121
Friday, March 16th 2018, 3:15pm
Can you tell me if you already know this issue ?
Sure - it's a Chrome bug - see these threads for more information about updated plugins:
Possible gyro issue with Chrome 65 for Android.
Webvr not working with Chrome's latest updates
122
Saturday, March 17th 2018, 9:10pm
Thank you so much, Klaus ! You're the best ! Cheers
123
Monday, March 19th 2018, 7:49pm
You can download Chrome Canary for the moment to get it working.
Hello Klaus !
I've noticed that since the last Chrome update ( 65 ) the gyroscope is not working anymore on my Samsung smartphone.
http://www.prismamediaxrlab.com/tour-de-france/
jordi
124
Tuesday, March 20th 2018, 12:39pm
i also never understood break();
long ago i tested it and i failed to use it to exit an action on a condition.
since then i never used it again.
Just a simple code for demo
for(set(i,0), i LT 2000, inc(i),
	if(scene[get(i)].name,
		error(i);
		error('no more scenes');
		break();
you can check it will stop once the condition is not true anymore, and then you will avoid looping until 2000
everpano.com step beyond 360
125
Tuesday, March 20th 2018, 6:01pm
the docs say:
"Break / stop the execution of the current actions call."
now, the problem is that break() only breaks the actual block
this works for loops, but you cant use it in a condition to exit an action.
	<action name="test" autorun="onstart">
 		if(true, break());
 		trace('a')
		break();
 		trace('b');
INFO: a <--- this should not happen
note: the 2nd break() works, 'b' wasnt logged
strangely it works in the condition in your example....
so i guess either there is a bug or "stop the execution of the current actions call" is not meant how i understand it
it would be nice to have a return(), even if it is not used for a return value. could be called exit() ?
Scott Witte
Occupation: Professional Photographer
126
Wednesday, March 21st 2018, 4:31am
Hotspot math in WebVR problems
Having a hard time understanding the new hotspot math in WebVR mode. For example, I place the scene title in a non-distorted text hotspot at the top of the stage. In non-vr mode and in pre pr14 releases that is easy: oy = stageheight/-2. But in true WebVR mode (simulated works much differently) in pr14 I can't figure out what is going on. What is the formula?
If you want to see my various attempts I will post them.
127
Thursday, March 22nd 2018, 8:52am
That's not a bug, that's how the break() currently is intended to work.
But for the next release I have improved the break() functionality a bit - then call break() will not only stop the current flow of actions, but also one flow from 'one level' up - that means when called inside an if() it will stop the flow inside the if() actions and also the flow() that was calling that if() - and if there was a loop() one level up, then also this loop.
I will think about it, maybe as exitcall()...
128
Thursday, March 22nd 2018, 8:59am
Sorry, but placing hotspots relative the screensize is a bad idea in VR - in VR there is basically no screen anymore. The screen size and resolution defines indirectly only the maximum possible fov, but that's also depended on the VR headset and the lens distortion. And the field-of-view is not square, depending on the lens it is a mixture of round and square.
That means the screen/stage sizes shouldn't be used in VR for positioning at all.
Better just use fixed angels in VR (like in real) - e.g. something 30° degree upward (atv=-30).
Thursday, March 22nd 2018, 9:20am
that would be great *squint*
it just would allow nicer code by avoiding big condition blocks sometimes
spacerywirtualne
Professional
130
Thursday, March 22nd 2018, 10:13am
It would be great. *thumbsup*
Piotr
facebook page :: youtube
cms4vr team *thumbsup*
Similar threads
