61
Friday, May 24th 2019, 7:35pm
Thanks!!!
Really no, I had not tried. *rolleyes*
*thumbup*
The plugin uses combobox. It is slightly modified, but when you disable a plugin, it is also disabled.
Try to disable as I wrote, it should work.
I will search for the cause
ramirox3
Occupation: photographer
62
Saturday, May 25th 2019, 1:32am
Yes, your solution woks.
But it would be better to be able to work them at the same time
ramirox3
63
Saturday, May 25th 2019, 2:13am
as? where can i see that feature
64
Sunday, May 26th 2019, 2:26pm
I used combobox.xml to create a list of hotspots and organize searches.
Now I do not use it. I made my list.
Download the archive, put the files in the "add_hotspot/plugins_l/editor" folder
Check with yourself this option, if everything works, I will make changes to the next version.
San7 has attached the following file:
  • addhs.rar (33.79 kB - 1 times downloaded - latest: May 27th 2019, 4:25pm)
ramirox3
65
Monday, May 27th 2019, 4:49pm
works!!!
The log shows me this text: ERROR: add_hotspot/plugins_l/editor/textarea.js - loading failed! (0)
But when I close the log all works.
this would be a bit annoying for the client
66
Monday, May 27th 2019, 5:02pm
Do you have this file textarea.js along this path?
ramirox3
67
Monday, May 27th 2019, 5:25pm
I looked for it between the add_hospot and krpano files, but I did not find it
68
Monday, May 27th 2019, 5:27pm
Unzip to folder, check
  • textarea.rar (826 Byte - 1 times downloaded - latest: May 27th 2019, 5:42pm)
ramirox3
69
Monday, May 27th 2019, 5:45pm
Now everything is working well.
Thanks for your great support
70
Tuesday, May 28th 2019, 4:25am
I am glad to help!
This file should be in my example. You may have accidentally deleted it.
71
Yesterday, 6:03pm
Changes
  • Added the ability to edit local hotspots.
  • Changed save method. Empty or default attributes are not saved.
  • The "ondown" attribute button has been added to the editor.
  • Display the name of the active access point in place of the name of the plugin.
  • Partially modified interface.
  • The buttons visible2, enabled2, zorder have been added to the polygonal hot spots tab.
  • Changes in the panel "Settings for color and transparency."
  • Fill color in 0xFFFFFF format (in style and hotspots).
  • Added button to text hotspot - interactivecontent.
  • Drop-down list of scenes without using the plugin "combobox.xml".
  • When creating hotspots by default, no text appears when you hover over.
  • Added "url" button in attribute settings.
  • Added "default selection" button in copy settings.
  • Bug fixes.
Some changes in the save file, do not use this version in previous projects!
An example of creating several hotspot images (local) and placing them in one plane on the wall
San7 has attached the following image:
ramirox3
72
Today, 2:56am
GENIAL! When can we have the update?
