floz
Trainee
21
Saturday, May 6th 2017, 5:28pm
copyswf
Thanks for your hard work, Klaus!
Just wondering, will
copyswf
make a return in the .config files ? I'm creating panos batch-wise and don't need the .swf file to be created each time...
Thanks!
panomaster
Occupation: Virtual Tours - Spherical Panoramas - Krpano developer
22
Saturday, May 6th 2017, 10:37pm
There is a problem with aligning text when it is used as hotspot (no matter - distorted or not). Piotr reported misaligning but there are others problem eg. in Chrome vcenter works well but in Firefox text itself is aligned to the bottom an it is cutted.
Look at the example http://ai360.pl/projekty/vr_menu/index4.html
23
Sunday, May 7th 2017, 10:00am
Quoted
Still no way to use parent for hotspots in webvr mode ?
No yet, that's a way more complicated case because everything that has been done automatically by the browser (because all was html/css) has to be redone again manually for WebGL. I mean the layouting and the rendering of all involved elements. The first step here was the new textfield support and the next step will be a new internal layouting engine that will be designed for these requirements.
That's already planed and also already partially in work (several internals will be prepared step by step for that), but as this is a more comprehensive part, it will be probably not ready for version 1.19.
But by using several stacked hotspots (same ath/atv, offsets via ox/oy, ordered by zorder) it should be already possible to achieve almost the same.
Quoted
Just wondering, will copyswf make a return in the .config files ? I'm creating panos batch-wise and don't need the .swf file to be created each time...
Just set flash=false in the config files.
Or do you mean not creating any swf or js files?
For this case additionally the html setting (note - 'html' not 'html5') could be set to false in the config files.
Then only the images and the xml file will be created.
Quoted
But the text is not displayed in the center but on the left site.
Quoted
Thanks for reporting!
Sorry, I'm not sure how I could have missed such simple not working cases... *wacko*
There will be an update next week where these layout problems will be fixed.
jeromebg
Professional
Occupation: Photographer
24
Sunday, May 7th 2017, 10:43am
Ok, I understand, thnax Klaus !
One more thing, is it possible not to cut text when using textfield as a hotspot and setting a width & height ?
It seems text won't go to the next line, I guess because it's transformed into bitmap ?
Is it a bug ?
Umalo
Professional
25
Sunday, May 7th 2017, 3:41pm
Great update. Thanks Klaus *thumbup*
mstoss
26
Sunday, May 7th 2017, 11:38pm
Good news! Thanks a lot :-)
Michael
27
Tuesday, May 9th 2017, 5:41am
Hello,thanks for your hard work
But I think the date in the release note are not correct *tongue* ,in the news section of the mainpage
This post has been edited 1 times, last edit by "relationcg" (May 9th 2017, 8:46am)
jschrader
Occupation: Photographer, Producer
28
Tuesday, May 9th 2017, 12:50pm
Stereo, baby!
Finally. Thanks a lot and please move on ;-)
jschrader
29
Tuesday, May 9th 2017, 2:00pm
Equirectangular stereo pairs like name_l.jpg and name_r.jpg do no create stereo tiles when dragged onto the batch files.
It works with over/under and cubestrips. What am I doing wrong?
I still cannot use the tour edior. It generates an error message that flash is required. Also when dropped on the testing server. Why?
(Using Chrome).
spacerywirtualne
Professional
30
Tuesday, May 9th 2017, 2:32pm
(Using Chrome).
I checked and all my old online virtual tours build in the Flash Player stopped working on Google Chrome *huh* I think this is the end of Flash Player on this browser.
best regards
Piotr
facebook page :: youtube
cms4vr team *thumbsup*
jschrader
31
Tuesday, May 9th 2017, 8:50pm
Oh. my bad. I read that wrong and thought it was fixed already. That explains it fo course <facepalm>:
"Bigger news (e.g. a Flashplayer-free tour-editor) and many other features are still in work ..."
32
Wednesday, May 10th 2017, 7:44am
That would be possible by disabling the wordwrap setting;
https://krpano.com/plugins/textfield/#wordwrap
Thanks for notice! ;-)
Is corrected now.
33
Wednesday, May 10th 2017, 7:46am
Hmm... that should definitively work, just tested successfully again... *confused*
What are the full filenames and filepaths in your case?
Wednesday, May 10th 2017, 8:13am
고맙습니다. 클라우스는 최고 ~
35
Wednesday, May 10th 2017, 3:37pm
when renderer is webgl wordwrap can not work
set(hotspot[get(tooltipname)].wordwrap,true);
set(hotspot[get(tooltipname)].width,200);
set(hotspot[get(tooltipname)].height,200);
text="when renderer is webgl。wordwrap can not work"
36
Wednesday, May 10th 2017, 6:11pm
hm i just noticed,
that if you use google chrome 58.0.3029.110 on macosx 10.10.5 the screen stays blank white...
to be precise : the toolbar shows and works, but the panorama itself stays white, nothing visible
the console shows no errors, but if i set it to verbose i can see
"[Violation] 'requestAnimationFrame' handler took 70ms"
this does not happen on sierra with the same google version
also no problems with safari and firefox neither on 10.10.5 nor on sierra.
37
Wednesday, May 10th 2017, 8:44pm
That's also related to the layout problems mentioned a few posts above.
There will be a new krpano release in the next hours where this will be fixed.
38
Wednesday, May 10th 2017, 8:47pm
Sorry, but that sounds like a GPU/GPU-driver related problem of Chrome.
That should be not krpano related.
Are other WebGL pages working on that system with Chrome?
39
Wednesday, May 10th 2017, 11:02pm
there is a minor update from version 1.19-pr9 to version 1.19-pr10:
This release fixes several layout and rendering problems of the new textfield hotspot WebGL support.
Thursday, May 11th 2017, 4:47am
Linux Tools
Hi! thank you for great update.
I downloaded linux version and extracted files, the tools are changed to js implement.
Is there still command line interface of linux tools? ( depend on node.js ?)
Please tell me how to use linux tools.
