Monday, April 13th 2015, 11:33am
'<a href="event:action()"' does not work under IOS 8.3 (on Ipad2 - Safari 8.0)
Hello
The Html-Code '<a href="event:action()"' is used to start actions from the textfield. This doesn't work on my old Ipad 2 under Safari (iPad - iOS:8.3 - Safari 8.0 - WebGL).
I have not tested this before, so I can't say if the recent update to IOS 8.3 is the culprit. I didn't test it with other Ipads.
This is reproducable with the "official" Interface-JS-Example "Get a link to current pano view": "Close" in Textfield (after ".. via XML") does not work (krpano 1.18.3)
I tested it too with the old example http:/krpano.com/examples/textfield - Same result (krpano 1.19-pr1).
All examples work perfectly well with an alternative browser (iCab Mobile), so it has to do with Safari.
Regards
Wolfgang
Monday, April 13th 2015, 1:46pm
thanks for reporting!
This seems to be an iOS 8.3 bug, the iOS versions before were working fine.
I've tested this now and already found a workaround (by internally manually redirecting 'touchend' to 'click' events for the links).
I will need to do more tests of course, but if all works well, that workaround will be included in the next release.
Monday, April 13th 2015, 2:28pm
Danke
Wolfgang
Tuesday, September 22nd 2015, 2:39pm
Trigger an event via iframe?
Is it possible to trigger a krpano event from an html page placed in a textfield using iframe?
Tuesday, September 22nd 2015, 4:57pm
Tuesday, September 29th 2015, 3:03pm
Thanks mate,
it looks a bit complicated!
I'm going to try to get it working. And then hopefully simplify it a little bit.
Similar threads
