21
Friday, October 2nd 2015, 10:07pm
Nah nah nah. Like, don't require the entry pad at all.
It's just something resident in the background.. and don't require a reset, have it autoreset..
like on scene 2 password is 6155
if you put in 16155 it doesn't work. If you the password feature itself is secret, then it's hard to enter in the right password.
I'm almost done with this project I'm working on .. I'll code this up and show you and work on the enhanced security feature too.
Sage
  • "Tuur" started this thread
22
Monday, October 5th 2015, 10:36am
sorry Sacha but i have no clue at all what you mean.
But when you say autoreset .. yes.. that is in the planning.
We can discuss it in the 'chat' later.
Tuur *thumbsup*
http://www.virtualtuur.com
Skype:studiotuur
23
Wednesday, October 14th 2015, 12:52pm
Hi Tuur
I guess I did something wrong:)
My tour is generated by PTP 1.8
in the virtualtour0.xml I have
<action name="onxmlcompleteaction">
Password('item', 1234, LpToNormal(), openurl(http://www.krpano.com,_top) );
plugin[combobox].selectiditem(combobox0);
if(autorotate.enabled==false,set(plugin[autorotationOFF].visible,false); set(plugin[autorotationON].visible,true);,set(plugin[autorotationOFF].visible,true); set(plugin[autorotationON].visible,false););
I type 1234 and can see the tour but it comes with an error
WARNING: unknown action: lptonormal
ERROR: unknown attribute/path - scene[get(secretscene)].password
Second thing, when I walk inside tour and come back to the first panorama I still have to type the password.
My intention is, that the user has to type in the password to enter first scene and then he can walk inside without any problems.
Can you tell what am I doing wrong?
Marcin
Sage
24
Wednesday, October 14th 2015, 1:18pm
The Lptonormal action is a custom action. As you can see in the code provided.
You can change that to an action you like to happen when the password is ok.
Are you using the 185 or the 193 version?. They are a bit different still. I come with update with 1.19 release.
It is made to use with scenes, so better call it in the onstart of your first scene.
In the update this will be an option. Btw.. In the 193 version this first scene protection is not working as you might expect.
There are better ways of doing that.
The 'type password only once' i will also implement in the update.
It was not designed for this 'first scene' password in the first place but as many people use it like that i will antticipate on that. It was made to protect things inside a tour, not for main entrance.
Of course you are free to change things in the code to make it work as you like but you can send me your xml files or project and then i have a look somewhere this week.
Please sent with wetransfer.com to virtualtuur@gmail.com
Tuur *thumbsup*
Skype:studiotuur
25
Wednesday, October 14th 2015, 1:52pm
I will wait for the update then.
I would like to have an example tour and I will send pass to those who should see it.
I am using 1.8.5 krpano
Marcin
Sage
26
Wednesday, October 14th 2015, 9:25pm
As you wish.
I offer to fix it for you but if you prefer to wait... Fine
Tuur *thumbsup*
Skype:studiotuur
27
Tuesday, June 28th 2016, 7:12pm
loading view
Hi Turr,
Thank you for the great plugin. I have a question though.
Every time I have a defined start-view, such as:
<view hlookat="110" vlookat="0" fovtype="MFOV" fov="120" maxpixelzoom="2.0" fovmin="70" fovmax="140" limitview="auto" />
The view will load, however as soon as you go to navigate (click and drag) the password plugin somehow re-sets the view to 0,0. Even if that page was not protected. I know it is the password plugin because when I comment out the plugin include statement then the view loads as it was designed to.
Any thoughts on this?
~Andrew
Sage
28
Wednesday, June 29th 2016, 2:40pm
mmm.. 'funny'.
- which version of the passwordplugin do you use? 185 or 193?
- on which krpano version are you running'?
Maybe you can send me a link or the project?
Tuur *thumbsup*
Skype:studiotuur
29
Thursday, June 30th 2016, 9:02pm
Quoted
- which version of the password plugin do you use? 185 or 193?
I am running the 193 Version of the plugin
Quoted
KRPano 1.19.pr5 (Most Recent)
On further investigation,
it appears as though when you disable / comment out the
<include url="pw_vr.xml" />
Statement it will load a predefined view.
30
Monday, December 17th 2018, 2:48am
Before the tour (Little Planet Intro) Can I set a password? Where can I see detailed usage? *confused*
Also, can you use it permanently with one purchase?
This post has been edited 1 times, last edit by "kangsj2277" (Dec 17th 2018, 2:59am)
31
Monday, December 17th 2018, 3:08am
Can you use it if you buy only the top item except the two items as shown below?
Sage
32
Monday, December 17th 2018, 9:52am
when you buy the 'plugin', you can use it as much as you like.
Updates are for free.
It is also open source so you could make changes you wish.
The idea is to protect items within the tour. Secret scenes and/or hotspots etc..
Not as a 'Gatekeeper'. It is possible though.
The update will have that functionality build in.
I am about to release 2-3 new products. After that i will make an update of this plugin.
If you buy the 'plugin' and you need some help with it you can always contact me.
Tuur *thumbsup*
Skype:studiotuur
andrew22222
33
Tuesday, December 18th 2018, 2:30am
Mmmmmmmm! What's this..... 2-3 more products?
34
Monday, May 13th 2019, 2:37am
Can I open a new page with a new window using the openurl I want after clicking on the hotspot and entering the password?
Sage
35
Monday, May 13th 2019, 12:53pm
Sure, read the plugin page.
https://krpano.com/plugins/userplugins/password/#top
Quoted
ACTIONS:
Call: Password(item, yourpassword, the action to do when password is ok, blabla..
Tuur *thumbsup*
Skype:studiotuur
36
Tuesday, May 14th 2019, 11:36am
Thank you. You are a must for krpan forum. Thanks again! Tuur!
Thank you. You are a must for krpan forum. Thanks again! Tuur! *thumbsup* *thumbsup*
37
Thursday, May 30th 2019, 7:24am
exit
When you press the exit button, loading ... text appears and does not disappear. How should I fix it ??
Sage
38
Thursday, May 30th 2019, 10:04am
Hi kangsj2277,
Hard to say from here without example.
Do you try to protect the first scene of the tour?
If so, then there is no 'pwlastscene'.. in pwback action.
That option is not available in this version. It is not as a gate keeper.
It is possible to alter the code though to make that work.
you could do something like:
if(pwlastscene == null, openurl(https://www.krpano.com,_top));
or something like that in the PwBack action.
In the next version this first scene protection will be added.
If you find this problem not on the first scene, please give more info or link to example.
Tuur *thumbsup*
Skype:studiotuur
39
Thursday, October 17th 2019, 10:12pm
Hello
I use panotour + krpano 1.20.2.
When the project is complete, can I insert the password plugin there?
Sage
40
Thursday, October 17th 2019, 10:27pm
I don’t have or do ptp stuff, but i think yes. You need to go into your code though.
It is opensource, so you can alter to your needs.
Tuur *thumbsup*
Skype:studiotuur
Similar threads
