181
Friday, August 19th 2016, 10:26pm
I have a problem with parsing 1-letter query parameters since 1.19pr4.
That problem was fixed in 1.19-pr6 (build 2016-08-08) - please check the build date of your version!
See also here: (or a few posts above)
Querystring parameters h and f are forced null
Friday, August 19th 2016, 10:35pm
while the iPhone really struggles
The problem is the bad/inefficent 'video to texture' transfer implemention in Safari - see here at 'iOS and Mac Safari - Bad video to WebGL performance':
http://krpano.com/plugins/videoplayer/#h…nownbrowserbugs
Only Apple itself could improve that, there is notthing that could be optimize here from external.
As workaround use lower-res videos, the performance depends on the pixel-size of the video (the more pixels that need to be copied from the video to the texture, the slower Safari).
Saturday, August 20th 2016, 2:35pm
Thanks Klaus,
all is fine now.
I had Krpano 1.19-pr6 (2016-08-05). With version Krpano 1.19-pr6 (2016-08-08) everything is OK.
Wolfgang
Taurus
Trainee
Occupation: photographer & virtual tour developer
184
Monday, August 22nd 2016, 4:51pm
NOT work wait(0)
Hi, friends,
I had a problem: the transition from 1.19.3 to 1.19.5 tours ceased to operate normally in flash, with the perfect worked under ntml5
the same as in 1.19.6
I found that the only reason for this was the command WAIT(0)
as soon as I removed all the wait(0) - everything become ok
whether I alone faced with such a problem?
Serge
in order to comply the word with the affairs, you need to keep quiet and do nothing!
Virtual tour Gomel
Virtual tour
Virtual tour
Elbrus
Windows 10x64 & krpano 1.19pr16
185
Tuesday, August 23rd 2016, 4:46pm
Hi Klaus
and members.
I have just completed a new project and updated it to 1.19pr6. When viewing in VR Stereoscopic on the cardboard it is very slow and clunky, and horrible to view. We have tried it on both an iphone 6 and Galaxy s6 with identical results. The link to this is below.
http://www.arc-cgi.uk/twofiftyone/twofiftyone.html
I have previously done one using the same code with version 1.19pr3, and this runs seamless in VR mode with the cardboard, the cube images are also larger for this one, so it cant be image file sizes.
http://www.arc-cgi.uk/xmas/arc_christmas.html
Has anyone come across this yet. The new tour had been created then upgraded to pr6 if this could be a factor. But a little counter productive if upgrading the tour is going to cause this, as it would mean a complete new project from scratch every time. The new pr6 is also important to us as the ability to run an Gear VR browser would be great as we have also created Gear VR specific tours, using Krpano for both requirements would be very usefull for certain projects.
Please could users test both and see if you get the same results, one smooth pr3, and one slow in VR mode pr6. And any resolutions would be fantastic.
Thank You
James
After much painful testing and rebuilding I have resolved the clunky movement withing stereoscopic VR on the cardboard with 1.19pr6.
I rebuilt the project with 1.19pr6 base, no conversion using the default hotspots keeping it as default and all worked great, I reduced the new hotspots right down to between 4kb and 10kb and all was well. After more testing (adding or removing features) I noticed the clunky sickening movement only comes in really bad with the removal of the <!-- VR scene switching hotspots --> and <!-- floating/following VR hotspots --> as the code below.
I find these very awkward in VR mode especially if you use hotspots,
<!-- <style name="webvr_menu_style" depth="800" scale="0.5" distorted="true" ath="0" atv="45" alpha="0.5" />
<hotspot name="webvr_prev_scene" keep="true" style="skin_base|webvr_menu_style" crop="0|64|64|64" ox="-64" onover="tween(scale,0.6);" onout="tween(scale,0.5);" vr_timeout="750" onclick="skin_nextscene_loop(-1);" visible="false" devices="html5.and.webgl" />
<hotspot name="webvr_next_scene" keep="true" style="skin_base|webvr_menu_style" crop="64|64|64|64" ox="+64" onover="tween(scale,0.6);" onout="tween(scale,0.5);" vr_timeout="750" onclick="skin_nextscene_loop(+1);" visible="false" devices="html5.and.webgl" /> -->
<!-- <action name="webvr_menu_following" type="Javascript" devices="html5"><![CDATA[
var hs1 = krpano.get("hotspot[webvr_prev_scene]");
var hs2 = krpano.get("hotspot[webvr_next_scene]");
if(!hs1.hovering && !hs2.hovering)
var f = 0.01; // following speed factor
var h = krpano.view.hlookat;
var v = krpano.view.vlookat;
var hsh = hs1.ath;
var hsv = hs1.atv;
h = (h -(h|0)) + (((h|0) +360180)%360) - 180.0;
v = (v -(v|0)) + (((v|0) +360180)%360) - 180.0;
hsh = (hsh-(hsh|0)) + (((hsh|0)+360180)%360) - 180.0;
var dh = h - hsh;
dh += (dh > 180) ? -360 : (dh < -180) ? 360 : 0
hsh += dh*f;
var a = Math.abs(v - hsv) / 90.0;
a = 1.0 * Math.max(1.0 - 2.0*Math.sqrt(a), 0);
v = v + 55.0 - v*1.5;
hsv = hsv*(1.0 - f) + v*f;
hs1.ath = hs2.ath = hsh;
hs1.atv = hs2.atv = hsv;
hs1.alpha = hs2.alpha = a;
]]></action> -->
Are these floating hotspots code being referenced elsewhere that removing this part could cause the clunky movement in stereo vr when removed?
James Budge
186
Tuesday, August 23rd 2016, 8:04pm
Yes - when you only remove that action but not it's call (see the 'webvr_setup' action), then there would be constantly warning and errors in the krpano log - and this will definitely be very bad for the performance!
The log is html text and each additional log message requires an additional html element - and adding html elements is slow!
Therefore always make your panos and tours error-free ;-) and don't trace constantly any messages!
There is also a note about that in the documentation:
http://krpano.com/docu/actions/#trace
Tuesday, August 23rd 2016, 8:58pm
NOT work wait(0)
Serge, you saved me - many thanks.
2 days ago i noticed the same problem with flash in pr4-pr6: Drgagging the pano was not possible, klicks on thumbs and hotspots didn't do anything.
But the right mouseclick showed the contextmenu and clicks in textfields did what they were supposed to do. Very strange.
And now: after I removed my 1 wait(0) in 2000 lines: everything OK in PR6 with Flash!
I dont't know if i had found this - many thanks!
Wolfgang
Taurus
Trainee
188
Tuesday, August 23rd 2016, 10:03pm
@Wolfgang
Yes, it was hard work *wacko*
I am very glad that I could help you *thumbsup*
Serge
Virtual tour Gomel
Virtual tour
Virtual tour
Elbrus
189
Wednesday, August 24th 2016, 3:26am
Klaus, Best *thumbsup*
190
Wednesday, August 24th 2016, 7:10pm
Do you have an example?
The wait itself shouldn't be the reason, it's probably a combination of other things.
Taurus
Trainee
191
Wednesday, August 24th 2016, 10:38pm
Hi, Klaus,
I do not have an example now
I can say that as soon as I replace the WAIT(0) to WAIT(0.01) - problem is solved
my virtual tours engine consists of a large number of modules and to search for the source of the problems I have cut off all of the modules disable, and then do a detailed tracing kernel
after finding out the causes of the failure and fix it, I consistently connected the software modules and replaced them WAIT(0)
Everything begins to work properly
Virtual tour Gomel
Virtual tour
Virtual tour
Elbrus
192
Thursday, August 25th 2016, 10:45am
@Wolfgang
Thanks for the sending an example! It helped identifying the problem.
That 'wait(0) bug' (endless waiting when called directly after blending to new pano) in the Flash viewer will be fixed in the next release (1.19-pr7).
360boy
Occupation: Virtual tours, Krpano coding, Graphic Design, Photographer, Panographer
193
Thursday, August 25th 2016, 10:36pm
Hi James,
Just checked both tours and everything is ok, ¿did you modify the slow version?. Anyway, I've been having the same issue here on a Galaxy S6 Edge, slow and choppy animation with upgrade to pr-6. In this case things went beyond as I've had a complete freeze of the device twice while exiting from VR-mode (complete block, buttons don't work, no turn off, no volume, nothing) and had reset it manually, which really is a new experience with Krpano and an obvious red alarm with future productions. Klaus, you may want to check this out.
Regards
Luis
194
Friday, August 26th 2016, 11:34am
Sure - do you have an example where this happens?
And what browser and browser version do you use?
360boy
195
Sunday, August 28th 2016, 2:22am
Yes, we have it online, it's a custom adaptation for a tour and it's open source right now. I'll send you the link.
It happened in a Samsung Galaxy S6, Chrome 52.0.2743.98, Android 5.1.1. right on exit of VR MODE, but it's not happening all the time
Regards
196
Sunday, August 28th 2016, 3:02am
1.19 pr-6 hotspots keep disappearing. super irritating !!
hi there. I have just converted to 1.19 pr-6. i have 17 scenes, and a target box in each scene.
the properties of the target box is as follows :
distorted="true" depth="off" vr_timeout="3000" zorder="1" zoom="true" enabled="true" alpha="1.0" visible="true"
onloaded="tween(alpha,1.0); "
the target box would appear in the scene. but when I mouse over or when the crosshair is over it in VR mode, the target box would just disappear !
when i go to the previous scene and back to the current scene , sometimes the target box is there, sometimes it is not !!
I have no idea what is wrong. this target box has similar settings as my other hotspots, but only it is causing issues.
1) is it because i am using a .png file ?
i am using a 256x256px .png image
2) the target box has the same name in all the scenes, could it be the problem ?
<hotspot name="hotspot_trigger"
and In every scene , I have a function to remove it.
<events name="nextsnd"
onnewpano="webvr.resetSensor(178.536);"
onremovepano="removehotspot(hotspot_trigger);
removehotspot(HS_narration);
removehotspot(HS_image);
removehotspot(previous);
removehotspot(title);
removehotspot(home);
removehotspot(restart); "
please help. this problem is getting annoying.
This post has been edited 2 times, last edit by "tmrnvrcome" (Aug 28th 2016, 10:25am) with the following reason: remembered more details
197
Tuesday, August 30th 2016, 12:18pm
Hi! in VR mode only in GearVR there are delays during the move. How to fix it?
http://aerocamera.ru/test/100516/360.html
I follow this instruction https://www.youtube.com/embed/tljfu3R5DvI?hd=1&vq=hd720 and this not help
ninerian
Beginner
Occupation: Softwareentwickler
198
Wednesday, August 31st 2016, 9:19am
dist2 setting for VRone
Hello Klaus,
thanks for all the great work. *thumbsup*
Actually we're testing the new VRone Plus and discovered a stuttering with the Samsung S6.
As you noted in the documentation, this is caused by the mobilevr_lens_dist2 parameter.
Would it be possible to use only mobilevr_lens_dist for this glasses?
199
Wednesday, August 31st 2016, 11:28pm
iPhone sound synchronization
Hi there,
I'm using 1.19-pr4 which works perfectly fine on Android. On iPhone 5,6,6s the sound and video are not synchronized. How can I fix it?
Thank you.
200
Friday, September 9th 2016, 5:59am
Scrollarea with Multiple Layers
Hi . I need help for my program . I have multiple textfield layers in a scene and I want to use ScrollArea plugin to toggle between the different layers. Only ONE textfield layer is visible at any ONE time.
I did a simple mock up. But the scrollslider does not return to the original position and the text is cut off at the bottom.
Do i have to create a scrollbar for each and every layer ? and use one layer container to contain one scrollbar and one textfield layer ?
Code is as follows :
<!-- use a grid preview pano as background -->
<preview type="grid(cube,16,16,512,0xCCCCCC,0xF6F6F6,0x999999);" details="16" />
<!-- view settings -->
<view hlookat="0" vlookat="0" fovtype="VFOV" fov="100" fovmin="60" fovmax="150" />
<!-- the textfield -->
<layer name="textfield" url="textfield.png" align="center" x="0" y="0" width="50%" height="300" scale9grid="6|6|268|188">
<!-- the scrolling text -->
<layer name="textmask" type="container" align="lefttop" x="5" y="5" width="-30" height="-10" maskchildren="true">
<layer name="textscroller" url="%SWFPATH%/plugins/scrollarea.swf" alturl="%SWFPATH%/plugins/scrollarea.js" mwheel="true" direction="v" overscroll="0" align="lefttop" width="100%" height="100%" onscroll="if(hoverflow GT 0, div(yp,toverflow,hoverflow);Math.min(yp,1);Math.max(yp,0); copy(th,layer[scrollbar].pixelheight);sub(th,layer[scrollup].pixelheight);sub(th,layer[scrolldown].pixelheight);sub(th,layer[scrollslider].pixelheight); mul(yp,th);add(yp,layer[scrollup].pixelheight); copy(layer[scrollslider].y,yp); );">
<layer name="text" url="%SWFPATH%/plugins/textfield.swf" align="lefttop" x="0" y="0" visible="false" width="100%" autoheight="true" background="false" border="false" onautosized="copy(layer[textscroller].height, height);"
padding="10 15"
html="data:testtext"
css="color:#000000; font-family:Arial; font-size:12px;"
<layer name="text2" url="%SWFPATH%/plugins/textfield.swf" align="lefttop" x="0" y="0" visible="true" width="100%" autoheight="true" background="false" border="false" onautosized="copy(layer[textscroller].height, height);"
padding="10 15"
html="data:testtext2"
</layer>
</layer>
<!-- the scrollbar -->
<layer name="scrollbar" type="container" bgcolor="0x000000" bgalpha="0.25" align="righttop" x="5" y="5" width="19" height="-10">
<layer name="scrollup" url="dirbutton.png" align="righttop" x="19" rotate="-90" crop="0|0|19|19" onovercrop="0|19|19|19" ondowncrop="0|38|19|19" ondown="asyncloop(pressed, layer[textscroller].scrollby(0,+1));" />
<layer name="scrolldown" url="dirbutton.png" align="rightbottom" x="19" rotate="+90" crop="0|0|19|19" onovercrop="0|19|19|19" ondowncrop="0|38|19|19" ondown="asyncloop(pressed, layer[textscroller].scrollby(0,-1));" />
<layer name="scrollslider" url="sliderbutton.png" align="righttop" x="0" y="19" crop="0|0|19|19" onovercrop="0|19|19|19" ondowncrop="0|38|19|19" ondown="if(layer[textscroller].hoverflow GT 0, copy(cy,y);copy(sy,mouse.stagey);dragging(); );" dragging="if(pressed, sub(dy,mouse.stagey,sy);add(ny,cy,dy);Math.max(ny,layer[scrollup].pixelheight); copy(th,layer[scrollbar].pixelheight);sub(th,layer[scrolldown].pixelheight);sub(th,layer[scrollslider].pixelheight);Math.min(ny,th); copy(y,ny); sub(ny,layer[scrollup].pixelheight);sub(th,layer[scrollslider].pixelheight);div(ny,th); copy(fh,layer[textscroller].hoverflow); mul(fh,-1); mul(ny,fh); layer[textscroller].stopscrolling(); copy(layer[textscroller].y,ny); delayedcall(0,dragging()); );" />
</layer>
</layer>
<hotspot name="btn" url="dirbutton.png" scale="2.0" ath="0" atv="-40" onclick="toggle(layer[text].visible); toggle(layer[text2].visible);" />
<!-- the text for testing -->
<data name="testtext">
Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet.
Duis autem vel eum iriure dolor in hendrerit in vulputate velit esse molestie consequat, vel illum dolore eu feugiat nulla facilisis at vero eros et accumsan et iusto odio dignissim qui blandit praesent luptatum zzril delenit augue duis dolore te feugait nulla facilisi. Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore magna aliquam erat volutpat.
Ut wisi enim ad minim veniam, quis nostrud exerci tation ullamcorper suscipit lobortis nisl ut aliquip ex ea commodo consequat. Duis autem vel eum iriure dolor in hendrerit in vulputate velit esse molestie consequat, vel illum dolore eu feugiat nulla facilisis at vero eros et accumsan et iusto odio dignissim qui blandit praesent luptatum zzril delenit augue duis dolore te feugait nulla facilisi.
Nam liber tempor cum soluta nobis eleifend option congue nihil imperdiet doming id quod mazim placerat facer possim assum. Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore magna aliquam erat volutpat. Ut wisi enim ad minim veniam, quis nostrud exerci tation ullamcorper suscipit lobortis nisl ut aliquip ex ea commodo consequat.
Duis autem vel eum iriure dolor in hendrerit in vulputate velit esse molestie consequat, vel illum dolore eu feugiat nulla facilisis.
At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, At accusam aliquyam diam diam dolore dolores duo eirmod eos erat, et nonumy sed tempor et et invidunt justo labore Stet clita ea et gubergren, kasd magna no rebum. sanctus sea sed takimata ut vero voluptua. est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat.
Consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet.
</data>
<data name="testtext2">
[p]Portuguese Macau around 1665, produced by the Dutch cartographer Johannes Vingboons (Image source: Atlas of Mutual Heritage). [/p]
[/br]
[p]Compare the map to today’s Macao.[/p]
[p]The Portuguese were officially granted by the Ming dynasty in 1577 to use Macao as a port which developed into a colony.
For more than 250 years Macao was the only port in China where Europeans could stay for a long period of time, and develop a community.
The Dutch and British both tried to snatch without success Macao from the Portuguese. All sorts of Europeans came and went.
The Portuguese maritime empire long ended in the early seventeenth century, but Macao limped ahead playing a key role in China-west interactions.
It only formally became a part of Chinese territory in 1999. What a colony with rich and colorful histories.[/p]
</data>
Similar threads
