AKSAN Bros
  • "AKSAN Bros" started this thread
Monday, October 3rd 2016, 9:24am
IOS 10 problem with 1.8.6
Hi Klaus 1.8.6 has problems with ios10, while rotating page panorama start to blinking, but ios 9 no problem or android or the others
vr.mersin.bel.tr can you check please, opening get time appx 5 seconds
Monday, October 3rd 2016, 10:04am
I don't get any blinking when trying your link but a distorted/stretched view on an iOS 10 iPhone...
But that seems to be related to your webdesign, not to krpano itself...
AKSAN Bros
Thursday, October 6th 2016, 12:21pm
https://www.youtube.com/watch?v=vOkLNd1KRJY
you can check this video, with ios 9 no problem only ios 10 and above, with 1.8.6 .
the new problems 1.19 has serius bugs with swfadress, and swfaddress null
https://vr.mersin.bel.tr/mobile/index.html
https://vr.mersin.bel.tr/mobile/index19.html
and second problem opening time is so long, we have so many elements in xml, 1.8.6 working but 1.19 opening time gets so long time but works with no problem, but waiting so so much time. (before not) is there a new preloading system in 1.19? (withoutswfaddress) we change it for you to test
https://vr.mersin.bel.tr/mobile/test.html
https://vr.mersin.bel.tr/mobile/test19.html
http://vr.mersin.bel.tr/ you can check the o
Thursday, October 6th 2016, 1:33pm
The 'long opening' could be related to the errors.
Writing errors is slow - each error message is a new dom element and creating and adding dom elements is slow.
So far I see the most errors are related to the 'style' using in the maps plugin.
That's because in 1.19 the 'style' attribute is a new universal xml feature and can be used for all xml elements - and because 'style' was unfortunately already in usage in the maps spots, it was necessary to rename it there to 'spotstyle' to avoid xml parsing conflicts.
That means as first step rename all 'style' to 'spotstyle' for the map spots.
AKSAN Bros
Thursday, October 6th 2016, 6:23pm
vr.mersin.bel.tr/mobile/maps.xml
vr.mersin.bel.tr/mobile/actionload.xml
vr.mersin.bel.tr/mobile/swfaddress.xml
vr.mersin.bel.tr/mobile/swfaddresspano.xml
vr.mersin.bel.tr/mobile/ana_sanalgezintimobile.xml
No we are using spotstyle too , you can check with debugger. Did you have an idea for swfadress too?
thanks
waiting for your news.
Friday, October 7th 2016, 7:28am
In this file:
change all 'style' attributes to 'spotstyle' attributes for the <spot> elements.
E.g. this:
<spot .... style="..." />
to this:
<spot .... spotstyle="..." />
Birdseye
Trainee
Occupation: Freelance Photographer
Sunday, October 9th 2016, 6:08am
I have the same problem with the blinking, after upgrading from Ios 10.0.1 to 10.0.2.
A friend of mine with the same Iphone (6+), who participate in the Ios Beta project has no problem with the Beta vesrsion 10.1.0.
Yvan
AKSAN Bros
Sunday, October 9th 2016, 10:26pm
Yvan
Hello Yvan, are you using swfadress ?
Birdseye
Trainee
Monday, October 10th 2016, 7:00am
Quoted
Hi Aksan,
No, but we do use an older version, JAddress
Occupation: 360˚ Photographer
Monday, October 10th 2016, 5:24pm
I'm seeing the same issue on iPhone 6 and iPad Air 2 with iOS 10.0.2 especially if the panorama is delivered via an iFrame. The iFrame seems to exaggerate the flickering issue. I've been having the same issue with my panoramas built out of Pano2VR and my RoundMe projects. However I haven't seen any problems with projects built out of krpano 1.19-pr8, even in iFrames the playback is perfect.
Viewing Aksan's panorama on the iPad Air 2 I can see a lot of flickering *sad*
Tony
AKSAN Bros
Tuesday, October 11th 2016, 4:39pm
Hello,
It is not a iframe problem. Because it was working on ios 9.x if you have you can check. this page www.anadolupark360.com and not used iframe.
Klaus any news from your side?
Tuesday, October 11th 2016, 7:51pm
What do you mean?
The flickering?
Have you already updated your krpano version?
Wednesday, October 12th 2016, 3:05pm
Hello,
Hi, yes, it's not specifically an iFrame problem, but if you are using an iFrame it makes the flickering much worse.
Tony
Birdseye
Trainee
14
Thursday, October 27th 2016, 11:44am
Problem is solved with the newest Iphone update 10.1 (on my Iphone), don't know about the Iframe issue.
