make sure to use krpano 1.20 and also the newer gyro2.js and webvr.js plugin from there!
They already support requestPermission for DeviceMotionEvent (which is used by default) and also for DeviceOrientationEvent.
I've done that, not sure what could be wrong. You can check it out here: https://cityguide360.baHi,
please ignore that code above, that's misleading and not krpano related.
All you would need todo is to use the latest krpano version and HTTPS and gyro/webvr will work.
This post has been edited 2 times, last edit by "granton" (Oct 23rd 2019, 10:52am)
