Reggie
Trainee
Occupation: Virtual Tour Photographer
61
Friday, May 19th 2017, 1:36pm
Thank You Klaus!
......your ingenuity is eclipsed only by your generosity! *smile*
62
Friday, May 19th 2017, 3:02pm
autolevel=prealign_noheading
autolevel=remap_noheading
:D
63
Wednesday, May 24th 2017, 11:39am
Example error: demotour-stereoscopic
Hi, klaus.
The example in the sample appears to be an error. Demotour-stereoscopic
Bottom: Stereo Display: When pressed on, vr is all running and the gyro does not work. Please confirm.
Example
Smartphone: Galaxy S6
Have a nice day~
This post has been edited 4 times, last edit by "hermas" (May 25th 2017, 1:14am)
64
Thursday, May 25th 2017, 12:56am
Equirectangular stereo pairs like name_l.jpg and name_r.jpg do no create stereo tiles when dragged onto the batch files.
It works with over/under and cubestrips. What am I doing wrong?
Hmm... that should definitively work, just tested successfully again... *confused*
What are the full filenames and filepaths in your case?
it doesn't work well when I dropped 2 pair of files. works well for one pair but not for the other and generates 3 groups of pano files:
000551A_l.tiles 002049A_l.tiles 002049A_r.tiles
And many mobile phones have 2K screen and have best effect for 10K pano images such as http://vr.g08.com/beihai/
So, the default size may be too low, and what size fits 10K pano images best?
# generate special optimized, non-tiled, lower-res images for VR
customimage[vr].size=1536
65
Friday, June 2nd 2017, 8:08am
Example
The bottom 'stereo button' in that examples only enables or disables the stereo display. That's not related to VR mode. For VR mode use the 'enter vr' button at the top.
There is unfortunately a bug in the current release that the sorting of the input files is randomly not working. And without sorting the 'image pairs' will not be detected.
As workaround please open the 'templates/basicsettings.config' file and add this line anywhere in the file:
sortinput=true
Then the file sorting and the stereo-pair detection should work.
The 'best' size is difficult to say, it depends on the display-resolution and the lens. Additionally also the loading time can be a factor. So just play with the size until you find a size what would fit your needs best.
xodrive
Beginner
66
Monday, June 12th 2017, 3:07pm
Can anyone confirm the wakelock function on iOS 10.3.2 ( with 1.19 pr10) isn't working anymore?
Previously i used the wakelock hack, which workt like a charm:
<!-- SPECIAL CASE END -->
<action name="ios10_webvr_wakelock_workaround" type="Javascript" autorun="onstart" if="device.iosversion GE 9"><![CDATA[
setInterval(function()
if(krpano.webvr && krpano.webvr.isenabled)
krpano.trace(0,"iOS wakelock hack");
window.location = (""+window.location.href).split("#")[0];
window.setTimeout(window.stop, 0);
window.setTimeout(krpano.Kloader.iOSWakelockCheck, 1); // an internal API: restart pending loading requests
}, 15000);
]]></action>
Now i read:
Plugins: WebVR Plugin -> Fix: iOS wakelock support.
On previous versions of iOS 10 it was working fine, but on iOS 10.3.2 it isn't working anymore. Even the Example tour isn't keeping the device awake: https://krpano.com/examples/119/krpano.h…tml5=only+webgl
I've tested it on several iPhone 6+ devices with iOS 10.3.2 with Safari and also Chrome.
We are planning to release a VR experience this week so i'm kinda stressed right now *cry*
Can someone please look into this?
67
Monday, June 12th 2017, 5:06pm
Right, it seems Apple has unfortunately closed that hack hole in iOS 10.3...
Other scripts (which are basically doing the same) are reporting that too:
https://github.com/googlevr/webvr-polyfill/issues/217
https://github.com/richtr/NoSleep.js/issues/29
I've warned about that in the documentation:
Quoted
Currently the wake-locking is not a browser feature, currently it is only an ugly hack. The current hack might be not working or could cause problems in newer/updated browser version, therefore it's optionally possible to disable that feature.
https://krpano.com/plugins/webvr/#mobilevr_wakelock
That mean until someone finds another hack for iOS, there might be no real solution for wakelocking/nosleeping yet...
ninerian
Beginner
Occupation: Softwareentwickler
68
Wednesday, June 14th 2017, 10:31am
When I add an hotspot with the text attribute, is it not shown, until I add width and height. Is it possible to autosize the hotspot, using the text width?
ninerian
Beginner
69
Friday, June 16th 2017, 8:13am
There was a css style, which applied on the table element, which krPano creates. So it's no bug in krPano. But maybe you should namespace the elements, so it won't happen per accident.
70
Tuesday, June 20th 2017, 11:47pm
onidle + autorotate
Hi *, Tuur, Scott, Klaus,
Having trouble to let the 360 panos looping with autorotate when idle. The same as Scott reported in his post:
https://krpano.com/forum/wbb/index.php?p…66460#post66460
Worked great with 1.18 but since 1.19.pr5 no way!
After lot of frustration I found the correct procedure:
autoratate.enabled = true,
autorotate.waittime = 10
idletime = 20
<events onidle="autorotate.interrupt(); skin_nextscene_loop(+1);" />
Due to Firefox 53.0 + WebGL ambiguity (code above is working when running wia Win7 + testingserver.exe but failing
when starting Firefox directly tour.html. It is not recognizing the onidle event after the first load.)
I added the autorotate.interrupt(); to the startup() action, too:
loadscene(get(startscene), null, MERGE);
It works on my desktop in the local testing environment (Win7 + FF53.0; Win10 + testingserver.exe + FF53; Win7 + testingserver.exe + IE11.0;).
Please let me know if it works for you, too.
Thank you,
Pavel
This post has been edited 1 times, last edit by "pur" (Jun 21st 2017, 3:26pm)
ninerian
Beginner
71
Friday, June 23rd 2017, 10:29am
Daydream and ZTE Axon 7 support
Hello Klaus,
would you be so kind, and implement support for the Device ZTE Axon 7 (ID "zte-a2017", screensize 5.5) in combination with Daydream? Actually the screen is split and the gyroscope of the device isn't used. Also the low persistance mode isn't activated. The website webvr.info is working on daydream, so it is possible.
Thanks for the great work on krpano. *thumbsup*
72
Saturday, June 24th 2017, 1:02pm
That sounds like a bit you're testing sometimes with Flash and sometimes with HTML5 and there maybe with different krpano versions...
Otherwise I have currently no idea what you might mean...
About auto-rotating - with the latest krpano versions there is also a new nice possibility for auto-rotating through tours - the 'onautorotateoneround' event
allows detection one autorotation 'round' and it's possible to keep the panos rotating during the blending for more seamless experience.
E.g. try this code (anywhere in the tour.xml, but outside the <scene> elements):
<autorotate enabled="true" waittime="1.5" accel="1.0" speed="10.0" />
<events onautorotateoneround="push(skin_settings.loadscene_flags); set(skin_settings.loadscene_flags, MERGE|KEEPVIEW|KEEPMOVING|NOPREVIEW); skin_nextscene_loop(+1); pop(skin_settings.loadscene_flags);" />
Monday, June 26th 2017, 10:12pm
Thank you Klaus! It's great!
In my code/post I was just finding where to put the autorotate.interrupt() to get exactly what the new 'onautorotateoneround' event solves. Of course I had to adjust the idletime to one rotation time. (Not talking about finding that the autorotate speed on IE 11.0 + WebGL / Win7 is half so quick as both Chrome 59.0 + WebGL + Win7 and Firefox 54.0 + WebGL + Win7. This is true for krpano 1.18.6 and 1.19.pr10).
I 'm looking forward to test onautorotateoneround event and will upgrade my vtours.
Thank you again!
Pavel
74
Wednesday, June 28th 2017, 3:39pm
Autorotate
Hi Does anyone have a working example using this code
I have tried it but cannot see any difference when having it added?
75
Wednesday, June 28th 2017, 4:40pm
Okay - I've made quickly a full example here:
https://krpano.com/tours/corfu/autotour.html
Here's the xml:
https://krpano.com/viewsource.html?tours/corfu/autotour.xml
Thursday, June 29th 2017, 1:33pm
Thanks Klaus :)
Sage
77
Thursday, June 29th 2017, 1:45pm
Great code example for my 'secret suprice' project. ;-)
Thanks Klaus!
Tuur *thumbsup*
http://www.virtualtuur.com
Skype:studiotuur
martyhr
78
Sunday, July 2nd 2017, 8:14am
Thank you. Now I have autotour options.
What about the new editor?
I desperately need to group my panoramas and to have posibility to "hide" thumbs of some panorama in thumbnails strip.
Example: Huge city tour with buildings interiors = separate groups: all, exteriors and parks, museum 1, museum 2 etc.
Hiden panorama= no thumbnail in the strip for - multitile flat panoramas of paintings on the walls in the museum.
79
Thursday, July 20th 2017, 5:41pm
sphere2cube syntax confusion
To me the new syntax of sphere2cube is confusing and not usable. If I get the current view coordinates (h,v) and want to create the same with sphere2cube -view. What values does -lookat= need?
With the old syntax I still had to put 3 values, but it was working fine with the third value=0. This does NOT work anymore.
The old syntax also does NOT work with negative values anymore, those were working fine before. Is there a proper way of doing this now *confused* (instead of adding 360 ;-) )
80
Wednesday, August 2nd 2017, 5:22pm
here the krpano 1.19-pr11 release notes:
  • New: Oversampling support for WebGL textfield hotspots - when using values higher than 1.0 the text will be rastered with a higher resolution. This improves the visual text quality, especially for zooming hotspots.
  • New: Support for mipmapping for WebGL textfield hotspots - when enabled the internal text-bitmap-buffer will be automatically scaled-up to the next power-of-two size to allow using mipmapping. This improves the text rendering quality for texts that get displayed smaller than they their current pixel-size (e.g. when zooming-out in the pano). Because of the scaling to the next power-of-two size in this case, it would be recommend to use additionally also oversampling to avoid scaling artifacts and for a better overall image/text quality.
    E.g. this are good settings if you prefer high quality text rendering quality for hotspots:
    mipmapping="true" oversampling="2.0"
    The only disadvantages are the higher memory need and the slightly slower text-to-bitmap rendering.
  • New: WebVR Plugin
    • Improved WebVR support - updated to the latest API and Browser-behavior changes.
    • When the screen-size of the Android device is unknown (required for correct VR rendering), load now an online Cardboard Device-Parameter-Database (dpdb) and try getting the information from there.
      New setting: mobilevr_database_url.
    • Support iPhone 6S, 6S+, 7, 7+, SE detection.
  • New: Do more checks for invalid names when creating variables and do a more advanced error reporting for an easier error locating. This avoids strange errors when accidentally creating variables that have the name of a number (e.g. a variable named '0').
  • Fix: In some cases the texts in WebGL textfield hotspots were either wrongly aligned, completely missing or words were wrongly cut-off - these problems are fixed now.
  • Fix: When tweening colors with an alpha component (e.g. the AA in 0xAARRGGBB), then the alpha value wasn't corrected calculated.
  • Fix: Avoid an JS-code-error when trying to load (currently unsupported) spherical-multires-images.
  • Fix: There could have been wrong a hotspot image/texture when switching hotspot urls in some cases.
  • Fix: Dispatch the onout event also when removing a currently hovering element.
  • Fix: Flying hotspots weren't correctly working when using architectural projection (report).
  • Fix: When the loading of the spherical preview pano image takes longer than the normal sphereical pano image, when wrongly the preview pano was shown instead of the normal pano.
  • Fix: Avoid a WebGL texture resource leak when using spherical preview images.
  • Fix: Several textfield plugin alignment/stacking problems in the Flash viewer due the internal/embedded textfield plugin from the last release.
  • Fix: When resolving expressions and doing number-type detection avoid a wrong String-to-Number conversions for some cases (report).
  • Fix: Makepano Tool - don't keep autoleveling the input images when autolevel setting is set to off.
  • Fix: Makepano Tool - the new sortinput setting was wrongly set to 'undefined' by default - and that resulting in a random behavior. Sometimes the files were sorted and sometimes not.
  • Fix: SphereToCube Tool - the 'lookat' rotations in the view mode were wrong.
  • Change: Testing Server (tour_testingserver) - use the IP address instead of 'localhost' by default when opening the url in the browser. This was changed because Chrome is extremely slow when doing the DNS resolving for 'localhost' (a Chrome bug).
  • Fix: Googlemaps Plugin - mouse dragging in IE11/Edge.
  • New: Bingmaps Plugin - complete port from the V7 to the new V8 Bing-Maps-API. Microsoft has announced to stop supporting/providing the old API. The spot and radar rendering is completely new but will work exactly as with the old API.
  • Fix: Videoplayer Plugin - avoid the iOS 10.3 black-first-frame bug (for video-panos and video-hotspots).
  • Fix: WebVR Plugin - the mouse-pointer-locking and the mouse-control wasn't working when switching to VR mode and being already in fullscreen-mode.
