Kabkee
Trainee
  • "Kabkee" started this thread
Occupation: South Korea
Friday, October 19th 2018, 11:23am
watermark with window krpanotools.exe
I use only "krpanotools.exe" (window version) for window server.
I put only one executable file, krpanotools.exe which is already registered by "krpano Tools.exe".
However,
when I execute and make multires with command line, it shows watermarks on all images.
Furthermore,
when I execute the following line on 'Command Line' of windows, it shows all Licenses registered (krpano license, krpano maps plugin license, krpano branding free license).
krpanotools.exe register show
What should I do eliminate watermarks?
which files should be with krpanotools.exe file?
Thanks.
Tuesday, October 23rd 2018, 9:15am
make the 'register' call in the same script as the 'makepano' call.
This ensures that the tools will get registered for the correct user (a web-server typically runs with a different user then when normally logged-in).
Additionally make sure that the krpano tools folder has write permissions (e.g. 777).
Kabkee
Trainee
Tuesday, October 23rd 2018, 9:26am
I added the register line right before makepano comnmand. it works :)
Thanks.
