Config: VR and stereo support?
  • Hi!
    Converting 12x1 stereo cube strips.
    In my droplet config file I have:
    stereosupport=true
    and
    customimage[vr].stereosupport=true
    The problem is that VR images are not created unless I comment out one of those.
    If I comment out customimage[vr].stereosupport=true, I get both multires in stereo and VR in stereo.
    That seems weird.
    Klaus, would you chime in?
    I've just tested again and all stereo settings seems to work as they should...
    Maybe try the MAKE VTOUR (VR-OPT) Droplet - it has:
    stereosupport=false
    and
    and this way it generates a mono-multires image for normal-viewing and stereo-images for VR-viewing.
    stereosupport=false
    and
    I haven't given much thought to stereo multires. I guess I'd like to keep it for future compatibility. I can always generate a new XML.
    So, currently I have enabled the stereosupport for stereo multires and commented out the customimage[vr].stereosupport. That combination produces both a stereo multires and stereo vr.
    If I leave the customimage[vr].stereosupport=true, the vr images aren't generated.
    Here is my full config:
    Okay - there is one special case about the 'custom images' - when the normal image is SMALLER than the custom image size and is of the SAME TYPE, then they are not generated - because in this case they would need to get upsampled and would be only waste of space and resources.
    You can count on me to hit that special edge case! :)
    My input images are 18432x1536.
