Friday, February 20th 2015, 9:41am
set url.flash
I'm using the addhotspot command to create a hotspot but setting the flash URL using the Set() command doesn't seem to work with this variable.
set(hotspot[video].url.flash, %SWFPATH%/Engine/plugins/videoplayer.swf);
I imagine this is because there Is a dot in the middle of the name of the variable and the set() command only recognises what comes after the first dot.
As I'm creating a large number of video hotspots an action is necessary to create them. Does anyone know of a workaround for achieving this?
Friday, February 20th 2015, 11:37am
that '.flash' is a special filter for the static xml parsing.
See here for details:
http://krpano.com/docu/xml/#devicechecksforattributes
That will be only parsed and resolved when parsing the xml attributes during loading. When the 'devices attribute' is matching the current device, then this xml attribute will be set and when not, it will be skipped.
When using dynamic actions code, it would be necessary to check the device manually, e.g. this way:
if(device.flash, set(hotspot[video].url, %SWFPATH%/Engine/plugins/videoplayer.swf));
if(device.html5, set(hotspot[video].url, %SWFPATH%/Engine/plugins/videoplayer.js));
Friday, February 20th 2015, 1:29pm
Thanks Klaus,
That worked like a dream!
