olihar
Trainee
  • "olihar" started this thread
Occupation: Interaction Designer
Thursday, March 27th 2014, 4:28pm
Change from Spherical to Flat
I had on my old site a button that changed spherical images to flat images if people wanted to see them like so, (For example to see how they would print) This was a long time ago and when KrPano was flash only.
Now however HTML5 is the way to go. So I ask, anyone have an idea if something like this would be possible to get working in HTML5 and to work on all devices.
VR view to Flat and back to VR if one would want to do so.
I am talking tiled images here of course.
Sage
Thursday, March 27th 2014, 7:08pm
I had the same question a while ago and the answer was no.
Flash only.
You could load another scene though where that pano is as a flat one i suppose.
Tuur *thumbsup*
http://www.virtualtuur.com
Skype:studiotuur
This post has been edited 1 times, last edit by "Tuur" (Mar 27th 2014, 7:55pm)
Friday, March 28th 2014, 9:22am
in Flash this was possible because a spherical pano and a flat pano were basically the same image, only with different geometry and blending between these geometries (flat and sphere) was possible.
But in HTML5 there are currently only cubes and flat panos, and there such isn't possible. And many HTML5 systems (e.g. iOS) are only supporting CSS3D, there something like spherical aren't possible at all with good quality and performance.
olihar
Trainee
Friday, March 28th 2014, 1:51pm
So indeed only way is to have a second tileset with a flat image.
olihar
Trainee
Friday, March 28th 2014, 4:29pm
Then anyone have a suggestion to create generic button to change between these 2 images, for example if I want to use the same theme file for all sets like this. Like I currently do, Use 1 theme file for spherical and another for flat.
olihar
Trainee
Monday, March 31st 2014, 4:30pm
So I dont really care if I would need to have 2 tile-sets online, but what I care about is an easy way to change between them, and as well good way to create both sets at the same time with KrPano tools.
For example its a simple command to change between folder and folder_flat inside the same scene.
Any suggestion Klaus?
Sage
Monday, March 31st 2014, 8:18pm
Throw the pic on the normal droplet and on the multires droplet ( set flat)
Then you have two scenes and two tile sets.
( just changing the folder makes no sence at all)
Switch between the scenes any way you want.
Tuur *thumbsup*
Skype:studiotuur
olihar
Trainee
Thursday, April 3rd 2014, 4:52pm
Tuur *thumbsup*
What I am getting at is to make it easier, I know I can have 2 thumbnails to click but thats not what I am looking for, What I am looking for is if pano is leaded called 001 I would like to have a button that would then load 001_flat
Or load xxx_flat so it would work with any image I put that is spherical it would just be another folder with flat tiles. and have different view setting. So I could put that button into my skin and it would work with all images.
Sage
Thursday, April 3rd 2014, 5:00pm
i'm not talking about 2 thumbnails, but you need 2 scenes or 2 xml's to do that!
just because the image syntax is fully different, and some more..
Tuur *thumbsup*
Skype:studiotuur
olihar
Trainee
Friday, May 9th 2014, 4:36pm
So maybe someone has a suggestion for a solution that goes something like this.
Scene loaded and its Spherical image and its named 001_sph
Then have a button that says, change to a scene called 001_Flat so it will always go to a scene called the same as the spherical one _sph but loads the _flat scene instead, then when its in flat view the button changes and it works the other way around and loads the 001_sph scene.
This would be pretty easy if there is just 1 panorama then you can just use next and prev button, but if its a virtual tour one would like to have such feature automatically added and working always like stated above.
And of course, when changing to a flat image, Gyro should be disabled and then re-enabled when changing back to Spherical.
This post has been edited 1 times, last edit by "olihar" (May 10th 2014, 2:34pm)
