Hi
I've upgraded to the latest version of krpano from the 1.0.8.15 version ... imagine my shock when nothing was loading in HTML5 because all the files i use (tiles and images) are on Amazon.
Ok so after a few hours of cursing and trial and error my conclusion is HTML5 cors option only works with OFF
As you might already know the buckets on amazon have the option to set up "CORS Configuration" as they call it ... it uses an xml that defines the response headers .... here are my settings:
<?xml version="1.0" encoding="UTF-8"?>
<CORSConfiguration xmlns="http://s3.amazonaws.com/doc/2006-03-01/">
<CORSRule>
<AllowedOrigin>*</AllowedOrigin>
<AllowedMethod>GET</AllowedMethod>
</CORSRule>
</CORSConfiguration>
as you might expected it does not work. so how should the krpano security tag look like to only allow GET requests to my bucket?
thanks,
Rares
