Hi, all!
I got a bunch of xml files with boatloads of stuff. Is there any way to load them after first pano is loaded?
There seems to be no obvious way for that and no clear answer on this forum.
Looking forward for suggestions and advice.
Hi, all!
maybe with loadxml() ?
https://krpano.com/docu/actions/#loadxml
depends on what kind of xml,
or if you work with krpano-xml actions or js
I will need to pass hundreds of kb of strings to it...
Ok, will try
Nope, that won't work
it depends on what you want to do...
Hi, Klaus.
I want to call an action that will load and intertpet custom xml with any stuff like loadxml() but without reloading scene.
I'm already planing a special 'includexml(url, onloaddone)' action for such case,
but for the moment you could try calling with these flags:
That should keep the current loaded stuff, but will still trigger some loading related events.
