62
Tuesday, January 16th 2018, 6:40pm
step 2. open it and change URL to something like this: http://192.168.0.13:64544/tour.html#123
step 3. reload the browser page
Get an error: ERROR: copy(startscene,scene[0].name) - invalid variable name: 123
that's not directly an error, but the error message is wrong/unrelated.
When passing a query parameter (after a ? or # in the url), then the basic syntax to set/pass variables is:
tour.html?variable=value&variable=value&...
but the '=value' is optional, it also possible just to define a variable without value.
and that is what is happening here - that call tries to defined a variable named '123' - but that's an invalid name.
The error message is wrong because that happens at an 'unexpected' state/time.
Tuesday, January 16th 2018, 6:54pm
But I don't what to setup any variable. Who knows what can be in browsers hash after #.
For example I used hash for deeplinking, but since pr13 I get such warnings.
Is there any way to disable setting variables at all?
64
Tuesday, January 16th 2018, 7:00pm
Yes - just set the passQueryParameters setting in the html file to false (or remove the setting):
https://krpano.com/docu/html/#passQueryParameters
65
Tuesday, January 16th 2018, 7:09pm
Thanks its works!
However there is no documentation how to setup vars with #hashes
IMHO query_string is enough for it but hashes need to be leaved for customs purposes
66
Tuesday, January 16th 2018, 7:59pm
Is there any way to set passQueryParameters to false after player is embeded with passQueryParameters:true?
67
Tuesday, January 16th 2018, 10:53pm
I had to admit I wasn't aware too that '#hash' values were parsed as well. They were used as alternative when no '?query' values were present in the url.
In the next release this will be removed - then only the query values will be passed (when the related setting is enabled).
How do you mean that?
The url parsing and the passing the url variables to the viewer happens only ONCE at the embedding of the viewer...
benji33
68
Wednesday, January 17th 2018, 9:24am
When Simulated VR mode is activated on Chrome desktop (PC) when rotating with the mouse on Yaw axis the view is refreshed at a previous position during "quick" rotations. Works good on Firefox.
Many users report a difficulty to access a tour through the WebVR API with the Samsung Internet Browser for GearVR. It works great with the Oculus Browser.
Do you know the difference between the 2 differents browsers? It seems that the Oculus Browser has a better use of the available resolution. John Carmack FB Post
69
Wednesday, January 17th 2018, 11:59am
Oh! sure! sorry was drunk ;)
70
Wednesday, January 17th 2018, 8:25pm
Sorry, can't reproduce anything like that. Just tested again (on Windows).
Can you please explain your 'quick' rotations?
Right, the Oculus Browser has way better WebVR support - but for the technical details please contact the browser developers! From krpano side everything is the same of course. The rendering is done via the WebVR API and there the browser is doing the VR rendering.
jeromebg
Professional
Occupation: Photographer
71
Wednesday, January 17th 2018, 9:14pm
Quoted from "benji33"
I have the same issue with Chrome 63, when fake vr mode is enabled the view.hlookat resets to it's initial value while moving the mouse.
72
Wednesday, January 17th 2018, 11:19pm
Do you have the Chrome developer tools opened while testing this?
If yes - this is the problem - Chrome has a pointer-lock bug with opened developer tools.
With closed dev-tools I can't reproduce a problem, but there are some other (non-krpano) posts about a pointer-lock problem on the web - so maybe there is really a new Chrome bug here:
http://www.html5gamedevs.com/topic/34516…ith-windows-10/
http://www.html5gamedevs.com/topic/34523…g-in-chrome-63/
Btw - 'pointer-lock' is the name of the browser api for this control mode:
https://developer.mozilla.org/en-US/docs…ointer_Lock_API
Kabkee
Trainee
Occupation: South Korea
73
Thursday, January 18th 2018, 2:38am
log window color change.
according to the current update,
log window is too bright to see. since that , ever time i see the logs i have to drag and have all text been highlighted.
May i change the color or any other options for it ?
74
Thursday, January 18th 2018, 9:05am
you're talking about the krpano log, activated by pressing "O", right?
it is always black opaque with white text... how can it be that you cant read it?
maybe a screenshot?
benji33
75
Thursday, January 18th 2018, 9:32am
Here is a video sample with closed Chrome dev tools : https://www.dropbox.com/sh/dq9jntg58uo9z…tpIn4lxPma?dl=0
Thanks for the answer to jeromebg.
This post has been edited 1 times, last edit by "benji33" (Jan 18th 2018, 9:46am)
Kabkee
Trainee
76
Thursday, January 18th 2018, 9:40am
maybe a screenshot?
Is everyone having the same style as old as usual?
Check mine out in the attetchment.
77
Thursday, January 18th 2018, 10:00am
uh that looks strange... are you on 1.19?
i've never seen that...
maybe klaus knows whats going on w your tour
Kabkee
Trainee
78
Thursday, January 18th 2018, 10:11am
Yes, it's 1.19 pre14. most updated one.
I assumed that it's a new feature because its style is set using inline style attribute.
.... strange... and hard to see.. :(
79
Thursday, January 18th 2018, 10:50am
Looks like some custom CSS styles that overwrite global element styles... (link to the example?)
krpano itself doesn't style the log this way of course ;-)
Kabkee
Trainee
80
Thursday, January 18th 2018, 11:00am
please, check out the link - https://look360.kr/vr/indyspot/indyspot_member/2521
I hope the link will work on your country as well.
press 'o' key will show the log.
Similar threads
