Sie sind nicht angemeldet.
Donnerstag, 31. Mai 2018, 11:59
show expiry date
I have set an expire date via krpanotools, is there anyway I can show this in the context-menu or call it as a variable?
Thanks!
Freitag, 1. Juni 2018, 22:03
there is currently no API to access the expire date, but I will consider one of the next releases.
Fernando
Fortgeschrittener
Beruf: Architect, Photographer, Programmer.
  • Nachricht senden
Montag, 2. Juli 2018, 15:43
Hi, Klaus this feature is very important. Now the only option is to link to Website. Another option as: "Message to show when expired" would be very good.
Best Regards,
Fernando.
jordi
Fortgeschrittener
Beruf: creating ideas & coding them
  • Nachricht senden
Montag, 2. Juli 2018, 21:28
Fernando, you can already do that. Just set a variable with the value of expiration and check if current time is lower or bigger...
everpano.com smart virtual tours
Fernando
Fortgeschrittener
  • Nachricht senden
Dienstag, 3. Juli 2018, 16:44
Thanks Jordy, this is very important for me.
Where is that info? How to get that variable? Any example please.
Greets,
Fernando
Scott Witte
Fortgeschrittener
Beruf: Professional Photographer
  • Nachricht senden
Freitag, 6. Juli 2018, 04:11
Just add it to the skin_settings variables:
Quellcode
<skin_settings
      expiry="######"
      gyro="true"
If you want a message to appear add a textfield and display it there.
Fernando
Fortgeschrittener
  • Nachricht senden
Montag, 9. Juli 2018, 15:45
Thanks Scott and Jordy,
1) Is there any krpano current date variable or it is javascript variable?
2) The idea is before to load the complete project, check this var: if the date expired then show message, if not run normally?
Greets,
Fernando
Scott Witte
Fortgeschrittener
  • Nachricht senden
Montag, 9. Juli 2018, 17:18
Pretty sure you need to do a js call to get the system date.
jordi
Fortgeschrittener
  • Nachricht senden
Mittwoch, 11. Juli 2018, 07:17
You should use unix time, so if you don't want to make it dynamic go this web page and transform your expiration date into unix timesatamp
https://www.unixtimestamp.com/
then set in your krpano tag the expirationDate atribute
Quellcode
<krpano expirationDate="1594451340" onstart="checkExpiration();" >
then it comes the action that you will probably need to execute on start
Quellcode
<action name="checkExpiration" type="javascript"><![CDATA[
    var expirationDate = krpano.get("expirationDate");
    var currentTime = new Date().getTime()/1000; // UNIX TIME IN SECONDS
    if (currentTime > expirationDate) {
        doSomething(); // Javascript Action
        // or
        krpano.call("myKrpanoAction()");
]]></action>
Fernando
Fortgeschrittener
  • Nachricht senden
Mittwoch, 25. Juli 2018, 06:31
Thanks Jordi, your example is very usefull. It works fine *thumbsup*
Greets,
Fernando
Mittwoch, 25. Juli 2018, 18:49
Fernando,
This code does not check expiration date but installation version of krpano but may be useful, too. Just set the expire_date before.
Quellcode
	<!-- krpano version check -->
	<action name="combobox_versioncheck" autorun="preinit">
		if(build LT '2017-09-13',
			error('combobox.xml - too old krpano version!');
			set(events[combobox_xml_plugin_events].name, null);
			set(action[addComboboxLayer].content, '');
			set(action[removeComboboxLayer].content, '');
It is located in the krapno examples ..\krpano\krpano-1.19-pr16-win\viewer\plugins\combobox.xml file.
Regards,
Pavel
Fernando
Fortgeschrittener
  • Nachricht senden
Donnerstag, 26. Juli 2018, 21:09
Thanks Pavel,
in this case, the problem is how to get the current date in krpano ... Do you know how?
Greets,
Fernando.
Samstag, 28. Juli 2018, 13:07
Hi Fernando,
Here is the action
Quellcode
	<!-- Expiration check  -->
	<action name="check_expire" scope="localonly" args="exp_date">
		jsget(today, 'new Date().toISOString().slice(0,10);');
		trace('Today is ', get(today));
		if(today GT exp_date,
			//your actions here e.g.:
			error('Sorry, your creditcard has expired!');
and the call is:
Quellcode
check_expire('2017-12-31');
Regards,
Pavel
Fernando
Fortgeschrittener
  • Nachricht senden
14
Samstag, 28. Juli 2018, 14:52
Thanks Pavel, very good solution! *thumbsup*
Greets,
Fernando
