jeronicoz
Beginner
  • "jeronicoz" started this thread
Thursday, November 29th 2018, 12:27pm
Function passQueryParameters
Something has changing is the passQueryParameters ?
Using this code :
if (s !== null, if (startscene === null OR startscene === "undefined", set(startscene, get(s));); );    if (startscene === null OR startscene === "undefined",      set(startscene, intsos360tour1),      ;    );
The variable "s" is not found, did this function change between the two version of krpano ?Adding this :
    trace('variable=', startscene);        showlog();
I have always "intsos360tour1" as result
For exemple :
In the new version with new .js all links arrives in the same tour intsos360tour1 (there is 6 tour : 1,2,3,4,5,6)
coming from http://35.177.4.43/virtualtour.html
http://35.177.4.43/internationalsos360tour.html#s=intsos360tour4
same than http://35.177.4.43/internationalsos360tour.html#s=intsos360tour1
With the krpano 1.19.pr8 the function working
coming from http://internationalsos360.com/virtualtour.html
http://internationalsos360.com/internationalsos360tour.html#s=pano10
different than http://internationalsos360.com/internationalsos360tour.html#s=pano13
Friday, November 30th 2018, 8:21pm
krpano doesn't support using the 'hash' character '#' for passing parameters! (although older version accidentally did - see here in the 1.19-r15 release notes the note about the related change/fix).
Only the 'query' character '?' is supported.
See your url:
.../internationalsos360tour.html#s=intsos360tour1
correct would be:
.../internationalsos360tour.html?s=intsos360tour1
jeronicoz
Beginner
Monday, December 3rd 2018, 9:37am
Thanks, it's working fine.
For information, this script came from Panotour pro templates...I tried to export some projects with the last version and they still use #.
Regards,
Jérôme
Tuesday, December 4th 2018, 11:33am
Thanks for the info!
Hmm... so far I know all krpano documentation and examples were for '?' query parameters, so when PTP is using '#' that's not that good of course...
And supporting the # hash key is also not that good, because can it interfere with anchor links (e.g. anchor link names would get passed to krpano as variables).
I will think about a solution...
