jpdeglet69
  • "jpdeglet69" started this thread
Occupation: VR Maker and Document Management Expert
Tuesday, September 10th 2019, 5:54am
EverPano3D, tests and questions!
So,
I go ahead,
- On Mac, "undo", "redo" : no action?
We start a new project with 1 pano.
- How is it possible to add another pano after?
(we have the same limitation with Krpano Droplet, for sure... in this case, I edit/merge manually XML sources).
In case of Krpano import, with large pano 15000x7500, it seems that viewmodel and project/preview doesn't run correctly.
With extruded polygon, sometimes, some part of ground are skipped, see screenshot in attachment.
- Or I don't use the right tool to define complex ground!
jpdeglet69 has attached the following image:
JPhD
VR-Guide®/Eleana CEO
https://vr-guide.online
jordi
Tuesday, September 10th 2019, 8:07am
in this version they are still not affecting the model, they are just in the menu for form work, which I'm afraid makes confusion.
Will try to have it implemented as soon as possible for the geometry part.
In everpano 3D you can just drag new panos at anytime, take a look here.
that was now fixed and will be available in next build
You are using the right tool for sure, there are just few limitations that needs to be taken in care :
1.- you can not make polygons bigger than 180º.
2.- you can not draw polygons that intersects them self.
You can take a look at that part of documentation here and look for Check triangulation.
Using ⇧ + a and locating the mouse over the desired polygon will reveal the triangulation that the software did. From there you should be able to see some errors in case there are, and proceed to delete it and just make it by using smaller parts.
Kind regards
everpano.com step beyond 360
jpdeglet69
Tuesday, September 10th 2019, 11:40am
Kind regards
So, following your advice, I produced
based on 2 linked panos 8000x4000:
https://vr-guide.online/@Forum@eMail/Dep…leine/tour.html
- 2 questions,
1) why circle hotspot is not visible?
2) ON MOBLE with Compliant browser, in VR mode, (my WebSite is https compliant, so real VR mode is operational)
- no hotspot, no navigation, is navigator pro plugin required?
- Does I need to define hotpsots in XML?
For multiple point of view on same scene (thru different panos),
adding reference and linking panos ask to align geometrical points between panos, Y/N?
If I'm right, It should be nice to clarify with a tuto!
JPhD
This post has been edited 2 times, last edit by "jpdeglet69" (Sep 10th 2019, 11:56am)
jordi
Tuesday, September 10th 2019, 2:52pm
in order to print the hotspots, please use the code in here
14
15
16
<!-- automatically add floor-hotspots at scene locations -->
<action name="generate_floor_hotspots" autorun="onstart" scope="local">
	set(floorheight, 152.0);
	for(set(i,0), i LT style.count, inc(i),
		indexoftxt(is_everpano3D_style, get(style[get(i)].name), 'everpano3d_');
		if(is_everpano3D_style == 0,
			copy(st, style[get(i)]);
			addhotspot(calc('floorspot_' + (i+1)), hs);
			hs.loadstyle(floorspot);
			copy(hs.tx, st.ox);
			copy(hs.tz, st.oz);
			calc(hs.ty, floorheight + 1.0*st.oy - 1.0);
			copy(hs.linkedscene, st.linkedscene);
You will dinamically generate the hotspots.
If you would use the code above then in mobile you would also have the hotspots printed. Otherwise if you use the navigator plugin, you can just click around and navigate.
For basic navigation you do not need the Navigator pro License. with the free included in everpano 3D it's enough to navigate around
Kind regards
jpdeglet69
Tuesday, September 10th 2019, 4:13pm
			copy(hs.tx, st.ox);
			copy(hs.tz, st.oz);
Kind regards
Okay, I will add the code.
Nevertheless, if you follow my link from a Mobile you can test in real VR mode.
Without hotspot, with free navigator plugin, gaze navigation doesn't change the scene.
Is-it normal on not?
JPhD
Edge@51
Beginner
Tuesday, September 10th 2019, 6:53pm
I found the solution to navigate (with some clues given by Jordi):
  • Add the "depthmap_navigation.xml" file (can be found in the plugin folder of krpano 1.20) in the root folder of your project
  • Edit the file "main.xml" generated by Everpano3D and add this code in the beginning:
 <include url="depthmap_navigation.xml" />
jpdeglet69
Thursday, September 12th 2019, 5:58am
Code added.
But no hotspot visible.
So in VR mode, without VR controllers, impossible to navigate.
What is the right solution?
JPhD
jpdeglet69
Friday, September 13th 2019, 7:29am
So,
with set(floorheight, 92.0) to replace set(floorheight, 152.0)
hotspots are now visible and active in VR mode.
Gaze clicking is OK.
I have also updated the size values in the style.
JPhD
