Alexey Tkachenko
Professional
  • "Alexey Tkachenko" started this thread
Occupation: Interpreting, Building virtual tours
21
Monday, October 15th 2018, 2:28pm
It seems that Krpano Linux tools require minimum GLIBC 2.14. I found it in this thread: https://krpano.com/forum/wbb/index.php?p…glibc#post54241
however, if I go to the download page, it says that Linux tools require GLIBC 2.4 https://krpano.com/download/
Which is correct?
Regards,
Alexey
22
Monday, October 15th 2018, 4:40pm
the core krpanotools file (the 'krpanotools' executable) has GLIBC 2.4 as minimum.
Only the 'krpano Tools' GUI application requires GLIBC 2.14 as minimum.
The older krpanotools versions have an even lower requirement on Linux libraries, but it's unfortunately not possible to do both -be compatible and very old and newer Linux versions... That's unfortunately a typical Linux problem... Windows is much better here when it comes to compatibility.
About your problem - sounds like a compatibility problem, try directly calling the krpanotools from SSH to get more information about the exact case.
Alexey Tkachenko
Professional
23
Tuesday, October 16th 2018, 11:53am
Hi)
If I ty to execute this line,
/var/www/u0566741/data/www/alexeyonline.ru/krpano/krpanotools makepano -config=/var/www/u0566741/data/www/alexeyonline.ru/krpano/templates/normal.config /var/www/u0566741/data/www/alexeyonline.ru/krpano/pano.jpg
I get an error "Segmentation fault (core dumped)"
Regards,
Alexey
Kabkee
Trainee
Occupation: South Korea
24
Friday, October 19th 2018, 11:17am
The Location of the krpanotools is the problem.
I also set up a server with krpanotools as like you'd like to
I also tested a lot for getting the result of the krpanotools.
What was the most important thing is the location of the krpanotools.
What I had known from some experiments is that I had to use absolute path based on server based directory NOT relative path.
If your apache server based on /var/www/ directory,
use "u0566741/data/www/alexeyonline.ru/krpano/krpanotools" with out '/var/www/'
Hopefully this help you out.
Thanks.
Alexey Tkachenko
Professional
25
Monday, October 22nd 2018, 8:34am
Hi)
Thanks for the hint. I managed to get old tools working. the path wasn't the cause.
Regards,
Alexey
Occupation: Code-Slave
26
Monday, October 22nd 2018, 9:34pm
Take a look at this thread for some insight.
The "solution" relates to encryption but applies to just about any other process/command you could be doing with krpanotools executable server-side.
The key with all of this is waiting for the process/command to finish up before moving on.
https://krpano.com/forum/wbb/index.php?p…&threadID=16462
Alexey Tkachenko
Professional
27
Tuesday, October 23rd 2018, 8:16am
Hi, Douglas!
Thanks for that! I'll take a proper look at your thread. ;-)
Regards,
Alexey
