jl-krp
  • "jl-krp" started this thread
Occupation: Panographer - hobby and commercial
Monday, December 14th 2015, 6:29am
interactive spheres
Please take a look at some recent work - circular fisheye projections of spherical panoramas:
john-law.net/projects
I would like to turn these circular fisheye projections into true interactive spheres that the user can roll with mouse or finger, but dont know how to do so. I’m sure I’ve seen examples of this…
Suggestions gratefully received!
JL
john Law arps
current: www.john-law.net/projects
archive: www.john-law.org.uk
mail: mail@john-law.net
tel: 01225 339590
mob: 07814 993 904
skype: john-sk-law
panomaster
Occupation: Virtual Tours - Spherical Panoramas - Krpano developer
Monday, December 14th 2015, 1:32pm
It's not a good idea to convert panoramas from mirror ball. It's because of high distortion and blur near the border of mirror ball pictures.
Theoretically, you could use PTGui:
1. Open mirror ball image
2. Set Lens Type = circular fisheye and HFOV = 360
3. Set properly round crop in Crop tab (it should be done absolutely perfectly)
4. Click ctrl + E (editor) and align panorama
Here's what you can get (see attachment)
panomaster has attached the following image:
Red
Trainee
Occupation: Virtual tour creator, VR app developer
Monday, December 14th 2015, 3:17pm
Two suggestions that may help
- Use the Make Object droplet or the HTML 5 friendly solution from Andrey here http:
//www.krpano.com/forum/wbb/index.php?page=Thread&threadID=8034&pageNo=2
Firstly, it's not possible for the single circular image to be rotated as it's essentially just a flat image with one point of view.
You require multiple circular images, rotated slightly each time (say 10 degrees) to show a slightly different viewpoint which ends up covering 360 degrees of the sphere.
36 images would give you smooth rotation when interacting. 24 may even suffice. This will only give you horizontal rotation.
If you wanted vertical rotation you'd require more images.
See here Object VR with left/right AND up/down rotation
- For a sphere wrapped around a 3D object, you could implement the Three JS plugin.
Use three.js (3d objects) inside krpano (with VR support)
In this case the mirror ball/sphere projection is not necessary and the equirectangular is mapped to a 3D sphere object instead.
Example of pano mapped to a 3D object is here http://www.pano-ad.com.au/panos/animetes…thex/index.html
To enable mouse/touch interaction would require more coding knowledge in Three JS, but certainly possible.
Hope that helps
Monday, December 14th 2015, 4:20pm
Hi John,
I think most replies misunderstood you.
This just needs 3 view changes.
fovmin 180
stereographic false
fisheye 1
jl-krp
Monday, December 14th 2015, 6:37pm
many thanks!
Thanks for the swift replies!
Leszek - Your attached image looks similar to my initial equirect made from 4 x10.5mm images on a full-frame. The fisheyes were other ptgui projections, not mirrorballs:
Red - I’ve made 3d objects with modelling software but what I was trying to remember was a manipulable sphere in which the user was at the centre not outside it.
Many thanks for the links to the Three.js plugin and the examples.which look very promising.
Sacha - will try your settings and re-render - but will the result be passive or interactive?
Merry xmas & HNY’ 16 to you all!
JL
Monday, December 14th 2015, 8:19pm
jl-krp,
It's krpano viewing settings for normal scenes.. turns the scene into an interactive mirrorball. Is that what you wanted?
Friday, December 18th 2015, 3:17pm
Bingo! Thanks Sacha – for me at least, that's it. :)
Friday, December 18th 2015, 3:19pm
Although it would be perfect if the distortion simulated a ball coming OUT rather than being like looking into a concave shape.
Friday, December 18th 2015, 5:05pm
You can play with the options plugin in flash to change various settings quickly. If you use details=1 you get a cube. I've not seen that in krpano before.
Yeah it would look better out than in.. I didn't find a magic setting for it.
examples/plugin-examples/editor-options-plugins.. replace the flat image with one from the tours like..
		<preview url="../../../examples/virtual-tours/demotour-corfu/panos/achilleion-hof-unten.tiles/preview.jpg" />
			<cube url="../../../examples/virtual-tours/demotour-corfu/panos/achilleion-hof-unten.tiles/mobile_%s.jpg" />
jl-krp
Friday, December 18th 2015, 9:53pm
spheres again
Hi
Thanks to our pano colleague Toni Garbasso who pointed me towards WebGL, I now have a couple of interactive spheres with panos painted on the outside.
john-law.net/projects/spheres/ The Turrell cubic room looks very odd but the Hunstanton beachscape is almost tolerable.
Now I need to find out how to paint a pano inside a sphere...
WebGl is very forbidding for a non-programmer but it looks worth the effort!
JL
