hi, i would like to know if someone has problema with new krpano version becouse in my virtual tour there is a flashing yellow light when loading new pano, as show in this picture #mce_temp_url#
This happens only with virtual tour online. Same files offline work fine.
What's may be?
Flashing a yellow light when loading new pano issue
that's related to the current WebGL rendering and the background color (or the page color behind the pano when using a transparent background color).
Change the webpage background color to black (as its by default) to avoid that behavior.
The problem itself will be fixed in the version 1.19.
i notice that i have problem on safari:
- on windows there isn't flashing problem (work online and local);
- on mac there is the flashing problem (only online) and the navigation isn't fluid (online and local).why in local there in's flshing webgl problem?
Are you really sure that HTML5+WebGL is in use and not HTML5+CSS3D or Flash?!
The problem itself is known and as I had described it above.
Change the background color to black and it will work!Best regards,
Thanks, i used more dark bacground color to fix it. In local ambient start flash and i haven't problem. Great Klaus
