Friday, September 28th 2018, 6:58am
How to create a hotspot(custom sprite) in the plugin interface?
This do not work :(
var hs = krpano.addhotspot(name);
hs.ath = 0;
hs.atv = 0;
hs.sprite = document.createElement('div');
hs.sprite.appendChild(element);
Do you have any relevant example?
I want to load the plugin only once and create multiple hotspots.
Friday, September 28th 2018, 10:47am
directly adding custom html elements is not possible,
it would be necessary to load an image as hotspot image first,
you could use a 1x1 transparent pixel for this case if you want.
Additionally the renderer setting need to get set to css3d to display the hotspot as html element and having a 'sprite' element.
Here an example:
hs.renderer = "css3d";
hs.url = "transparent_1x1_pixel.png"
hs.onloaded = function()
  var element = document.createElement('div');
