Wednesday, March 13th 2019, 11:17pm
testing server - easier solution for IT illiterate end user?
I am still having problems with the recipients of thumb drives which are used to view vtour projects offline.
It is difficult to train people as the disks go out to many people and even though I have included instructions, this isn't good enough. They want a single file that will run on all systems with a single click and not be asked for permissions. Is there an easy solution to package a vtour into one entity - like a zip folder yet will run? Is Abode Air a solution?
I tried using an alias to the html file, however that doesn't work with the testing server.
Suggestions would be very much appreciated.
Rich
Thursday, April 25th 2019, 7:26am
you can use the included 'tour_testingserver' (not the normal krpano Testing Server) - it's simple click and run the tour...
Or build a standalone application using NWJS or Electron - see here for more:
Offline exe for client (without server)
