tsukada
Beginner
  • "tsukada" started this thread
Occupation: Programmer
Tuesday, December 6th 2016, 8:42am
Cookie and Authorization headers called from xml
Depending on browsers, no Cookie header or Authorization header are sent to server, when urls are called from xml.
Those urls are for fetching another xmls, images, movies and so on. The result is the server responding 401 error.
Especially ie or edge doesn't send those headers at all.
This is so annoying when the page is placed on a restricted area.
When I use application server, I added ;jsessionid=xxx to urls for workaround but in case of basic auth, we have to add Authorization header, that cannot be done by just manipulating url attribute of xml. *wacko*
Is there any way to solve or, Klaus, could you be kind enough to implement?
tsukada
Beginner
Tuesday, December 6th 2016, 9:27am
As for basic auth, I found using
<security cors="use-credentials" />
solved the problem.
Similar threads
