jeromebg
Professional
Occupation: Photographer
101
Friday, October 4th 2019, 9:12am
Should we open a specific post for Panotour update ?
The showtooltip action sends a WARNING: Unknown function: get
Dav-74
Beginner
Occupation: CIO & Enthusiast Photographer
102
Friday, October 4th 2019, 11:48am
That means the system doesn't allow the krpano Tools app to load the krpanotools.exe. For some reason the system blocks it.
Thanks, Klaus!
The problem was with Avast antivirus.
Same for me, I click the "file is safe" and receive this morning a notification that file has been approved by antivirus team as safe.
103
Friday, October 4th 2019, 2:13pm
Yes, I have made a new thread here - please continue there:
Panotour Pro Update Package
Mael B.
Trainee
104
Friday, October 4th 2019, 5:07pm
The encrypt tool does not crash anymore with v1.20.1 but, apparently, it does not correctly encrypt files which contain comments, so the problem is worse !! *cry*
For example, i have an non-crypted file of 90Ko, it is encrypted correctly with v1.20 (and give a file of 32Ko), but with v1.20.1 the encrypted file is only 2Ko (and obviously, i have a parsing error). After removing all comments, i get again a 32Ko file which seems to work correctly.
105
Monday, October 7th 2019, 2:23pm
No Fullscreen-Support
I can´t get krpano 1.20 to switch to fullscreen in landscape-mode anymore on newest Chrome and Firefox. Only Safari on iPhone works so far. And even the VR-mode in the examples on krpano.com are´nt working anymore :-(
I did try your <set var="device.fullscreensupport" val="true" />-switch, but without any luck. Is there a new trick/hack necessary to switch to fullscreen-mode in Chrome and FF?
106
Monday, October 7th 2019, 4:16pm
There will be very soon a fixed version.
Do you mean Chrome and Firefox on iOS?
These browsers don't support any way for a fullscreen view.
And iOS itself doesn't support the HTML5 Fullscreen API on the iPhone.
But why 'anymore' - the iOS Chrome and Firefox browsers were always working that way and nothing had been changed there.
Why? That would only fake the detected browser support. But when the browser itself is not supporting the HTML5 fullscreen mode API, then faking the detection result will not help of course.
That setting could be only used on the iPad with iOS > 12 - there iOS is supporting the HTML5 Fullscreen API, but krpano is blacklisting it because it works so badly. Any dragging on the screen will easily exit the fullscreen mode. Apple has unfortunately limited the fullscreen usage too much there.
Not that I know.
Tuesday, October 15th 2019, 9:21pm
krpano 1.20.2
there is another minor update: krpano 1.20.2 - Release Notes
  • It fixes several Panotour Pro Update Package problems, e.g. custom 'Documents' folders are supported now.
  • The encrypt tool works correct again.
  • There is now again a 32bit Windows version for older systems.
  • The vtourskin.xml has got a nice 'auto tour' feature - just set autotour=true in the tour.xml and the tour will smoothly auto-rotate through all scenes.
  • And there is a new Javascript-Sync-Example - it syncs the view from two different krpano viewers. Compared to older sync-examples it is easier to use and supports more features.
Mael B.
Trainee
108
Tuesday, October 15th 2019, 10:17pm
Thanks Klaus for this quick update *thumbup*
109
Wednesday, October 16th 2019, 6:18pm
hi, don't worked limit fovmax and fovmin after the update. Is there any solution?
UP:sorry, all ok
This post has been edited 1 times, last edit by "[dp]" (Oct 16th 2019, 7:01pm)
olihar
Trainee
Occupation: Interaction Designer
110
Thursday, October 17th 2019, 4:08pm
Did you plan to add full screen button to the themes for iPhones? (The one that simply links to the direct folder if its inside an iFrame)
111
Monday, October 21st 2019, 10:17am
ios13 gyro2.js problem
Does the old krpano support gyro2.js on ios13? After updating ios13, gyro2.js of krpano tour made with old version does not work
112
Monday, October 21st 2019, 10:35am
search the forum for gyro problems. since half a year you need https to use the gyro in the latest browsers.
This post has been edited 4 times, last edit by "indexofrefraction" (Oct 21st 2019, 10:47am)
Similar threads
