Wednesday, May 11th 2016, 5:26pm
360 Video Scene menu
I'm relatively new to krpano, so please excuse me if my question seems a little basic.
I'm trying to create a tour with multiple 360 video scenes. I'd like to create a scene menu similar to this example from the examples page
http://krpano.com/examples/119/krpano.ht…-corfu/tour.xml.
My default video is housed in an external xml file. Do I need to create a separate xml for each 360 video and call it with an action from my interface.xml page?
Thanks in advance (I hope I made sense)
Ronandl
Sage
Wednesday, May 11th 2016, 5:39pm
the answer is no ;-)
You can just use scenes.
example:
<scene name="scene_1" title="heli"  onstart="ChangeVideoScene(heli);" >
	<view hlookat="0" vlookat="0" fov="90" fovmin="60" fovmax="110" limitview="on" />
		  <sphere url="plugin:video" />
and also for example
<action name="ChangeVideoScene" devices="desktop">
		set(plugin[video].posterurl, calc:'video/%1-2k-poster.jpg');
		plugin[video].playvideo(video/%1-2k.mp4|video/%1-2k.webm);
i use a strict protocol in naming the videos like:
heli-1k.mp4
heli-2k.mp4 etc etc
So the ChangeVideoScene action can work.
Now, just call a scene. no need to stop or pause the video player.
Hope it helps!
Tuur *thumbsup*
This post has been edited 1 times, last edit by "Tuur" (May 11th 2016, 9:49pm)
Thursday, May 12th 2016, 2:26pm
Hi Tuur,
Thanks so much for your help. I really appreciate it!
One thing, though. when I implement the second example code, I receive an error when I click the many option for the second scene;
INFO: krpano 1.18.5 (build 2015-08-04)
INFO: HTML5/Desktop - Safari 9.1 - WebGL
ERROR: loading of calc:'video/null-2k-poster.jpg' failed!
ERROR: video/null-2k.mp4 - loading video failed!
I receive the same error when I use the full file name and root, too.
<action name="videointerface_avenue_view">	 set(plugin[video].posterurl, calc:'video/union-2k-poster.jpg');	 plugin[video].playvideo(video/union-2k.mp4|video/union-2k.webm);
I'm using a tour skin video interface template. I'm trying to link between scenes from the select view menu from the interface bar. Am I totally in the wrong direction?
Many thanks, again,
Ronandl
Sage
Friday, May 13th 2016, 6:19pm
please put the %1 's back in the ChangeVideoScene action.
Those will be replaced by the first 'argument' between the brackets from the ChangeVideoScene(); call
In this case that should be 'union'.
Call ChangeVideoScene(union); in the onstart of the scene.
In the ChangeVideoScene action the %1 will be automatically replaced with union.
With another scene you can call another video like: ChangeVideoScene(anothervideoname);
( http://www.krpano.com/forum/wbb/index.ph…d&threadID=2677 )
and then just use loadscene.
I find it very convenient.
In your example you made a mistake.. because there is nothing to calc.
So your line should be:
set(plugin[video].posterurl, video/union-2k-poster.jpg);
But then you need to call just videointerface_avenue_view(); in the onstart of the scene.
Then it should work, when the video is in the video folder / the path is ok.
Hope it helps!
Tuur *thumbsup*
This post has been edited 1 times, last edit by "Tuur" (May 13th 2016, 7:10pm)
Thursday, July 7th 2016, 5:43pm
PanoVideo Creator allows to create this menu in video tours. Simply select option"include preview navigation"
As well as it allows to create html-style menu navigation. And many other functions.
You can see how it works in this video
https://www.youtube.com/watch?v=u3myANAcKkg
Occupation: Media consulting and video production
Friday, November 18th 2016, 6:52pm
Problem loading multiple video scenes in WebVR example on IOS
Hi Tuur;
I'm having a similar problem loading multiple video scenes into a WebVR example.
A version of my code is here:
http://www.moreyummy.com/wp-content/test/examples/webvr/
Works fine on desktops, but the video won't load new "Panoramic Video" scenes on iOS. I suspect this is because I can't seem to set the variables 'videourl.ios' and 'videourl.no-ios' in the "video" plugin. But honestly, I'm not sure.
The XML file is here:
http://www.moreyummy.com/wp-content/test…r/krpano_vr.xml
Here's a code sample for the two thumbnails calling the videos ...
	<scene name="video_scene" title=""  onstart="ChangeVideoScene(video);" >		<view hlookat="0" vlookat="0" fov="90" fovmin="60" fovmax="110" limitview="on" />		<image>		  <sphere url="plugin:video" />    	</image>	</scene>			<scene name="video_scene2" title=""  onstart="ChangeVideoScene(video-orig);" >		<view hlookat="0" vlookat="0" fov="90" fovmin="60" fovmax="110" limitview="on" />		<image>		  <sphere url="plugin:video" />    	</image>	</scene>		<action name="ChangeVideoScene" devices="desktop"> 				set(plugin[video].videourl.no-ios, calc:examples/webvr/%1/video-1920x960.mp4|%1/video-1920x960.webm);		set(plugin[video].videourl.ios, calc:examples/webvr/%1/video-1024x512.mp4);		plugin[video].playvideo(examples/webvr/%1/video-1920x960.mp4|examples/webvr/%1/video-1920x960.webm, examples/webvr/%1/video-1024x512.mp4);			</action>
I'd appreciate it if someone might know what's going wrong on iOS.
Thank you.
This post has been edited 1 times, last edit by "surfermedina" (Nov 18th 2016, 11:58pm)
Sunday, November 20th 2016, 4:32pm
Hi!
Use PanoVideo Creator Extended or pro version. It allows to do it.
Exsample here: http://www.tcreator.classic-ru.org/example/videotour/ind.htm
