Monday, July 30th 2018, 11:48am
Creating Floor Plans.
Hi, this is a plugin for creating floor plans and placing points with radars.
Capabilities.
  • EEvery operation is done in the browser window and does not require code writing and editing.
  • Create floor plans, dot them with radars. Add drawings, diagrams, images and set icons on them, which open the chosen tour places.
  • To select plans or documents, there is a drop-down list. Customize the window (location, size, positioning, show / hide at startup).
  • Customize the window design (color, transparency, border, rounding, shadows).
  • Enable compass in the plan and view windows, (there are options to show/hide or disable the compass).
  • Select the dot images before and after viewing the scene, adjust their scale.
  • Enable captions, they appear when hovering over the dots.
  • The moving effect. When moving to the next scene, the view direction and the viewing angle are saved
  • The plan image is scaled in respect to the cursor location on the plan, not to the plan center (the place under the cursor does not shift).
  • The plan image is moved with the mouse inside the window.
  • When moving to the next scene, the plan is automatically centered in the window in respect to the spot of this scene.
  • The window with the plan moves around the screen, its size changes if you pull the corner of the window. No need to specify the coordinates and size of the window, just save in the selected position.
Description on Krpano website
How to use - https://youtu.be/kPmb998M0Oo
Example in 3D tour
Description
San7 has attached the following image:
This post has been edited 4 times, last edit by "San7" (Aug 26th 2019, 12:00pm)
Monday, August 20th 2018, 8:07am
Using the plugin.
An example of a tour with an apartment plan:
http://novosibpano.ru/VT/Bavariya/
Wednesday, November 7th 2018, 5:28pm
Made some changes to the plugin
  • Added a button to select the opening scene when switching between plans.
  • Added the button "collapse plan by clicking in the empty space of the screen" (Yes/no).
  • Added the button "expand the plan when hovering the mouse over the button to open the plan" (Yes/no).
  • Added the ability to select the icons of the image points before and after viewing the scene individually for each point.
  • Added the ability to zoom the icon for each point.
  • Fixed some bugs in the executing code.
Monday, July 8th 2019, 9:11am
Made some changes to the algorithm of work.
Added the ability to install different images for each point of the three states:
1. Before watching
2. view scene
3. After watching
A drop-down list of plan names was created without the use of additional plug-ins.
Floor Plans
ramirox3
Occupation: photographer
Monday, July 8th 2019, 8:28pm
Great
because I do not see any reference, in the plugin documentation,
about the image gallery that is in the example?
Nor does the video show this feature
Monday, July 8th 2019, 8:41pm
It is possible to install images.
Clicking on the icons opens the explorer and selects the point image for each of the three states.
http://novosibpano.ru/Plugins/Floorplan2_en.html#spot
ramirox3
Tuesday, July 9th 2019, 12:11am
my question is: if the features: 3D Design project, Make screenshot and on / off light are part of the plugin plugin?
Scott Witte
Occupation: Professional Photographer
Thursday, July 11th 2019, 12:03am
Howdy San7,
Just ran across this plugin and I want to say, Really Nice! Well thought out and complete. If it had been around when I was building my own floor plan plugin I could have saved countless hours and ended up with something better.
One observation: It doesn't seem to be offered on the third party plugins section of the KRPano plugins page. I bet you could get a lot more interest if it were.
Scott
Thursday, July 11th 2019, 9:57am
do not quite understand. The screenshot plugin is in krpano. turn on / off lights - is the scene change? You can simply make a button and switch scenes.
Thursday, July 11th 2019, 10:02am
Thanks for the positive feedback. *smile*
Now I make it possible to add documents and place points on them that will open the specified views in the panorama. After your advice I will post in the plugins section *smile*
Thursday, August 1st 2019, 1:29pm
Hello!
A panel has been added for creating and editing points on plans (documents) that open views with a given view and viewing angle.
Read more here .
Monday, August 26th 2019, 12:02pm
Now a description on the Krpano website .
Updates:
  • Now, when saving a project without a PIN code, the editor files are not loaded.
    Finished project loads faster, increased productivity.
  • When moving to a new scene, the point with the radar on the map moves smoothly. Example in 3d round
  • The ability in the mobile version to set the window size for the plans in proportion to the height and width of the viewport. (file param_EFR.xml - width_mobile and height_mobile)
