benji33
101
Monday, February 19th 2018, 11:51am
I've an issue with z-index and fullscreen.
In fact I use external div element out of the krpano div and I apply my own fullscreen treatment.
But since latests krpano version I've noticed that the z-index of the krpano element is applied to the highest zindex available (2147483647) and the others div cannot be displayed anymore with Android Chrome browser when rotating the screen (which apply the fullscreen event).
Is it a krpano or Chrome issue/feature ?
102
Tuesday, February 20th 2018, 10:29pm
copyattributes() / PARENT
Hi
i played with copyattributes to copy all params from layer1 to layer2 and it turns out it has problems copying parent attribute: its value is correct in the debugvar but the layer doesn't show up in the parent element (it doesnt show up at all even if visible set to true)
Regards
jeromebg
Professional
Occupation: 360 experiences creator
103
Wednesday, February 21st 2018, 9:57am
https://krpano.com/docu/xml/#display.autofullscreen
benji33
104
Wednesday, February 21st 2018, 3:30pm
Nice thanks Jérome !!! I'll have a look.
105
Wednesday, February 21st 2018, 5:03pm
ondoubleclick action for layer/hotspot
Adding an ondoubleclick property for layer/hotspot as you did for events would be soooo nice!
regards
106
Wednesday, February 21st 2018, 10:40pm
copyattributes()
Please note that the copyattributes() when Flash viewer does not copy all attributes to the new destination (mainly numeric) e.g. width, height, ath, atv.
The workaround: device.flash only set() function.
The copyattributes action was originally intended to copy attributes from custom elements.
When using it with layer or hotspot elements there are several problems - the action copies also 'state' attributes like loading, loaded and also some internal attributes - and additionally attributes that are predefined/build-in weren't copied in Flash because they are technically a special case there.
But to make that possible the next krpano version will have a special handling for this case - it will detect if the source is a layer or hotspot element and then skip these internal/state attributes and handle also the special Flash cases.
Wednesday, February 21st 2018, 10:49pm
Yes, that's the 'New Automatic Fullscreen Mode for Android when rotating the device to landscape mode' feature.
It was documented on the news page:
https://krpano.com/news/
and also in the release post:
krpano 1.19-pr14
krpano doesn't change the zindex in this case, it only uses the browsers fullscreen on landscape feature.
When using a custom fullscreen management outside of krpano that setting would need to be disabled.
Wednesday, February 21st 2018, 10:53pm
Here some code that will add 'onsingleclick' and 'ondoubleclick' events to layers or hotspots:
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
<style name="doubleclick"
       downx="0"
       downy="0"
       clicks="0"
       onsingleclick=""
       ondoubleclick=""
       onclick="doubleclick_style_onclick();"
<action name="doubleclick_style_onclick">
    inc(clicks);
    if(clicks == 2,
        set(clicks,0);
        stopdelayedcall(doubleclickdetector);
        if((((mouse.x-downx)^2 + (mouse.y-downy)^2)^0.5) LT (device.touch ? 10 : 2),
            ondoubleclick();
            onsingleclick();
            onsingleclick();
        copy(downx, mouse.x);
        copy(downy, mouse.y);
        delayedcall(doubleclickdetector, 0.3,
            set(clicks,0);
            onsingleclick();
To use it:
<layer ... style="doubleclick"
         onsingleclick="trace(-single click-);"
         ondoubleclick="trace(-double click-);"
Thursday, February 22nd 2018, 12:08am
thanks!
110
Thursday, February 22nd 2018, 8:32pm
break(); malfunction
Please notice some break(); imperfection.
Neither in if( ) nor in for( ); loop is it doing as expected. Am I missing something?
14
15
16
17
18
19
20
21
22
23
<action name="break_test">
    <!-- OK -->
    trace( before break);
    break();
    error(AFTER BREAK);
<action name="break_test_1">
    <!-- HTML5 & Flash goes to ERROR -->
    if( true == true,
        break();
    error(AFTER BREAK);
<action name="break_test_2">
    <!-- loop break (the next iteration...) -->
    for(set(i,0), i LE 5, inc(i),
        trace(i);
        if( i EQ 2, break(); );
    trace( 'loop broken at ', i);
(I use my test case in the onclick event of the contextmenu item but the same happens in html5 and flash viewer, too.)
Anyway thank you for your great work!
Pavel
111
Friday, February 23rd 2018, 12:31am
i also never understood break();
long ago i tested it and i failed to use it to exit an action on a condition.
since then i never used it again.
something like this does not work as i remember...
<action name="test">
if(!condition, break());
... code block ...
Scott Witte
Occupation: Professional Photographer
112
Tuesday, February 27th 2018, 6:27am
Hotspots Always distorted in VR Mode
Klaus,
There seems to be a bug with hotspot distortion in VR Mode in pr14. Distortion is always true. Here is the relevant code:
<hotspot name="hs1" url="skin/Rons.jpg" flying="0" scaleflying="false" zoom="false" distorted="false" alpha="1"  depth="off" />
How it behaves in pr13
How it behaves in pr14
Behavior is fine in non-VR Mode. Only VR Mode has the problem.
This post has been edited 1 times, last edit by "Scott Witte" (Feb 27th 2018, 7:55pm) with the following reason: modified examples to include distorted and non-distorted version for comparison.
113
Tuesday, February 27th 2018, 5:36pm
That's not a bug, that's intended - here a quotes from the news page and the news post: ;-)
Quoted
Better, more natural non-distorted hotspot rendering for VR.
Quoted
Improved non-distorted hotspot rendering for VR - the normal 'billboard' rendering method that is done on normal screens doesn't 'work' in VR. Now a rendering method will be used that will display the hotspots in an 'expected' way.
That means it's not the normal distorted=true mode, it is a special mode for VR (e.g. the hotspots don't scale with the fov like normal distorted hotspots do).
Please test and compare it in the headset and not on the desktop screen!
The new method should be much better - in VR it should be the equivalent to the normal non-VR viewing.
Scott Witte
114
Tuesday, February 27th 2018, 7:51pm
Quoted
I have looked at this in a headset and I'm not seeing it. I have updated the examples. When loaded, the image straight ahead has distorted="false". The version to the right has distorted="true". In v14 the two seem to behave exactly the same in VR Mode. The non-distorted image is locked to the background in VR mode and distorts with it, exactly like the distorted version. That is nothing like in non-VR Mode.
Why is this important? I use this to display still images in the headset. When doing that you want them to remain square to the screen when looking around, as they do in non-VR Mode, not distorting with the background.
This post has been edited 1 times, last edit by "Scott Witte" (Feb 28th 2018, 3:00am)
115
Wednesday, February 28th 2018, 10:16am
In non-VR mode the distorted=false hotspots are oriented to the flat screen surface - but in VR mode there is no flat screen surface. In VR such hotspots look like they would rotate by itself when you move the head around. So they will not remain 'square' anymore (when viewing in the headset).
But when keeping the hotspots oriented to the viewer (as distorted hotspots do) they have the same visual effect as the screen-orientation in non-VR. Now they will remain looking 'square'.
Btw - the more FOV the headset has (e.g. test with Vive or Rift if possible), the better that effect can be seen.
If really necessary I could add a setting for disabling that again, but I can't see any usage cases where this would be useful...?
Wednesday, February 28th 2018, 11:25am
@klaus.. i noticed, too that hotspots in vr mode behave strange...
in my case i have info "i" icons without distortion
in non webvr they are oriented normally
but in webvr the lower center points to the "south-pole", which looks a bit strange
(also using a cardboard)
normal https://pasteboard.co/H9IrKyR.jpg
webvr https://pasteboard.co/H9IrxNu.jpg
best, index
117
Wednesday, February 28th 2018, 2:00pm
What about when viewing them in a headset like Vive or Rift or GearVR?
Cardboard headsets typically have a much too few fov and are often not very well calibrated to be allow a judgement.
118
Wednesday, February 28th 2018, 9:10pm
Vive or Rift or GearVR... i sadly dont have any of those...
in cardboard mode the effect is very strong as you see
to clarify, its not an urgent matter at all here.. just wanted to notice you about it
dunno if this is a problem of representation of distortion=false for headsets
but anyway in this case these rotations dont look optimal
This post has been edited 1 times, last edit by "indexofrefraction" (Feb 28th 2018, 11:05pm)
Scott Witte
119
Tuesday, March 6th 2018, 6:50pm
Hotspots Always distorted in VR Mode -- Conclusion
OK. I've been working pretty hard on this, comparing the way non-distorted hotspots work in previous versions and v14 for the actual tour I am building. Got a Gear VR headset and a really good Cardboard goggle to test this fully. My conclusion......Klaus is right. Who knew!? V14 is better.
Still, ideal for me by a long, long shot would be a way to display a hotspot image so that it appeared to be -- and stay -- square to the phone. It would need the same pincushion distortion as a distorted hotspot to accommodate the goggle but no other 3D transform or rotation, just move in a 2D plane as you move your head. Is that possible, Klaus? It would make photo displays better and address index's button issue, I think.
120
Friday, March 16th 2018, 12:19pm
gyroscope bug
Hello Klaus !
I've noticed that since the last Chrome update ( 65 ) the gyroscope is not working anymore on my Samsung smartphone.
http://www.prismamediaxrlab.com/tour-de-france/
Can you tell me if you already know this issue ?
thank you very much !
Similar threads
