Sie sind nicht angemeldet.
Dienstag, 13. Juni 2017, 08:07
Visual Hotspot Editor
Hello!
Possibilities of the editor of the hotspot.
Changing the main parameters of the hotspot visually controlling the result.
Move the hotspot with the mouse.
The original system of changing the parameters "click and move".
Output of parameters to the window for editing, copying, pasting. Enter parameters directly on the buttons
Change all the parameters of the text hotspot - colors, shadows, borders, radii, transparency, input and editing of HTML text, editing CSS style.
The ability to make actions in the attributes onover, onhover, onclick, ondown, onnout, onup, onloaded.
Ability to create, delete, copy hotspots
Ability to edit and save changes without opening files xml.
Example of the work of the editor v1.3
Example of the work of the editor v1.2
You can try it here v1.3
You can try it here v1.2
More in detail here:
edit_hotspot 1.3
edit_hotspot 1.2
Example of button operation
»San7« hat folgende Bilder angehängt:
Dieser Beitrag wurde bereits 21 mal editiert, zuletzt von »San7« (20. Dezember 2017, 06:09)
ramirox3
Schüler
Beruf: photographer
  • Nachricht senden
Dienstag, 13. Juni 2017, 23:04
*thumbsup*
Erleuchteter
Beruf: Krpano custom coding / Virtual Tours / Photography / Musician / Recording engineer
  • Nachricht senden
Freitag, 16. Juni 2017, 14:51
Nicely done!
Share?
Or sell, i would like it open source to change some things.
Could build my own though.
Tuur *thumbsup*
http://www.virtualtuur.com
Skype:studiotuur
Samstag, 17. Juni 2017, 08:02
Nicely done!
Share?
Tuur *thumbsup*
  • Thanks for your response!
    What would you like to change? Maybe I can do that for you.
    I would like to sell it, but don't misunderstand me, without opened source code.
    What's your price?
    Right now I'm making edit_layer by the same principle.
    Sizes, borders, rediuses of corners, colours will change.
    In plans edit_txt.
Sonntag, 18. Juni 2017, 11:44
Wery nice!
Very interesting plugin! The author kindly provided the alpha version for a test I liked it very much!
To ensure that the correct move button controls, get used to it.
It is better to do so:
1. select the parameter that will change 2. Press and not release the mouse 3. move in the desired direction (left or right) 4. in order to change faster, move the mouse on. If you slowly and accurately - move the mouse slowly. First, it is not clear, but then very convenient!
Montag, 18. September 2017, 07:15
Deprecated
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »San7« (9. Oktober 2017, 19:05)
Montag, 9. Oktober 2017, 18:11
Change the save method. Added saving without editing files xml. Fixed bugs with editing hotspots with the same names in different scenes .
youtube
Download test
Thanks for the useful information Tuur !
*thumbsup*
Donnerstag, 14. Dezember 2017, 08:52
Almost completed the changes.
It radically changed the editor where extended functionality.
Added panel for input / output of information with the ability to copy and paste settings.
Added a panel to edit all text settings of the hotspot - color, shadows, borders, corner radii, transparency, input, and edit HTML text, edit the CSS style.
Changed the appearance of the main panel, added scroll buttons.
Added stretch panels – you can pull, grasping the lower right corner.
Added to edit the attributes of the hotspot: depth, zorder, distorted, capture, keep, handcursor, maskchildren, mipmapping.
Added all the attributes of action: onover, onhover, onclick, ondown, onnout, onup, onloaded.
Added a block to create, copy, and delete hotspots.
Added button to "on.-off" drag mode for each hotspot.
Added button to open the help information (go to website) for text and hotspots in the hotspot editor.
The button "Display all attributes" lists all parameters editable hotspot in the new input panel and edit the information.
youtube
You can test here
»San7« hat folgendes Bild angehängt:
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »San7« (18. Dezember 2017, 04:15)
Donnerstag, 26. April 2018, 10:18
Fixed some bugs. Works with krpano-1.19-pr16.
Added restriction to move and stretch editor panels within the screen.
example
Dienstag, 7. August 2018, 18:29
Paid For Plugin but Never Got The Product??
Hi All,
Noob here. Yesterday I purchased the hotspot plugin http://novosibpano.ru/Plugins/Hotspot_1.3_en.html but never received an email or any instructions on how to download the plugin.
Anyone have any experience with the process? Thanks!
Samstag, 11. August 2018, 18:11
Sorry, I was not.
I sent you a download link
Montag, 19. November 2018, 07:54
add hotspot
Привет,
я создал плагин для создания и редактирования горячих точек, теперь он имеет больше функциональности и более интуитивно понятный интерфейс, чем этот плагин.
Вы можете увидеть пример создания текстовой точки доступа здесь .
Страница форума здесь .
Описание на сайте здесь . В ближайшее время вы можете добавить все свои параметры.
14
Montag, 19. November 2018, 07:57
add hotspot
Hello
I made a friend plugin for creating and editing hotspots, now it already has more functionality and a more intuitive interface than this plugin.
You can see an example of creating a text hotspot here.
The forum page is https://krpano.com/forum/wbb/index.php?p…&threadID=16252
Description on the site here.
Soon there will be a tab for creating polygonal hotspots with the ability to edit all its parameters.
