21
Saturday, September 23rd 2017, 10:49am
2. - having the ability to decide whether you want a relative or absolute system of coordinate for the view, normally that would be used to make a 3d transition, so we need to easily know the direction of the axis we need to move.
Yes. It will be nice!
Sergey74
Occupation: professional noob
22
Saturday, September 23rd 2017, 11:41am
Also made a small test for the new parameters. It remains only to understand how to make the transition))
http://panosphera.ru/gallery/transitions/2/
singleclick - shift to center view
doubleclick - shift to mouse
translation difficulties *huh*
jpdeglet69
Occupation: VR Maker and Document Management Expert
24
Sunday, September 24th 2017, 3:13pm
*thumbsup*
JPhD
VR-Guide®/Eleana CEO
https://vr-guide.online
Scott Witte
Occupation: Professional Photographer
25
Sunday, September 24th 2017, 10:24pm
Very nice update! The variable scope change is especially helpful. You are the best!
ramirox3
Occupation: photographer
26
Monday, September 25th 2017, 1:42am
Could someone please explain to us that we still do not understand. Why the variable scope is especially helpful? I have read trying to understand, but I still do not grasp the meaning and I would like to understand how to apply the concept
thanks in advance
Ramiro
27
Tuesday, September 26th 2017, 1:28am
thanks in advance
Ramiro
pr12
14
15
16
17
18
19
20
21
22
23
24
	<action name="do_crop_animation">
		<!-- add attributes to the hotspot -->
		registerattribute(xframes, calc((imagewidth / %1) BOR 0));
		registerattribute(yframes, calc((imageheight / %2) BOR 0));
		registerattribute(frames, calc(xframes * yframes));
		registerattribute(frame, 0);
		set(crop, '0|0|%1|%2');
		setinterval(calc('crop_anim_' + name), calc(1.0 / %3),
			if(loaded,
				inc(frame);
				if(frame GE frames, if(onlastframe !== null, onlastframe() ); set(frame,0); );
				mod(xpos, frame, xframes);
				div(ypos, frame, xframes);
				Math.floor(ypos);
				mul(xpos, %1);
				mul(ypos, %2);
				calc(crop, xpos + '|' + ypos + '|%1|%2');
				clearinterval(calc('crop_anim_' + name));
pr13
14
15
16
17
18
19
20
21
22
23
24
25
26
	<action name="do_crop_animation" scope="local" args="framewidth, frameheight, framerate">
		<!-- define local variables -->
		calc(local.xframes, (caller.imagewidth /framewidth) BOR 0);
		calc(local.frames, xframes * ((caller.imageheight / frameheight) BOR 0));
		def(local.frame, integer, 0);
		<!-- set the first frame -->
		calc(caller.crop, '0|0|' + framewidth + '|' + frameheight);
		<!-- do the animation -->
		setinterval(calc('crop_anim_' + caller.name), calc(1.0 / framerate),
			if(caller.loaded,
				inc(frame);
				if(frame GE frames, if(caller.onlastframe !== null, callwith(caller, onlastframe() ) ); set(frame,0); );
				Math.floor(ypos);
				mul(xpos, framewidth);
				mul(ypos, frameheight);
				calc(caller.crop, xpos + '|' + ypos + '|' + framewidth + '|' + frameheight);
				<!-- stop the interval when the hotspot gets removed -->
				clearinterval(calc('crop_anim_' + caller.name));
Tuesday, September 26th 2017, 9:31am
Very nice update! Thanks for your continued support and development *thumbsup*
Is it possible to use the new "fisheye image"-support to also embed undistorted fisheye-images as hotspot or plugin/layer?
And is it now possible to change the pano-image on the fly? For example changing a 360-photo for a 360-video without loading a new scene?
Sage
29
Tuesday, September 26th 2017, 12:56pm
Quoted
Why would you want that?
Tuur *thumbsup*
http://www.virtualtuur.com
Skype:studiotuur
30
Tuesday, September 26th 2017, 7:24pm
e.g. when doing a:
set(i, 0);
anywhere in a normal action then that 'i' variable will be defined in a 'global' scope - and that means that variable will be available also everywhere else in all other actions.
Here a case where this is problematic - one action does a for loop using an 'i' variable as counter and in the inner loop it calls another action that also does a for loop using an 'i' variable:
<action name="test" autorun="onstart">
  for(set(i, 0), i LT 3, inc(i),
     test_inner_loop();
<action name="test_inner_loop">
     trace('hello');
Both actions are using the same 'i' variable and so the output will be 3 x hello, because after the inner action call the 'i' is already 3 and so the outer loop will also end.
But when adding scope="local" to the actions:
<action name="test" autorun="onstart" scope="local">
     test_inner_loop();
<action name="test_inner_loop" scope="local">
     trace('hello');
both actions will define their own local 'i' variable and the output will 9 x hello.
That means it can help avoiding conflicts when using the same variable names in different actions.
The next thing is that this local variable scope for an action allows adding variables that will exist only in that action. And this is ideal for passing arguments. An argument passed to an action can be made available as local variable in that action.
And arguments as local variables has these advantages:
  • It allows writing better self-describing code - e.g. using 'caption' instead of just a '%2' in code.
  • It avoid problems with string escaping - when an argument will be a string that contains quote or comma characters then it can be problematic to quote the %NN placeholder in a way that it can be used as string again.
  • When the action doesn't contain any %NN placeholders, its code will be basically 'static' - and this allows internally to cache the parsing or to pre-compile the code - and this can make its execution much faster (currently this not implemented, but its' already in work for the next versions).
That means ideally all new actions should use scope="local".
With the following versions I will also update/port all current xml templates, plugins and examples to that (some where already updated).
Tuesday, September 26th 2017, 7:35pm
No, the fisheye support is currently for pano images (btw - the fisheye support is not 'new' ;-)), but I was also already thinking about providing that feature also for hotspots - although there is a bit more difficult to implement, especially the hit-testing will be challenging - that would require an inverse formula for the fisheye distortion, but I think that's mathematically not possible...
What's the problem with doing a loadpano/loadscene/loadxml call to change the pano image?
Wednesday, September 27th 2017, 9:23am
Enter VR text show on top when first Open tour
<krpano version="1.19" title="Virtual Tour" onstart="callwhen(layer[webvr_enterbutton].alpha == 1,showlog();)">
in pr12 log not show
in pr13 log show
33
Wednesday, September 27th 2017, 9:26am
It would be a very helpfull feature for very complex tours with lots of global actions (events onnewpano, onremovepano etc.) and scene-based onstart-events. If you just need to switch to a 360°-Video for a short time for example, there are a lot of if-then-else routines necessary in those events, event-driven actions and autostart-actions to exclude their auto-execution. It would help to reduce the amount of work drastically if you have just a few scenes but each scene needs to switch to 10+ 360-Videos for just 10-20 seconds. With the possibility to replace the pano-image/video on the fly a simple action could replace 100+ 360-video-scenes.
And it would also be a great way to include window-views for example without the need to load a new scene. Just switch to a quick 180°x180° fisheye-pano for a few seconds and return to the room WITHOUT loading all scene-elements again. The keepall-flag is just not the best way all the time :-(
Nupsi
benji33
34
Wednesday, September 27th 2017, 10:44am
Very nice and stable update *thumbup*
Minor issue : Is it possible to avoid the image blink when editing a textfield css on the fly with an [img] link into ?
It can be tested on the Combobox sample with a "rounded" design on the "thumbnails bar".
And also with a multiple scenes project the select of an item can be masked into the list if a removeAll / addItem is used prior to the select.[/img]
This post has been edited 1 times, last edit by "benji33" (Sep 27th 2017, 10:59am)
samadi
Beginner
Occupation: Tehran,Alborz,nazarabad,
35
Thursday, September 28th 2017, 6:36am
YES
PERFECT
*thumbsup*
www.livepano.ir
36
Thursday, September 28th 2017, 3:22pm
New Editor - not working with own tour.xml
try out the new features...MANY THANKS for the cool new updates... *thumbsup*
Found out, that if you use an own tour.xml, not that one that's generated by the VTOUR droplet, I can`t add/edit hotspots.
With the old flashPlayer Version it was/is working...
My panos are also seperated in scenes like in your tour.xml, but I don`t use the "vtourskin.xml" and the "skin_settings"...
Will that be considered in future/final version?
Steve
This post has been edited 1 times, last edit by "svb" (Sep 28th 2017, 3:38pm)
37
Friday, September 29th 2017, 12:16pm
Ummm...this update totally killed all the (html) input fields in our plugins. Works well with 1.19 pr10, does not in pr13. Any ideas?
(ps.: not talking about mobile stuff, this is on the desktop platform)
Sage
38
Friday, September 29th 2017, 1:20pm
Yes, i have the same problem, with the text input script.
*cry*
Tuur *thumbsup*
Skype:studiotuur
39
Friday, September 29th 2017, 3:03pm
in pr13 log show
Please see this post:
krpano 1.19-pr13
40
Friday, September 29th 2017, 3:07pm
Additional IMAGEONLY and NOEVENTS flags for the loadpano/loadscene/loadxml actions might be a possibility for such...
What do you think?
But sending no events could be problematic when the fov-ranges of the new image would be different...
