Birdseye
Trainee
  • "Birdseye" started this thread
Occupation: Freelance Photographer
Friday, June 9th 2017, 7:23pm
Krpano testing server: Can't listen to port 8090!
Suddenly have this problem ...
ERROR: Can't listen to port 8090!
ERROR: Server can't be started.
Anyone knows a solution ?
Tnx for help,
Yvan
Birdseye
Trainee
Saturday, June 10th 2017, 5:41am
Solved. Don't know what happened but suddenly Windows asked for a major update and after that the testing server worked again. odd...
Birdseye
Trainee
Tuesday, June 13th 2017, 8:30am
Here we go again. Same problem occurs 2 days after Windows update. Yesterday, the testing server app worked a whole day without problems, and this morning after starting up my computer, I got this error message again...
I can't find a solution. Anyone?
Tnx,for help.
Monday, June 19th 2017, 10:24am
maybe an other software is already using port...
In this case you could try manually setting an other port in the settings tag.
Btw - an option for an automatic port selection (like the tour_testingserver does) will be added in one of the next releases. Then the tool would automatically choose a free port.
Birdseye
Trainee
Thursday, June 22nd 2017, 8:50am
Thank you for your reply. I already tried to set another port but nothing worked.
It seems that something is blocking the software. I even turned off the firewall and the Anti Virus. But none of this worked.
The testing server does work when I startup in safe mode with network support.
I have no clue what to do more.
