Sie sind nicht angemeldet.
Mittwoch, 10. Januar 2018, 11:25
kmaketiles.exe on old version of krpano 1.16.9-win64
i ran into a problem of losing original equirectangular images that has
been used to create a virtual tour using krpano-1.19-pr14.
so i
searched the forum, and i found some old posts talking about that i can
re create the panos from its tiles using kmaketiles.exe, which only
exist in older versions of krpano *sad*
so
when i tried to follow command lines in the replied of the posts
of other users here, i got an error because i couldn't license this
version 1.16.9 on win64 because there are no place to paste my
registration code anymore..
Please advise on how can i register or if there is any other solution to create panos from tiles.
Thanks *smile*
Mittwoch, 10. Januar 2018, 12:43
WRONG!
Just the filename / call is different now. Instead of several separated tools there is now one tool with different call parameters.
There is no need at all to use older versions.
See here at 'krpano Tools Changes':
https://krpano.com/forum/wbb/index.php?p…50816#post50816
That means instead of 'kmaketiles.exe' use 'krpanotools64.exe maketiles'.
See also the documentation:
https://krpano.com/tools/kmaketiles/#top
Mittwoch, 10. Januar 2018, 13:02
thanks for clearing that.. I was able to create cube faces now i`m facing another problem, when i try to convert cube face into sphere i get an error not a spherical nor cylindrical image
[img]https://scontent-cai1-1.xx.fbcdn.net/v/t31.0-8/26841279_1845731378812353_7365705308765798961_o.jpg?oh=e9333b7975c641f18114de511340200d&oe=5AEB5FBB[/img]
Any idea what`s wrong here?
Mittwoch, 10. Januar 2018, 13:39
okay i figured out what was wrong according to here: https://krpano.com/tools/kcube2sphere/#top
i had to rename the cubefaces with the suffix" _ "before each letter
thanks! PROBLEM SOLVED NOW I HAVE A PANO FINALLY *g*
Ähnliche Themen
