massimodeb
Beginner
  • "massimodeb" started this thread
Occupation: Photographer
Thursday, April 6th 2017, 11:32am
small text on the right + URl link
Please I like to insert a very small text on the right as credit + URl link.
What script do I put and where exactly to put it.
I am new to this forum I spend half a day reading lots of them.
The most issue I have lots of people sent scripts but I don't know which part to paste it in.
I Guest we are split in two sections, Good Photographers and Good Developers.
It takes lot of talent to be both.
Thank you very much Massimo Debattista - Malta - Europe
Umalo
Professional
Thursday, April 6th 2017, 2:29pm
Hi
Welcome to forum.
Add this simple row in any xml file you like. Eg. directly in tour.xml (if to be visible on all scenes don't put it inside scene definitions, but outside)
<layer name="credits" keep="true" url="%SWFPATH%/skin/yourimage.png" align="bottomright" edge="bottomright" x="5" y="5" enabled="true" visible="true" onclick="openurl(http://www.google.com,_blank)" />
In case you use Krapno default GUI you might have overlappings. In that case open skin/vtoursin and explroe code where scene title is defined. Same way create duplicate, rename layer and align on right side, with hard coded html="your text" and add onclick from above example. And set visible to true on start.
massimodeb
Beginner
Thursday, April 6th 2017, 7:53pm
Thank you Umalo
Thank you so much, It did work very well.
I hope I put in a right spot but its working.
<!-- startup action - load the first scene -->
<action name="startup" autorun="onstart">
if(startscene === null OR !scene[get(startscene)], copy(startscene,scene[20].name); );
loadscene(get(startscene), null, MERGE);
if(startactions !== null, startactions() );
<layer name="credits" keep="true" url="skin/logo.png" align="bottomright" edge="bottomright" x="5" y="5" enabled="true"............
Umalo
Professional
Thursday, April 6th 2017, 8:57pm
*thumbup*
