Monday, May 9th 2011, 8:28am
is it possible to load other scene's images in background?
I am using multiple scenes for multiple panos in single .xml file.
I have to do this for iPhone/iPad.
Is it possible to load other scene images(pano images) in background while loading the first scene images in progress?
Please let me know is it possible or not? and if it is possible, how?
thanks
Pratiks
Wednesday, May 11th 2011, 4:05pm
no, that's currently not possible,
and I'm not sure if it would be possible because of the limited memory on iPhone/iPad...
Thursday, May 12th 2011, 7:38am
thanks for your reply.
should i use any simple loader image in <preview> rather than to use cubestripe, spherical etc., images.?
or is there any other way to display loader image while changing from one scene to other in iPhone/iPad?
thanks
Pratiks
Thursday, October 8th 2015, 12:25pm
reviving this thread as I also have problems with a delay when entering a new scene.
I am using Krpano 1.19pr3 and the loading is especially bad when you are in VR mode, as your head movement doesn't work while the image is loading.
I tried the preload-action workaround, which works great for hotspots, but doesn't seem to affect panoramas. Is there now some way to preload (Sphere) panoramas? Did I miss something?
Phiz
