showmap(false);" onclick="switch(plugin[skin_gyro].enabled);" visible="false" devices="html5" />
<layer name="skin_btn_fs" style="skin_base|skin_glow" crop="0|576|64|64" align="bottom" x="140" y="4" scale="0.5" onclick="switch(fullscreen);" devices="fullscreensupport" />
<layer name="skin_btn_hide" style="skin_base|skin_glow" crop="0|448|64|64" align="right" x="50" y="0" scale="0.5" onclick="skin_hideskin()" />
<layer name="skin_btn_show" style="skin_base|skin_glow" crop="64|448|64|64" align="right" x="5" y="-36" scale="0.5" alpha="0" visible="false" onclick="skin_showskin()" />
<layer name="roton" style="skin_base|skin_glow" crop="0|640|64|64" align="bottom" x="180" y="2" scale="0.5" alpha="1" onhover="showtext(Autorotation aus, rotation);" onclick="action(off);" visible="true" />
<layer name="rotoff" style="skin_base|skin_glow" crop="64|640|64|64" align="bottom" x="180" y="2" scale="0.5" alpha="1" onhover="showtext(Autorotation an, rotation);" onclick="action(on);" visible="false" />
</layer>
<layer name="skin_loadingtext" keep="true" url="%SWFPATH%/plugins/textfield.swf" align="center" x="5" y="-5" html="loading..." visible="false" autoheight="true" background="false" border="false" enabled="false" css="text-align:center; color:#FFFFFF; font-family:Arial; font-weight:bold; font-size:22px; font-style:italic;" textshadow="2" />
<layer name="skin_buttonglow" keep="true" style="skin_base" crop="64|384|64|64" align="center" x="0" y="1" alpha="0.0" visible="false" enabled="false" />
<layer name="skin_thumbborder" keep="true" url="vtourskin_thumbborder.png" visible="false" enabled="false" align="lefttop" scale="0.5" ox="-2" oy="-2" />
<layer name="skin_logo" keep="true" url="" align="righttop" x="5" y="5" capture="false" accuracy="1" state="small" onclick="if(state == 'small', skin_openlogo(); , skin_closelogo('now'); opened_onclick(); );" />
<plugin name="skin_gyro" keep="true" url="" html5_url="%SWFPATH%/plugins/gyro.js" devices="html5+!firefox+!android" enabled="false" camroll="true" friction="0" velastic="0" onavailable="if(device.fullscreensupport, if(device.mobile,add(layer[skin_btn_gyro].x,40),add(layer[skin_btn_gyro].x,20));); set(layer[skin_btn_gyro].visible,true);" />
<!-- Skin Events -->
<events name="skin_events" keep="true"
onxmlcomplete="set(events[skin_events].onxmlcomplete,null); skin_startup();"
onnewpano="skin_showloading(true); skin_update_scene_infos();"
onremovepano="skin_showloading(true);"
onloadcomplete="skin_showloading(false);"
onresize="skin_onresize();"
<events name="skin_events" devices="fullscreensupport"
onenterfullscreen="set(layer[skin_btn_fs].crop, '64|576|64|64');"
onexitfullscreen="set(layer[skin_btn_fs].crop, '0|576|64|64');"
<!-- Alternative small screen layout for mobile devices (override/extend settings) -->
<krpano devices="mobile">
<layer name="skin_scroll_window" y="64" y_opened="64" y_closed="-4">
<layer name="skin_scroll_layer">
<layer name="skin_topborder" height="24" />
<layer name="skin_title" css="text-align:left; color:#FFFFFF; font-family:Arial; font-weight:bold; font-size:26px;" />
<layer name="skin_scroll_container">
<layer name="skin_thumbs_container">
<layer name="skin_thumbs_scrollleft" scale="1" />
<layer name="skin_thumbs_scrollright" scale="1" />
<layer name="skin_thumbs_scrollindicator" height="6" />
<layer name="skin_thumbs" height="200" />
</layer>
<layer name="skin_map">
<maptypecontrol scale="1.5" />
</layer>
</layer>
</layer>
</layer>
<layer name="skin_control_bar" height="64" y="0" y_opened="0" y_closed="-68">
<layer name="skin_btmborder" visible="false" />
<layer name="skin_btn_prev" scale="1" y="0" align="left" x="0" />
<layer name="skin_btn_next" scale="1" y="0" align="left" x="80" />
<layer name="skin_btn_thumbs" scale="1" y="0" align="left" x="160" />
<layer name="skin_btn_map" scale="1" y="0" align="left" x="240" />
<layer name="skin_btn_lt" visible="false" />
<layer name="skin_btn_rt" visible="false" />
<layer name="skin_btn_up" visible="false" />
<layer name="skin_btn_dn" visible="false" />
<layer name="skin_btn_in" visible="false" />
<layer name="skin_btn_ou" visible="false" />
<layer name="skin_btn_gyro" scale="1" y="0" align="left" x="320" />
<layer name="skin_btn_fs" scale="1" y="0" align="left" x="320" />
<layer name="roton" scale="1" y="2" align="left" x="400" visible="true" />
<layer name="rotoff" scale="1" y="2" align="left" x="400" visible="false" />
<layer name="skin_btn_hide" scale="1" x="5" />
<layer name="skin_btn_show" scale="1" x="0" y="-58" />
</layer>
<layer name="skin_loadingtext" css="text-align:center; color:#FFFFFF; font-family:Arial; font-weight:bold; font-style:italic; font-size:44px;" />
<layer name="skin_buttonglow" scale="2.0" />
<layer name="skin_thumbborder" scale="1" />
<style name="skin_thumbtext_style" css="text-align:center; color:#FFF000; font-family:Arial; font-weight:bold; font-size:20px;" />
<!-- Additional layout changes for Android Flashplayer Mobiles - different fullscreen button layout, zooming buttons, smaller loading text size -->
<krpano devices="mobile+android+flash">
<layer name="skin_scroll_window">
<layer name="skin_title" width="100%" css="text-align:left; color:#FFFFFF; font-family:Arial; font-weight:bold; font-size:20px;" />
</layer>
</layer>
<layer name="skin_control_bar">
<layer name="skin_btn_fs" scale="1" align="right" x="70" y="0" />
<layer name="skin_btn_show" x="-10" y="-40" />
</layer>
<layer name="skin_loadingtext" css="text-align:center; color:#FFFFFF; font-family:Arial; font-weight:bold; font-style:italic; font-size:30px;" />
<layer name="skin_androidzoom_buttons" keep="true" type="container" width="60" height="160" align="right">
<layer name="skin_androidzoom_in" style="skin_base" effect="glow(0,0.5);" crop="9|512|46|64" align="center" x="0" y="-40" zorder="2" ondown="if(layer[skin_map].state == 'closed',set(fov_moveforce,-1));skin_buttonglow(get(name));" onup="if(layer[skin_map].state == 'closed',set(fov_moveforce,0),layer[skin_map].zoomin());skin_buttonglow(null);" />
<layer name="skin_androidzoom_out" style="skin_base" effect="glow(0,0.5);" crop="73|512|46|64" align="center" x="0" y="+40" zorder="2" ondown="if(layer[skin_map].state == 'closed',set(fov_moveforce,+1));skin_buttonglow(get(name));" onup="if(layer[skin_map].state == 'closed',set(fov_moveforce,0),layer[skin_map].zoomout());skin_buttonglow(null);" />
</layer>
<!-- Skin Actions -->
<action name="on">
set(plugin[roton].visible, true);
set(plugin[rotoff].visible, false);
switch(autorotate.enabled)
<action name="off">
set(plugin[rotoff].visible, true);
set(plugin[roton].visible, false);
<action name="skin_startup">
if(device.mobile == false,
copy(layer[skin_control_bar].y, skin_settings.controlbar_offset);
copy(layer[skin_control_bar].y_opened, skin_settings.controlbar_offset);
add(layer[skin_scroll_window].y, layer[skin_control_bar].height, layer[skin_control_bar].y);
add(layer[skin_scroll_window].y_opened, layer[skin_control_bar].height, layer[skin_control_bar].y_opened);
if(skin_settings.thumbs_opened, set(layer[skin_thumbs].state,'opened'); set(layer[skin_thumbs_container].visible,true); );
copy(layer[skin_thumbs].draggable, skin_settings.thumbs_dragging);
if(skin_settings.thumbs_onhoverscrolling,
ifnot(device.touchdevice, set(layer[skin_thumbs].draggable, false));
set(layer[skin_thumbs].onhover_autoscrolling, true);
if(device.android, if(device.flash, set(skin_settings.bingmaps_zoombuttons, false); ));
skin_addthumbs();
skin_onresize();
copy(usegyro, skin_settings.gyro);
if(device.desktop, set(usegyro, false));
if(device.flash, set(usegyro, false));
if(usegyro, copy(plugin[skin_gyro].url, plugin[skin_gyro].html5_url); );
if(skin_settings.bingmaps == true,
set(layer[skin_btn_map].visible, true);
copy(layer[skin_map].key, skin_settings.bingmaps_key);
copy(layer[skin_map_zoom_in].visible, skin_settings.bingmaps_zoombuttons);
copy(layer[skin_map_zoom_out].visible, skin_settings.bingmaps_zoombuttons);
if(device.flash, copy(layer[skin_map].url, layer[skin_map].flash_url), copy(layer[skin_map].url, layer[skin_map].html5_url) );
if(device.mobile, copy(layer[skin_btn_gyro].x, layer[skin_btn_map].x) );
<action name="skin_addthumbs">
copy(thumbwidth, skin_settings.thumbs_width);
copy(thumbheight, skin_settings.thumbs_height);
copy(thumbpadding, skin_settings.thumbs_padding);
copy(thumbcrop, skin_settings.thumbs_crop);
if(device.mobile,
mul(thumbwidth,2);
mul(thumbheight,2);
mul(thumbpadding,2);
add(thumbxoffset, thumbwidth, thumbpadding);
mul(thumbxcenter, thumbxoffset, 0.5);
mul(thumbbarwidth, thumbxoffset, scene.count);
add(thumbbarwidth, thumbpadding);
add(thumbbarheight, thumbpadding, thumbheight);
add(thumbbarheight, thumbpadding);
if (skin_settings.thumbs_scrollindicator,
copy(layer[skin_thumbs_scrollindicator].y, thumbbarheight);
add(thumbbarheight, layer[skin_thumbs_scrollindicator].height);
copy(layer[skin_thumbs].height, thumbbarheight);
copy(layer[skin_thumbs].width, thumbbarwidth);
mul(halfheight, thumbbarheight, 0.5);
copy(layer[skin_thumbs_scrollleft].y, halfheight);
copy(layer[skin_thumbs_scrollright].y, halfheight);
for(set(i,0), i LT scene.count, inc(i),
txtadd(thumbname,'skin_thumb_',get(i));
addlayer(get(thumbname));
copy(layer[get(thumbname)].url, scene[get(i)].thumburl);
set(layer[get(thumbname)].keep, true);
set(layer[get(thumbname)].parent, 'skin_thumbs');
set(layer[get(thumbname)].align, lefttop);
copy(layer[get(thumbname)].crop, thumbcrop);
copy(layer[get(thumbname)].width, thumbwidth);
copy(layer[get(thumbname)].height, thumbheight);
mul(thumbx, i, thumbxoffset);
add(thumbx, thumbpadding);
copy(layer[get(thumbname)].x, thumbx);
copy(layer[get(thumbname)].y, thumbpadding);
add(scene[get(i)].thumbx, thumbx, thumbxcenter);
copy(scene[get(i)].thumby, thumbpadding);
set(layer[get(thumbname)].linkedscene, get(scene[get(i)].name) );
set(layer[get(thumbname)].onclick, copy(layer[skin_thumbborder].parent, name); loadscene(get(linkedscene), null, MERGE, BLEND(0.5)); );
if(skin_settings.tooltips_thumbs,
set(layer[get(thumbname)].tooltip, get(scene[get(i)].title) );
layer[get(thumbname)].loadstyle(skin_tooltips);
if(skin_settings.thumbs_text,
txtadd(thumbtext, 'skin_thumbtext_', get(i));
addlayer(get(thumbtext));
layer[get(thumbtext)].loadstyle(skin_thumbtext_style);
set(layer[get(thumbtext)].keep, true);
set(layer[get(thumbtext)].parent, get(thumbname));
set(layer[get(thumbtext)].html, get(scene[get(i)].title));
<action name="skin_addmapspots">
if(scene[get(i)].lat,
txtadd(spotname, 'spot', get(i));
txtadd(spotclickevent, 'skin_hidetooltips(); activatespot(',get(spotname),'); loadscene(', get(scene[get(i)].name), ',null,MERGE,BLEND(1)); skin_updatescroll(); delayedcall(0.5,skin_showmap(false));');
copy(scene[get(i)].mapspotname, spotname);
addspot(get(spotname), get(scene[get(i)].lat), get(scene[get(i)].lng), get(scene[get(i)].heading), false, get(spotclickevent), null);
if(skin_settings.tooltips_mapspots,
set(layer[skin_map].spot[get(spotname)].tooltip, get(scene[get(i)].title) );
txtadd(layer[skin_map].spot[get(spotname)].onover, 'set(hovering,true);', get(style[skin_tooltips].onover) );
txtadd(layer[skin_map].spot[get(spotname)].onout, 'set(hovering,false);', get(style[skin_tooltips].onout) );
activatespot(spot0);
<action name="skin_onresize">
mul(mh, stageheight, -1);
if(layer[skin_thumbs].state == 'opened', add(mh,layer[skin_thumbs].height); );
if(layer[skin_map].state == 'opened', sub(hh,stageheight,skin_settings.controlbar_offset); sub(hh,layer[skin_control_bar].height); sub(hh,32); copy(layer[skin_map].height, hh); add(mh,hh); );
set(layer[skin_scroll_layer].y, get(mh));
ifnot(device.mobile, if(stagewidth LT 480, skin_showbuttons(false), skin_showbuttons(true)); );
<action name="skin_showbuttons">
set(layer[skin_btn_lt].visible, %1);
set(layer[skin_btn_rt].visible, %1);
set(layer[skin_btn_up].visible, %1);
set(layer[skin_btn_dn].visible, %1);
set(layer[skin_btn_in].visible, %1);
set(layer[skin_btn_ou].visible, %1);
if(%1 == true,
if(plugin[skin_gyro].available == true, set(layer[skin_btn_gyro].visible, %1) );
if(device.fullscreensupport, set(layer[skin_btn_fs].visible, %1) );
set(layer[skin_btn_gyro].visible, %1);
set(layer[skin_btn_fs].visible, %1);
<action name="skin_updatescroll">
if(layer[skin_thumbs].loaded,
set(cursceneindex, 0);
if(xml.scene, copy(cursceneindex, scene[get(xml.scene)].index));
layer[skin_thumbs].setcenter(get(scene[get(cursceneindex)].thumbx), get(scene[get(cursceneindex)].thumby));
<action name="skin_updatethumbscroll">
copy(padding,skin_settings.thumbs_padding);
if(device.mobile, mul(padding,2));
if(skin_settings.thumbs_scrollbuttons,
if(loverflow GT 0, set(layer[skin_thumbs_scrollleft].visible,true), set(layer[skin_thumbs_scrollleft].visible,false) );
if(roverflow GT 0, set(layer[skin_thumbs_scrollright].visible,true), set(layer[skin_thumbs_scrollright].visible,false) );
if(skin_settings.thumbs_scrollindicator,
if(woverflow GT 0,
set(layer[skin_thumbs_scrollindicator].visible,true);
sub(iw,pixelwidth,woverflow);
div(pw,iw,pixelwidth);
div(px,loverflow,woverflow);
mul(pw,iw);
copy(layer[skin_thumbs_scrollindicator].width,pw);
sub(iw,pw);
sub(iw,padding);
sub(iw,padding);
mul(px,iw);
add(px,padding);
copy(layer[skin_thumbs_scrollindicator].x,px);
set(layer[skin_thumbs_scrollindicator].visible,false);
<action name="skin_update_scene_infos">
if(xml.scene !== null,
if(scene[get(xml.scene)].index GE 0,
if(title, txtadd(layer[skin_title].html, get(title), ' - ', get(scene[get(xml.scene)].title) ); , copy(layer[skin_title].html, scene[get(xml.scene)].title ); );
delayedcall(0.1, set(layer[skin_title].visible,true) );
if(skin_settings.thumbs_loop == false,
if(scene[get(xml.scene)].index GT 0,
set(layer[skin_btn_prev].enabled, true);
set(layer[skin_btn_prev].alpha, 1.0);
set(layer[skin_btn_prev].enabled, false);
set(layer[skin_btn_prev].alpha, 0.3);
sub(lastsceneindex, scene.count, 1);
if(scene[get(xml.scene)].index LT lastsceneindex,
set(layer[skin_btn_next].enabled, true);
set(layer[skin_btn_next].alpha, 1.0);
set(layer[skin_btn_next].enabled, false);
set(layer[skin_btn_next].alpha, 0.3);
if(scene.count GT 1,
txtadd(layer[skin_thumbborder].parent, 'skin_thumb_', get(scene[get(xml.scene)].index));
set(layer[skin_thumbborder].visible, true);
if(scene[get(xml.scene)].mapspotname,
layer[skin_map].activatespot(get(scene[get(xml.scene)].mapspotname));
layer[skin_map].pantospot(get(scene[get(xml.scene)].mapspotname));
<action name="skin_nextscene">
add(newsceneindex, scene[get(xml.scene)].index, %1);
if(newsceneindex GE 0,
if(newsceneindex LT scene.count,
txtadd(layer[skin_thumbborder].parent, 'skin_thumb_', get(newsceneindex));
layer[skin_thumbs].scrolltocenter(get(scene[get(newsceneindex)].thumbx), get(scene[get(newsceneindex)].thumby));
loadscene(get(scene[get(newsceneindex)].name), null, MERGE, BLEND(0.5));
<action name="skin_nextscene_loop">
if(newsceneindex LT 0, copy(newsceneindex,lastsceneindex));
if(newsceneindex GT lastsceneindex, set(newsceneindex,0));
<action name="skin_showloading">
set(layer[skin_loadingtext].visible, %1);
<action name="skin_hidetooltips">
set(layer[skin_tooltip].alpha,0.0);
set(layer[skin_tooltip].visible,false);
<action name="skin_buttonglow">
if(%1 != null,
set(strength,0.7);
if(%2 != null, set(strength,%2));
set(layer[skin_buttonglow].parent, %1);
set(layer[skin_buttonglow].visible, true);
tween(layer[skin_buttonglow].alpha, get(strength), 0.07);
tween(layer[skin_buttonglow].alpha, 0.0, 0.1, default, set(layer[skin_buttonglow].parent, null); set(layer[skin_buttonglow].visible, false); );
<action name="skin_hideskin">
if(layer[skin_map].state != 'closed', skin_showmap(false); wait(0.4); );
if(layer[skin_thumbs].state != 'closed', skin_showthumbs(false); wait(0.25); );
tween(layer[skin_scroll_window].y, get(layer[skin_scroll_window].y_closed), 0.5, easeOutQuint);
tween(layer[skin_control_bar].y, get(layer[skin_control_bar].y_closed), 0.5, easeOutQuint);
set(layer[skin_btn_show].visible,true);
tween(layer[skin_btn_show].alpha, 1, 0.25, easeOutQuint);
<action name="skin_showskin">
tween(layer[skin_scroll_window].y, get(layer[skin_scroll_window].y_opened), 0.5, easeOutQuint);
tween(layer[skin_control_bar].y, get(layer[skin_control_bar].y_opened), 0.5, easeOutQuint);
set(layer[skin_btn_show].visible,false);
tween(layer[skin_btn_show].alpha,0,0);
<action name="skin_showthumbs">
if(%1 == null, if(layer[skin_thumbs].state == 'closed', set(show,true), set(show,false)); , set(show,%1); );
mul(mh, layer[skin_scroll_layer].pixelheight, -1);
if(layer[skin_scroll_layer].y == -100%, copy(layer[skin_scroll_layer].y,mh));
if(show,
set(layer[skin_thumbs].state, 'opened');
add(mh, layer[skin_thumbs].height);
tween(layer[skin_scroll_layer].y, get(mh), 0.5, easeOutQuint);
set(layer[skin_thumbs_container].visible, true);
tween(layer[skin_thumbs_container].alpha, 1.0, 0.25);
tween(layer[skin_map].alpha, 0.0, 0.25, default, set(layer[skin_map].visible,false));
set(layer[skin_thumbs].state, 'closed');
tween(layer[skin_scroll_layer].y, get(mh), 0.5, easeOutQuint, set(layer[skin_thumbs_container].visible, false););
<action name="skin_showmap">
if(%1 == null, if(layer[skin_map].state == 'closed', set(show,true), set(show,false)); , set(show,%1); );
if(show,
tween(layer[skin_logo].alpha, 0.0, 0.25, default, set(layer[skin_logo].visible,false));
tween(layer[skin_thumbs_container].alpha, 0.0, 0.25, default, set(layer[skin_thumbs_container].visible,false));
set(layer[skin_map].visible, true);
tween(layer[skin_map].alpha, 1.0, 0.25);
set(layer[skin_map].state, 'opened');
sub(hh,32);
add(mh,hh);
set(layer[skin_map].state, 'closed');
set(layer[skin_logo].visible, true); tween(layer[skin_logo].alpha, 1.0, 0.25);
tween(layer[skin_scroll_layer].y, get(mh), 0.5, easeOutQuint, set(layer[skin_map].visible,false) );
<action name="skin_openlogo">
if(layer[skin_logo].state == 'small',
set(layer[skin_logo].state, 'opening');
copy(backup_logo_align, layer[skin_logo].align);
copy(backup_logo_x, layer[skin_logo].x);
copy(backup_logo_y, layer[skin_logo].y);
copy(backup_logo_scale, layer[skin_logo].scale);
layer[skin_logo].changeorigin(center);
tween(layer[skin_logo].x, 0, 0.5, easeOutQuint);
tween(layer[skin_logo].y, 0, 0.5, easeOutQuint);
tween(layer[skin_logo].scale, 1, 0.5, easeOutQuint);
delayedcall(0.5, set(layer[skin_logo].state, 'opened') );
delayedcall(0, set(events[skin_events].onmouseup, delayedcall(0, skin_closelogo()) ) );
<action name="skin_closelogo">
if(layer[skin_logo].state == 'opened',
set(layer[skin_logo].state, 'closing');
layer[skin_logo].changeorigin(get(backup_logo_align));
if(%1 == 'now',
stoptween(layer[skin_logo].x, layer[skin_logo].y, layer[skin_logo].scale);
copy(layer[skin_logo].x, backup_logo_x);
copy(layer[skin_logo].y, backup_logo_y);
copy(layer[skin_logo].scale, backup_logo_scale);
set(layer[skin_logo].state, 'small');
tween(layer[skin_logo].x, get(backup_logo_x), 0.5, easeOutQuint);
tween(layer[skin_logo].y, get(backup_logo_y), 0.5, easeOutQuint);
tween(layer[skin_logo].scale, get(backup_logo_scale), 0.5, easeOutQuint);
delayedcall(0.5, set(layer[skin_logo].state, 'small'));
set(events[skin_events].onmouseup, null);
<action name="skin_view_normal">
tween(view.fovmax, 150.0, distance(179, 1.00), easeoutquad);
tween(view.architectural, 0.0, distance(1.0, 0.45), easeoutquad);
tween(view.fisheye, 0.0, distance(1.0, 0.45), easeoutquad, set(view.stereographic,false); if(view.pannini, set(view.pannini,false); delayedcall(0,updateobject(true,true)); ); );
set(centerview,false);
if(view.architectural LT 0.2,
if(view.vlookat LT -60, set(centerview,true));
if(view.vlookat GT +60, set(centerview,true));
if(centerview, tween(view.vlookat, 0.0, distance(90, 0.45), easeoutquad));
if(view.fov GE 150, tween(view.fov, 100.0, distance(50, 0.45), easeoutquad));
<action name="skin_view_fisheye">
tween(view.architectural, 0.0, distance(1.0, 0.30), easeoutquad);
tween(view.fisheye, 0.0 ,distance(1.0, 0.30), easeoutquad, set(view.stereographic,false); if(view.pannini, set(view.pannini,false); delayedcall(0,updateobject(true,true)); ); set(view.fovmax,179); tween(view.fisheye, 0.35, distance(1.0,1.25)); );
<action name="skin_view_architectural">
tween(view.architectural, 1.0, distance(1.0, 0.45), easeoutquad);
<action name="skin_view_stereographic">
tween(view.architectural, 0.0, 0.25);
set(backtonormalfirst,false);
if(view.pannini == true, set(backtonormalfirst,true) );
if(view.stereographic == false, set(backtonormalfirst,true) );
if(backtonormalfirst, tween(view.fisheye, 0.0 ,distance(1.0, 0.25), easeoutquad, WAIT); );
set(view.stereographic, true);
set(view.fovmax, 150);
tween(view.fisheye, 1.0, distance(1.0, 0.75), easeoutquad);
<action name="skin_view_pannini">
if(view.pannini == false, set(backtonormalfirst,true) );
set(view.pannini, true);
<action name="skin_view_littleplanet">
tween(view.vlookat, 90, distance(179, 1.50), easeoutquad);
tween(view.fov, 150, distance(179, 0.75), easeoutquad);
Display More
Warum zeigt das iPhone nicht den richtigen Teil aus der PNG an?
Gruß Tobias
Das Beispiel ist von hier: http://www.panorama-community.de/wbb/index.php?…78400#post78400
