Sie sind nicht angemeldet.
Samstag, 14. Juli 2018, 13:35
Transparent Grid on a spherical panorama
is it possible to put a trasnparente grid on a spherical panorama as a reference to fix the hotspots?
Suso
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Suso Barral« (14. Juli 2018, 14:24)
Samstag, 14. Juli 2018, 15:21
no, that is not possible...
but you can add this to your xml
Quellcode
<events name="click4angles" keep="true"
    onclick="screentosphere(mouse.x,mouse.y,mouseath,mouseatv);roundval(mouseath,3);roundval(mouseatv,3);debug('ath=',mouseath,' atv=',mouseatv);" />
then open the log with "O"
and click around
Samstag, 14. Juli 2018, 19:06
Ok thank you very much,
I put the event code in my xml and nothing happens, what should happen?
Thanks for your attention
Suso
Samstag, 14. Juli 2018, 20:30
try to change your main xml like this
<krpano debugmode="true" showlog="true">
<events name="click4angles" keep="true" onclick="screentosphere(mouse.x,mouse.y,mouseath,mouseatv);roundval(mouseath,3);roundval(mouseatv,3);debug('ath=',mouseath,'atv=',mouseatv);" />
.... your stuff ...
Samstag, 14. Juli 2018, 21:13
Ok, this works, but what I'm really looking for is a grid over the scene or guides to adjust the perspective of my hotspots.
Thank you.
Regards
Suso
Erleuchteter
Beruf: Krpano custom coding / Virtual Tours / Photography / Musician / Recording engineer
  • Nachricht senden
Sonntag, 15. Juli 2018, 14:59
download this pic:
http://www.virtualtuur.com/krpano/grid/1/grid.png
Now you can burn it in your pano, with photoshop for example and use that
OR
make cube faces from it as hotspots.. and overlay.
simple, and sloppy example of that.
xml
http://www.virtualtuur.com/krpano/grid/1/tour.xml
Edit:
if you press T (keyboard) , then you find my little toolbox.
https://krpano.com/forum/wbb/index.php?p…74910#post74910
use the numbers section, or maybe better the distorted hotspot editor to find some relevant numbers etc..
Hope it helps
Tuur *thumbsup*
Skype:studiotuur
Erleuchteter
  • Nachricht senden
Sonntag, 15. Juli 2018, 23:49
i quickly made a dynamic grid.
UPDATED!!
http://www.virtualtuur.com/krpano/grid/3/
press G to show/hide the grid.
Is that what you mean?
include the grid.xml in your project.
grid.xml
I will add this to the Toolbox at a later moment.
updated: DONE!
But here you can of course also press T.
The numbers section could be help full.
edit:
yes.... i was a bit sloppy on the line position, but that will be fixed.
UPDATE:
FIXED
Hope it helps!
Tuur *thumbsup*
Skype:studiotuur
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »Tuur« (19. Juli 2018, 13:25)
Taurus
Schüler
Beruf: photographer & virtual tour developer
  • Nachricht senden
Montag, 16. Juli 2018, 14:42
in order to comply the word with the affairs, you need to keep quiet and do nothing!
Virtual tour Gomel
Virtual tour
Virtual tour
Virtual tour Elbrus
Windows 10x64 & krpano 1.19pr16
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Taurus« (16. Juli 2018, 23:09)
Montag, 16. Juli 2018, 23:34
Thanks Tuur and Thanks Taurus forma your help
Suso
